I think I found the problem... and it would explain the issue with Ibuffs and Ram_base being 1 page apart too.
This piece of code is the problem:
LAB_142A
INY ; increment pointer
INY ; increment pointer (makes it next line pointer high byte)
STA Ibuffs,Y ; save [EOL] (marks [EOT] in immediate mode)
INY ; adjust for line copy
DEC Bpntrl ; allow for increment (change if buffer starts at $xxFF)
RTS
Previously in the code, Bpntrl gets set to Ibuffs. When the DEC instruction gets executed, Bpntrl get set to $FF. Later in the code, we have this:
LAB_15F6
JSR LAB_IGBY ; increment and scan memory
LAB_15F9
JSR LAB_15FF
The routine LAB_IGBY is located in zero page (to increase speed). it looks like this:
LAB_2CEE
INC Bpntrl ; increment BASIC execute pointer low byte
BNE LAB_2CF4 ; branch if no carry
; else
INC Bpntrh ; increment BASIC execute pointer high byte
; page 0 initialisation table from $C2
; scan memory
LAB_2CF4
LDA $FFFF ; get byte to scan (addr set by call routine)
CMP #TK_ELSE ; compare with the token for ELSE
BEQ LAB_2D05 ; exit if ELSE, not numeric, carry set
CMP #':' ; compare with ":"
BCS LAB_2D05 ; exit if >= ":", not numeric, carry set
CMP #' ' ; compare with " "
BEQ LAB_2CEE ; if " " go do next
SEC ; set carry for SBC
SBC #'0' ; subtract "0"
SBC #$D0 ; subtract -"0"
; clear carry if byte = "0"-"9"
LAB_2D05
RTS
The code at LAB_2CEE will INC Bpntrl, which becomes $00 and then INC's Bpntrh to $05. Now this pointer is pointing to the wrong page. And depending upon what is stored there, different things will happen.
This note is incorrect:
It should read (change if buffer starts at $xx00).
My fix would be to add this:
LAB_142A
; add patch for when Ibuffs is $xx00 - Daryl Rictor
LDA Bpntrl ; test for $00
BNE LAB_142P ; not $00
DEC Bpntrh ; allow for increment when $xx00
LAB_142P
; end of patch
RTS
I have tested this fix and it worked for me.
Edited - Changed BIT to LDA in my patched code....can't use BIT to test ZP=0 unless A is already 0.
