From 8bit breadboard to 6502
Re: From 8bit breadboard to 6502
I agree - the 6502 choice is the clever choice! It makes good sense from an implementation perspective, although sometimes people complain about the SEC and the not-borrow.
"BCC, or "branch on carry clear," means "branch if less than" if it's after a subtraction."
Thank you! Oh! So the XORing of the carry with Sub was unnecessary. Good to know! So I will simply letch the carry signal into the status register - and my code has to analyse what it means in case of subtraction or addition.
I want to enhance my current breadboard computer to become a 65C02 (I know that this could take ages or will never be successful. But I need a target. And I will learn a lot)
This is why I asked for the microcode. In my breadboard computer I used an EEPROM for the control Logic.
(see screenshot) And I wonder if this is the same in the 65C02.
I think we know from die photos that the 65C02 structure and floorplan is very like the 6502: a large regular first-stage decode (often called a PLA, sometimes called a ROM) followed by a less regular second stage decode (often called random logic)
See here for example (blog post with video within) which we discussed here:
"65C02: Tear down, A look at the CMOS version of the 6502"
But I don't believe anyone has extracted the structure of a 65c02 in the way that visual6502 has done for the 6502.
Hi! Thanks! I am just printing out the patent he's referring to.
Exactly was I was looking for!
Patents cited on die:
http://www.google.ca/patents/US4800487
http://www.google.ca/patents/US4652992
http://www.google.ca/patents/US4876639
Good thinking!
Perhaps a typo - you missed this one:
https://www.google.com/patents/US4876639
Edit oops, meant this one:
https://www.google.com/patents/US4739475
Note that two of the four patents are for the '816.
- GARTHWILSON
- Forum Moderator
nei02 wrote:
I want to implement a BCC and BCS.
I assume that this is equal to a "less than" .
SEC ; Set carry flag to start. (This may be unwanted or unneeded
; in a few situations.)
LDA VarLowByte ; Get the low byte of your two-byte (ie, 16-bit) variable,
SBC #$61 ; subtract the low byte of your two-byte constant, and
STA VarLowByte ; put the result back in the variable.
; Now leave C alone. The resulting C value from above gets
; used in the SBC below. If C=clear, the resulting high byte
; below will be 1 less than it otherwise would have been.
LDA VarHighByte ; Now get the high byte of your two-byte variable,
SBC #3 ; subtract the high byte of your two-byte constant, and
STA VarHighByte ; put the result back in the variable. At the end, C=clear
; means the variable was less than $361 before you started.Code: Select all
SEC ; Set carry flag to start (although this will be unwanted or unnecessary in some situations).
LDA VarLowByte ; Get the low byte of your 2-byte variable.
SBC #2 ; Subtract 2,
STA VarLowByte ; and put it back.
BCS 1$ ; If the low byte started with at least 2, there was no need to borrow, so skip the DEC instruction.
DEC VarHighByte ; Else, decrement the high byte to reflect that there was a borrow from it.
1$: <continue>http://WilsonMinesCo.com/ lots of 6502 resources
Thank you. I just print out the last pages of the 6502 manual. This information is missing in the 65C02 manual.
And I will start to print the first 40 pages of the programmers guide. Thanks for all the tipps.
Hi,
I dont have a 10pF to connect the crystal to the 65c51.
Can I take another value?
No harm in trying different values -- anything under 50 pF, say. Or it might work with no cap at all. But if you run into quirky behavior then try to get a cap that's at least close to spec. Have fun!
Currently I have a 100nF connected.
I get only dots ...........
I adapted a little program to write Hello to the ACIA in a loop:
.alias ACIA $4080
.alias ACIA_DATA ACIA+0
.alias ACIA_STAT ACIA+1
.alias ACIA_COMM ACIA+2
.alias ACIA_CTRL ACIA+3
RESET: LDX #$FF
TXS
LDA #$00
LDX #$00
LDY #$00
STX ACIA_STAT
LDA ACIA_DATA
LDA #%00011110
STA ACIA_CTRL
LDA #%00001011
STA ACIA_COMM
START: LDY #$0
OUTPUT: LDA Hello,y
STA ACIA_DATA
CPY #5
INY
BNE OUTPUT
BEQ START
hello: .byte "HELLO", 0
single stepping looks good.
I have certainly forgotten to connect some pins of the ACIA. Or the address decoding is not correct.
So I will have fun debugging!
Terminal configuration: Cool Term - 9600 8-N-1
.alias ACIA $4080
RESET: LDX #$FF
TXS
LDA #$00
LDX #$00
LDY #$00
STX ACIA_STAT
LDA ACIA_DATA
LDA #%00011110
STA ACIA_CTRL
LDA #%00001011
STA ACIA_COMM
START: LDY #$0
OUTPUT: LDA Hello,y
STA ACIA_DATA
CPY #5
INY
BNE OUTPUT
BEQ START
Hello,
I have no Oscilloscope. Do I need one?
The Voltage at pins 6,7 is 2,65 Volts
But we're not sure if it's producing the correct frequency. A 'scope would reveal that. And maybe your DMM can. Does it have a frequency range? One with sufficient range to measure the oscillator frequency?
Please answer the question about nF versus pF.
