What is Forth?
Re: What is Forth?
I find statements that Forth is not maintainable to be clearly without merit.
I once had to figure out some code by a person that wrote Forth code
and was obviously a Basic programmer.
Most variables were things like A1 and B2 and such. Still, even with some of
the worst coding I'd seen since looking at poorly written BASIC, I was able to
not only understand what the code did but make the needed modification
to solve the problem ( it was related to intertia and not code ).
I can imagine that a person that is used to seeing tight structure of syntax,
like C might not find looking at Forth as readable.
Well written code in any language is a pleasure to read.
Well written Forth is like reading a a well indexed book. I've never seen any language that compares.
Everything is clearly in sequence. Levels of complexity of task are well organized
so that one can quickly go to any depth to understand the intricateness needed
to solve a particular problem.
When done properly one can easily skip over parts that don't need such depth. Strings
like " 45 ms Delay " or " 45 Degrees CounterClockwise " are not hard to read.
What is missing is all the boiler plate noise found in languages like C.
I can except that there is a learning curve needed for all the ! @ SWAP DUP low level
words of Forth but I think people that see Forth that way are spending
too much time looking at the rebar, gravel, sand and Portland cement to see
the bridge that was built.
Dwight
Dwight
Re: What is Forth?
The example from the video posted above is very nice, I watched that, and it was easy to follow and easy to read. Of course, it's a very small program, and seeing it developed keeps the context of the individual words in mind. However, the presenter mentions how there's little need for a stack diagram. Not surprising in this case, since most of the work is done through global variables.
Consider, from the F83 source code.
Block 63
\ Interactive Layer Parsing 02Apr84map
: /STRING (S addr len n -- addr' len' )
OVER MIN ROT OVER + -ROT - ;
: PLACE (S str-addr len to -- )
3DUP 1+ SWAP MOVE C! DROP ;
: (SOURCE) (S -- addr len )
BLK @ ?DUP IF BLOCK B/BUF ELSE TIB #TIB @ THEN ;
DEFER SOURCE
: PARSE-WORD (S char -- addr len )
>R SOURCE TUCK >IN @ /STRING R@ SKIP OVER SWAP R> SCAN
>R OVER - ROT R> DUP 0<> + - >IN ! ;
: PARSE (S char -- addr len )
>R SOURCE >IN @ /STRING OVER SWAP R> SCAN
>R OVER - DUP R> 0<> - >IN +! ;
Or:
Block 55
\ Devices BLOCK I/O 01Apr84map
: UPDATE (S -- ) >UPDATE ON ;
: DISCARD (S -- ) 1 >UPDATE ! ( 1 BUFFER# ON ) ;
: MISSING (S -- )
>END 2- @ 0< IF >END 2- OFF >END 8 - WRITE-BLOCK THEN
>END 4 - @ >BUFFERS 4 + ! ( buffer ) 1 >BUFFERS 6 + !
>BUFFERS DUP 8 + #BUFFERS 8* CMOVE> ;
: (BUFFER) (S n fcb -- a ) PAUSE ABSENT?
IF MISSING 1 BUFFER# 4 + @ THEN ;
: BUFFER (S n -- a ) FILE @ (BUFFER) ;
: (BLOCK) (S n fcb -- a )
(BUFFER) >UPDATE @ 0>
IF 1 BUFFER# DUP READ-BLOCK 6 + OFF THEN ;
: BLOCK (S n -- a ) FILE @ (BLOCK) ;
: IN-BLOCK (S n -- a ) IN-FILE @ (BLOCK) ;
I'll finally leave this:
Block 76
\ Extensible Layer Defining Words 08Apr84map
: ,VIEW (S -- ) BLK @ DUP IF VIEW# @ 4096 * + THEN , ;
: "CREATE (S str -- ) COUNT HERE EVEN 4 + PLACE
ALIGN ,VIEW HERE 0 , ( reserve link )
HERE LAST ! ( remember nfa ) HERE ( lfa nfa ) WARNING @
IF FIND
IF HERE COUNT TYPE ." isn't unique " THEN DROP HERE
THEN ( lfa nfa ) CURRENT @ HASH DUP @ ( lfa tha prev )
HERE 2- ROT ! ( lfa prev ) SWAP ! ( Resolve link field)
HERE DUP C@ WIDTH @ MIN 1+ ALLOT ALIGN
128 SWAP CSET 128 HERE 1- CSET ( delimiter Bits )
COMPILE [ [FORTH] ASSEMBLER DOCREATE , META ] ;
: CREATE (S -- )
BL WORD ?UPPERCASE "CREATE ;
Now perhaps it's much different with modern Forth on modern systems, beyond the constraints of 1K blocks.
