Puzzled by part of one of WDC's official examples
Alarm Siren
Post by Alarm Siren »
Hi again all,
I've been getting my head round WDC's official assembler (no easy feat I can tell you!), but I've come across something in one of their official examples (8LED_CCAH.asm to be exact) which doesn't make sense to me:
;This code is here in case the system gets an NMI.  It clears the intterupt flag and returns.
badVec:		; $FFE0 - IRQRVD2(134)
	php
	pha
	lda #$FF
				;clear Irq
	pla
	plp
	rti
The label "badVec" is mapped into the NMI vector. I... I don't understand what this code is supposed to be doing. To my mind, you could simply do the RTI on its own. It seems to put register A and P on the stack, set A to FF, then overwrite A and P with their original values as pulled from the stack... this just seems like a NOOP, or am I missing something?
barrym95838
Re: Puzzled by part of one of WDC's official examples
Post by barrym95838 »
In the context you provided, it seems to be a bit of cycle-wasting nonsense to me too.
Mike B.
Wow, somebody sure messed up, huh?!
clockpulse
Post by clockpulse »
Why is the (;clear Irq) comment located on a blank line?
Maybe something like sta zploc should be there?
Still, you don't need PHP and PLP, since they're an automatic, implied part of the interrupt sequence and RTI anyway. As least they didn't do SEI and CLI too!
Rob Finch
Post by Rob Finch »
The only thing I can think of here is if there is a register flag located at address $FFE2 where the LDA #$FF instruction is. Maybe the $FF is loaded into an I/O reg by a read cycle ? It does say that it's an NMI flag that is cleared so there must be some sort of FF.
Alarm Siren
In case context helps, here's the whole program:
; File: SIM_8LED_CCAH.asm
; 09/16/2016
     PW 128         ;Page Width (# of char/line)
     PL 60          ;Page Length for HP Laser
     INCLIST ON     ;Add Include files in Listing
				;Test for Valid Processor defined in -D option
	IF	USING_02
	ELSE
		EXIT         "Not Valid Processor: Use -DUSING_02, etc. ! ! ! ! ! ! ! ! ! ! ! !"
	ENDIF
; End of testing for proper Command line Options for Assembly of this program
			title  "6502 xSimul8r Program V 1.00 - 8 LED Active High"
			sttl
; bgnpkhdr
;  FILE_NAME: SIM_8LED_CCAH.asm
;  DATA_RIGHTS: Western Design Center
;               Copyright(C) 1980-2016
;               All rights reserved. Reproduction in any manner,
;               in whole or in part, is strictly prohibited without
;               the prior written approval of The Western Design Center, Inc (WDC).
;               Information contained in this publication regarding
;               device applications and the like is intended through
;               suggestion only and may be superseded by updates.
;               It is your responsibility to ensure that your application
;               meets with your specifications.  No representation or
;               warranty is given and no liability is assumed by
;               Western Design Center, Inc. with respect to the accuracy
;               or use of such information, or infringement of patents
;               or other intellectual property rights arising from such
;               use or otherwise.  Use of WDC's products
;               as critical components in life support systems is not
;               authorized except with express written approval by
;               WDC.  No licenses are conveyed,implicitly or otherwise,
;								under any intellectual property rights.
;  TITLE: 8LED_CCAH
;  DESCRIPTION: This File describes the WDC Simulator Example Program.
;  DEFINED FUNCTIONS:
;          badVec
;                   - Process a Bad Interrupt Vector - Hang!
