It is currently Sun Nov 24, 2024 6:40 am
Post new topic Reply to topic  [ 57 posts ]  Go to page Previous  1, 2, 3, 4
PostPosted: Tue Oct 03, 2017 5:55 pm
(Might be worth noting that Acorn's BBC Micro's banking register is write-only - the OS keeps a copy in zero page so it knows what's going on.)
PostPosted: Tue Oct 03, 2017 8:21 pm
Alarm Siren wrote:
I recognize it. I did very seriously consider using something like it, but I decided that it was important that the bank bits be readable as well as writable so that subroutines / interrupts can save and restore them.
When I was writing memory management programs for the Apple II, I found keeping track of the bank number wasn't too difficult, but I understand your concerns.
I must say, the more I think about Jeff's "Ultra-fast Output" method, the more I like it. Being able to control those outputs from outside of I/O address space opens up some very interesting possibilities. Like a 64K memory map devoid of I/O address space, or, mapping any one of the three 16-byte I/O spaces into zero page "on demand". As a side note, writing code for I/O in zero page is kinda' fun. After studying the Acorn System-1 I re-assembled Sophie's 512-byte Monitor program for I/O in zero page and, IIRC, it shaved off something like 11 bytes.
For your CLKGEN is that a PIC?
Yes, the CLKGEN IC is a PIC microcontroller, as is the little 8-pin 16F18313 used to detect the single-cycle NOP fetch cycles.
Have fun. Good luck on your project.
Cheerful regards, Mike
PostPosted: Tue Oct 03, 2017 8:46 pm
Yeah, it's nice to be able save and restore. There are various approaches, offering different tradeoffs.
The BBC Micro solution Ed mentioned requires twice as much writing, as everything written to the (write-only) bank register must also be written to the image in memory to keep it current.
One way to beat the double-write business is to change the fact the bank register is write-only. To read it back all you need is to attach it to some unused bits of a VIA -- much as you plan to do now, except the VIA would be for reading only.
Of course the ultimate solution is an '816, which, upon interrupt and RTI, manages the save/restore of the entire 24-bit address transparently. But I admit there's educational value in doing things the hard way. :P
Edit: Thanks, Michael, for your thoughts on non-memory-mapped I/O. The 'C02 is an obvious candidate, as there are so many unused opcodes. But the '816 is also eligible, thanks mainly to WDM -- a two-byte NOP whose 8-bit operand is completely up for grabs.
PostPosted: Tue Oct 03, 2017 9:16 pm
Did you run into any problems with interrupts triggering between the write to the bank register and to zero page?
PostPosted: Tue Oct 03, 2017 9:30 pm
I am not a person with Beeb expertise. However, I don't see a problem as long as the code always writes to the memory image first then the actual bank register second (not the other way around). If an interrupt intervenes then the save-restore code associated with the ISR and RTI will only harmlessly "restore" the value which is about to be written.
PostPosted: Wed Oct 04, 2017 2:47 pm
Indeed it does
******** Set up Sideways ROM latch and RAM copy *************************
           ;on entry X=ROM number
DC16   STX &F4     ;RAM copy of rom latch
DC18   STX &FE30   ;write to rom latch
DC1B   RTS         ;and return
Andrew Jacobs
PostPosted: Wed Oct 04, 2017 10:32 pm
Examples of potential pitfalls are convoluted, but updating the register and its memory copy should always be done under interrupt disable (although an occurring NMI will remain a potential problem even then). There is no formally 'safe' way of updating the pair without it.
PostPosted: Thu Oct 05, 2017 2:35 pm
Citation needed! That would be a very interesting example.
PostPosted: Thu Oct 05, 2017 3:20 pm
I think John is wrong on this (but am happy to be proven otherwise with an actual example).
On the Beeb, the established pattern is to always update the shadow first (&F4) before writing to the latch (&FE30).
If an interrupt does happen between the two instructions, all that happens is that the OS ends up restoring the "new" bank from &F4 before returning, making the write to the latch at &FE30 superfluous.
You'll find this pattern used in OS 1.20:
https://acorn.huininga.nl/pub/docs/sour ... 201629.asm
Just search for rom_select
Dave
PostPosted: Thu Oct 05, 2017 5:01 pm
I'd say it's pretty obvious that if the register and its OS copy are not updated atomically, e.g. an interrupt occurs after updating only one of the two, then the interrupt routine can no longer tell which ROM is selected. This may not matter if it doesn't need to know. But it certainly does matter if it does.
E.g. interrupt routine relies on some data or code in some specific ROM X, and, for efficiency, only selects ROM X temporarily if it's not already selected. If the currently selected ROM is Y != X, and the foreground switches to X, then if the OS copy has been updated to X but not the register, or vice versa : kaboom.
Convoluted ? Yes. Impossible ? No. Don't assume what you don't need to. You're rarely in complete control of both foreground code and background code.
PostPosted: Thu Oct 05, 2017 5:06 pm
Thanks - that is an interesting example.
PostPosted: Tue Oct 17, 2017 7:05 pm
Well, another day, another computer design from Alsi....
This is the schematic of the system that all this decoding logic was in aid of. Its still called the Nimbot, and is derived from what you have seen previously, but I decided that I wanted to go for something a bit simpler (in the sense of easier to route) but also more general purpose. I still plan to make a games machine at some point, but I think it'll probably be based on this design rather than the previous one. I am much happier with this one overall.
I am unsure whether to expand the I/O Board header (P3) so that I can use this same logic board for both a games machine and a general purpose one, swapping out only the I/O board (the I/O board would have the gamepad, screen, and sound generation circuitry on it for a games device and a character LCD, keypad and buzzer for a non-games device) or whether to KISS as it is and make the games device have modified logic board.
File comment: NimbotCalc Logic Board
Users browsing this forum: No registered users and 79 guests