But then, maybe not. This is from eForth, and comes from a simple text file with no block constraints:
: parse ( b u c -- b u delta \ <string> )
temp ! OVER >R DUP \ b u u
IF 1 - temp @ BL =
IF \ b u' \ 'skip'
FOR COUNT temp @ SWAP - 0< INVERT WHILE
NEXT ( b) R> DROP 0 DUP EXIT \ all delim
THEN 1 - R>
THEN OVER SWAP \ b' b' u' \ 'scan'
FOR COUNT temp @ SWAP - temp @ BL =
IF 0< THEN WHILE
NEXT DUP >R ELSE R> DROP DUP >R 1 -
THEN OVER - R> R> - EXIT
THEN ( b u) OVER R> - ;
As a consumer of source code, the invisible stack shenanigans raises the cognitive load, at least for me. When the code is jumping in and out of named variables, the variables convey information germane to the context. Obviously, with badly named variables (a, b, x, q1, q2), you're just a step above the invisible stack. But at least the data flow is first class in the code, and not hidden.
All of that "boiler plate noise", like the parentheses of the Lisps, vanish during reading, at least for me. Assuming the code is properly indented. Its still a reality as a developer, you have maintain all of that "noise", but from as a consumer of source code, that stuff all goes away. I don't even see it.
Re: What is Forth?
Please look at the source code for C or BASIC.
Again, you are looking at the wrong things.
Dwight
Dwight
- GARTHWILSON
- Forum Moderator
Re: What is Forth?
A current Forth, Inc. employee posted about these modern applications that were done just in the last few years in Forth:
https://selinc.com/products/ICON/ used by power companies in security and managing communications at substations
http://www.gegridsolutions.com/Communic ... gleMUX.asp also used in electric power substations
https://www.radeuslabs.com/satcom/model-8200-acu/ antenna controller for deep space communications ground stations
http://minimusspine.com/ medical ozone-injection control for spine treatment used in Europe
http://logix-controls.com/engineered-solutions-archive/ controllers for industrial refrigeration systems and data analysis
https://web.archive.org/web/20200607042 ... ansmitter/ medical wearable devices
http://www.merj.com/solutions/ used in financial trading and currency exchange markets, risk analysis (or https://web.archive.org/web/20161023025 ... solutions/ )
Re: What is Forth?
I must be honest - I find most such claims to be questionable.
Especially when I see the manufacturers claiming 9001 standard development.
(as the first one listed does)
This suggests a documentary tool-chain I've never seen in any forth system.
In fact I was just reading some old usenet posts where people are complaining
there ARE no tool chains for forth.
Whilst that isn't strictly true you do have to pay a very large sum of money
to 1 of 2 companies in the world to get anything even remotely usable in a
business environment.
and as for maintainable - would you ever see a C programmer creating a
function simply called "parse" ? Not anywhere I've been you wouldn't.
I think you'd need better examples to convince me of maintainability of forth
for anything other than minority hobby use.
and what about reverse engineering? I can reverse engineer C programs all the
way back into flow charts if I want to - what tools does forth offer for code maintenance?
