Hi,
I'll scan some more manuals in the next few days and put them on my website. Happy if any of you guys want to copy/mirror them.
Tried both systems tonight, one works, the other appears to have a dead crystal. There is a cleaner copy of the schematic in one of the other manuals, will scan that section first.
It was quite a nostalgia trip entering a simple program using machine code, have not done that for many years.
LJ Electronics Emma 2
Re: LJ Electronics Emma 2
Fantastic 8bitstedy,
I've got several of the modules you have as well, so if you get to scanning, I could use the following:
Microprocessor application system MA04/1 Experiment manual.
Microprocessor application system MA02/1 Experiment manual.
Microprocessor fault simulation and diagnosis expansion system MA08
A/D converter MS3 (I think that's the module I have)
Strain gauge module MS13
Stepper motor MS4
I/O port monitor MS12
Still in search of the manual for the Memory Expansion Module w/EPROM programmer.
I think your tech manual is an older version of the manual. The one I sent Mike looks newer. I suspect he will make it available sometime soon (or else I haven't been able to find it here on the site).
Thanks a ton and a half.
John
Stepper motor MS4
John
Associated pron.
I removed the old battery and replaced it with what I had around. $25.00 was a bit much in my opinion for a replacement.
john
john
- BigDumbDinosaur
jaevans wrote:
Associated pron.
Once I figure out how to share my photos.
john
john
jaevans wrote:
Associated pron.
john
john
If anyone wants to grab files and docs I already have, here's a link to the files I shared with Mike. Let me know if you can't get or see any of the files to the folder as I am just sharing the dropbox link to the folder.
John
https://www.dropbox.com/sh/fxv0ktys0z4z ... U2wFa?dl=0
John
- BigDumbDinosaur
jaevans wrote:
jaevans wrote:
Associated pron.
john
john
In addition to the common image formats (GIF recommended unless high color depth is required), you can attach flat (text) files, PDFs, ZIP archives, and a few others. A maximum of five attachments are possible per post.
Hi,
Two more manuals, MA-02 Experiment manual http://www.ianstedman.co.uk/downloads/MA-02.pdf (37MB) and Fault simulation and diagnosis, http://www.ianstedman.co.uk/downloads/M ... gnosis.pdf 22.6MB.
The second manual has the schematics for the VISA II add-on which adds raster graphics!
Enjoy
Enjoy
8bitstedy wrote:
Hi,
Two more manuals, ..
Enjoy
Enjoy
john
Hi,
I recently acquired an Emma II trainer board and the Visa II expansion card.
I found the Emma II user manual online and the MA08 manual with both schematics.
Does anyone know where I can find the Visa II user manual?
Thanks,
Thanks,
