I want to put Darryl's SBC-2 OS on my eeprom, as it has everything I need. Since the particulars of his hardware are different than mune, clearly I need to be able to edit it, and thus assemble it.
I tried TASS and discovered sadly it won't run on 64 bit windows.
I tried 64Tass and got errors that suggest the linker wasn't happy. I entered the exact assembler command that Darryl's readme suggested. I am beginning to suspect that 64tass is its own thing, and not just a 64 bit version of TASS.
I don't care specifically what assembler I use, but it would be nice to be able to assemble Darryl's code so I can customize it for my machine.
Any ideas?
Trying to assemble Darryl's SBC-2 OS
- BigDumbDinosaur
Re: Trying to assemble Darryl's SBC-2 OS
Any ideas?
Any ideas?
Incidentally, you are creating a lot of topics about the same thing: your new computer and what you are doing to get it up and running. It's getting a little cumbersome to follow along.
I know
I posted this same question in the main thread, and got crickets for two days. New thread? Instant response! I agree a single thread would be better, but sometimes I get impatient
- BigDumbDinosaur
Dan Moos wrote:
I know
What I did was download DOSbox which emulates x86 and then ran the 32 bit TASS on it.
I actually did download DOSbox, but couldn't get it to actually assemble anything.
What I did was install DOSbox, put the entire SBC-2 folder contents in the TASS directory, go to that directory while in DOSbox (having mounted the C drive), and type in the exact command line in Darryl's readme. Unless I'm missing something, nothing assembled. All I got was the help listing.
How'd you get it to work?
I started up DOSBox and typed
This produced SBC.O64 as output.
mount c c:\users\martin\github
c:
cd SBC2.7
tass /c sbc.asm