Admittedly its expensive to buy a decompiler for executables but they do at least exist
and the flowchart stuff is not overly expensive if you have the C source.
Is there even a flowchart tool targeted at forth development never mind any form of project
control? I've never seen anything to support Forth development. Not even a half decent IDE.
Re: What is Forth?
Perhaps I could respectfully suggest that if you don't see the merit in Forth, you either try to see it, or leave Forth alone. Being outspokenly negative about it isn't conducive to a useful exchange of ideas.
Re: What is Forth?
You don't really write programs in Forth, you transform Forth into the desired
application.
You are probably right, no C programmer would even have thought to do this.
"parse" is a end purpose word. The thought to have created such a word to
make the interpreter/compiler process input streams is the essence of the
use of the Forth language.
I can see quite clearly that a C programmer would never have considered such
a function.
Dwight
- GARTHWILSON
- Forum Moderator
Re: What is Forth?
The links I provided came from a current Forth, Inc. employee, a programmer who worked on some of these. I think it's a pretty reliable source. The page https://www.forth.com/swiftforth/ addresses your other criticisms. You get a great tool chain, and all the source code. Even at its beginning decades ago, Forth provided its own IDE, integrating the editor, compiler, disc operations, command-line interpreter, etc., although these have improved greatly over the decades. A former boss took a look at the simple Forth system I have on the workbench and admitted that the $8000 C development system his company just bought could not compete with mine in interactiveness. SwiftForth is not used by hobbyists though. BTW, I've never had a problem with code maintenance on things I wrote in Forth many years ago.
Here's another one: Software to estimate and control costs for large industrial construction. It's 1.2 million lines of Forth. http://constructioncomputersoftware.com/
And another, not quite as new: http://www.carinasoft.com/voyager.html
The first paragraph of the web page says,
- View the heavens on your computer from any place on the Earth, in the Solar System, or beyond. Witness celestial events thousands of years in the past or future. Voyager includes millions of stars, clusters, nebulae, and galaxies visible only through powerful telescopes. This professional version of our software is designed for the advanced user with a serious interest in astronomy. Voyager can be used to control computer-driven telescopes to show you what is actually being simulated on your computer screen. Voyager 4.5 includes a powerful set of features and capabilities.
Re: What is Forth?
One other point to consider. High level Forth written with the proper
use of white space is often indistinguishable from a proper
flow diagram. That is the hole purpose of using Forth in the
first place.
A guess that is a good reason to make a business of writing
C so that the code can extracted in a flow chart.
Dwight
first place.
Dwight
- BigDumbDinosaur
Re: What is Forth?
jazz wrote:
This suggests a documentary tool-chain I've never seen in any forth system. In fact I was just reading some old usenet posts where people are complaining there ARE no tool chains for forth.
Re: What is Forth?
I do, however, have to comment on this:
I don't think that 1.2M lines of Forth is the Forth world that Chuck lives in.
- GARTHWILSON
- Forum Moderator
Re: What is Forth?
Re: What is Forth?
whartung wrote:
To that point, many Forth are (can be) self hosting as well. In that not only is the tool chain present, but the entire source tree of the entire kit. Forth can be used to change and rebuild itself if the developer is so motivated. Especially with the Forth meta compilers. Want to change your Forth from a Indirect style to a Direct style, you can do that, and since much of the code is already in high level Forth, even for a change as significant as that, you probably wouldn't have to change that much. The basic inner interpreter and the compiler, plus any words dependent on the internal layout of the compiled code.
Admittedly, the control files contain such egregious hackery as
: target-set-:-CFA
S" colon @ LITERAL,A ] CALL, [" EVALUATE
;Code: Select all
: : HEAD [ target-set-:-CFA ] ] ;There's probably an opening here for a discussion of metacompilation approaches and techniques, but that should probably be a separate thread if anyone is interested... Or do we have such a thread already?
Re: What is Forth?
Sounds like an excellent idea for a thread!
larsbrinkhoff
Re: What is Forth?