;  SPECIAL_CONSIDERATIONS:
;  SHARED_DATA:
;          None
;  GLOBAL_MODULES:
;          None
;  LOCAL_MODULES:
;          See above in "DEFINED FUNCTIONS"
;  AUTHOR: David Gray
;  CREATION DATE: September 16, 2016
;  REVISION HISTORY
;     Name           Date         Description
;     David Gray	09/16/2016   1.00 Initial
; NOTE:
;    Change the lines for each version - current version is 1.00
;    See -
;         title  "6502 xSimul8r Program V 1.00 - 8 LED Active High"
;endpkhdr
;                             Include Files
;None
;                              Global Modules
;None
;                              External Modules
;None
;                              External Variables
;None
;                               Local Constants
;	VIA_BASE:	equ	$f0
	VIA_BASE:	equ	$7FC0		;; base address of VIA port on SXB
	VIA_ORB:	equ	VIA_BASE
	VIA_IRB:	equ	VIA_BASE
	VIA_ORA:	equ	VIA_BASE+1
	VIA_IRA:	equ	VIA_BASE+1
	VIA_DDRB:	equ	VIA_BASE+2
	VIA_DDRA:	equ	VIA_BASE+3
	VIA_T1CLO:	equ	VIA_BASE+4
	VIA_T1CHI:	equ	VIA_BASE+5
	VIA_T1LLO:	equ	VIA_BASE+6
	VIA_T1LHI:	equ	VIA_BASE+7
	VIA_T2CLO:	equ	VIA_BASE+8
	VIA_T2CHI:	equ	VIA_BASE+9
	VIA_SR:		equ	VIA_BASE+10
	VIA_ACR:	equ	VIA_BASE+11
	VIA_PCR:	equ	VIA_BASE+12
	VIA_IFR:	equ	VIA_BASE+13
	VIA_IER:	equ	VIA_BASE+14
	VIA_ORANH:	equ	VIA_BASE+15
	VIA_IRANH:	equ	VIA_BASE+15
		CHIP	65C02
		LONGI	OFF
		LONGA	OFF
	.sttl "6502 xSimul8r Demo Code"
	.page
;                    6502 xSimul8r Demo Code Section
;Example code to controll 8 LEDs driven from the W65C22 VIA Port B
		org	$2000		;Our program code will be at $2000
	START:
		sei
		cld
		ldx	#$ff		; Initialize the stack pointer
		txs
; First, we initialize the VIA chip registers and set Port B to OUTPUTS
		lda	#$ff
		sta	VIA_DDRB	; set all as outputs
; Now we initialize the X register to use to count from 0 - 255 (FF)
		ldx #$00
;This is our loop where we get a value from $3000 in memory and load it
;into VIA Port B Output Register.  If ran all at once, this will cycle through memory
;from $3000 - $30FF.  The content at each memory address will be output to Port B
;which will be visable on the 8 LEDs as a binary equivalent.
;This exercise is meant to be done in the xSimul8r using single stepping.  The user can
;load the memory at $3000 with any data they wish.
LOADER:
		lda $3000,x		; Load the value that is in memory at 3000 + x index.
		sta VIA_ORB		; Display value on LEDs.  Value can be seen in ORB register of VIA
		inx				; Increment the value of X by 1
		bne LOADER		; Branch to the label "LOADER" if the value of the X-register is not $00
;After 256 loops, the program is done and we give control back to the simulator.
	IRQHandler:
		pla
		rti
	php
	pha
	lda #$FF
				;clear Irq
	pla
	plp
	rti
This_project_end:
WDCMON_RAM_START	EQU	$7C00
ROMSPACE EQU WDCMON_RAM_START-This_project_end  ;gives space left in the ROM BEFORE WDCMON TABLES
	IF ROMSPACE<0
		EXIT         "Not Enough Memory for This Application - bumping into WDCMON! ! ! ! ! ! ! ! ! ! ! !"
	ENDIF
	bits:	db	1
	cnt:	db	0
	wraps:	dw	0
	delay:	db	10
; New for WDCMON V1.04
;  Needed to move Shadow Vectors into proper area
	SH_vectors:	section
Shadow_VECTORS	SECTION OFFSET $7EFA
					;65C02 Interrupt Vectors
					; Common 8 bit Vectors for all CPUs
		dw	badVec		; $FFFA -  NMIRQ (ALL)
		dw	START		; $FFFC -  RESET (ALL)
		dw	IRQHandler	; $FFFE -  IRQBRK (ALL)
	        ends
vectors	SECTION OFFSET $FFFA
	        ends
	        end
Rob Finch
Post by Rob Finch »
Having a schematic of the board would help too. Just to see if there's an NMI disable FF hooked up.
