Historical question about ASCII
I've always wondered this.
Is there a reason that the ASCII codes 0-9 do not map to the same characters? As in ASCII 0 is "0", 1 is "1", ect...
Its just an annoyance to deal with when converting strings to numbers today, but on the computers of yesterday, wouldn't the extra step of subtracting "0" from the characters to make the numbers match have been a bigger deal computation-wise?
The only problem I see is that having "0" be 0 is that you couldn't have a NULL character. Is that reason enough? As I write this, that small thing does seem like a good reason I guess.
Anyone know how it came to be as it is?
- GARTHWILSON
- Forum Moderator
Re: Historical question about ASCII
I sure wish the A came right after the 9, so you wouldn't have to test in the conversion of hex numbers, just subtract $30.
- BigDumbDinosaur
Despite the seeming incongruities of ASCII with character sets, there is a method to the madness. Only those of us who have been around long enough to have worked with Tele-Type machines and Friden Flexowriters consider ASCII to be 100 percent logical.
A bit of explanation:
https://en.wikipedia.org/wiki/ASCII#History
I was wondering at one point why the newer standard Unicode doesn't support things that appear in a keyboard stream like cursor controls. I got talking to a Unicode expert about it one day and they seemed to have a reasonable explanation. So I made up my own set of virtual keycodes for one project.
http://www.finitron.ca/Documents/virtual_keycodes.html
I'd like to know what is the standard for virtual keycodes ?
ASCII is an older code which is great when characters fit into six or eight bits. But for any apps that need to be internationalized a wide code like Unicode is required.
- BigDumbDinosaur
Unicode produces a bulkier data stream than ASCII and in situations in which the alphanumeric set plus punctuation and control codes is all that is needed, ASCII will be substantially more efficient and economical of bandwidth. For example, transmitting binary data in Intel or Motorola hex form can be done solely with seven bit ASCII, using only numerals, uppercase letters A-F and a few control codes (typically <CR>, <LF> and <EOT>). Western languages that use only the Latin alphabet are transmittable in ASCII and even when lacking some diacritical marks, are usually intelligible to native speakers. Unicode was primarily developed to handle Latin characters with diacritical marks, such as ü, å, etc., localized characters, such as Æ, as well as the characters found in non-Latin alphabets, e.g., Cyrillic.
Incidentally, one of the reasons the control codes in the ASCII set are $00-$1F is the mechanism in Tele-Types was arranged to recognize the low bit patterns as control functions, not printing characters. As ASCII evolved, this characteristic was accommodated so Tele-Types could be used as computer I/O devices. The spread between "0-9", "A-Z" and "a-z" exists because two bits decide if the character set will be numerals, uppercase letters or lowercase letters. It all makes sense in the contexts of doing case conversion or determining if a user typed a numeral or a letter of either case.
Unicode, when encoded in UTF-8, and carrying ASCII, is no more bulky - unless you regard 8 bits as more than 7 bits, which you might!
- BigDumbDinosaur
Unicode, when encoded in UTF-8, and carrying ASCII, is no more bulky...
(Umm, UTF-8 expresses any Unicode character - as can UTF-16, but UTF-8 is more compact.)
- commodorejohn
However, I suspect that any performance gain in that regard will be vanishingly small.
- BigDumbDinosaur
On a hardwired TIA-232 link, baud rate and bit rate are the same. If a pair of short-haul modems is introduced, as was a once-common arrangement in large factories and adjacent buildings sharing a common host, the baud rate between the modems will usually be lower than the bit rate on the TIA-232 connections to the modems, since the bandwidth limits of analog telephone lines still apply.
Incidentally, a format of seven data bits and two stops bits is possible with most serial devices, as is seven data bits, one stop bit and parity, the latter which is often used with MSRs and bar code scanners.
I don't believe UTF-8 supports many non-Latin character sets, such as traditional Chinese. In fact, I seem to recall that pairs of UTF-16 words may be used in such cases, resulting in 32 bits being passed per character.
