Liara Forth, an "ANSI(ish) initial Forth" for the W65C265SXB
Re: Liara Forth, an "ANSI(ish) initial Forth" for the W65C26
How do you check for stack underflow? How is the empty stack indicated when TOS is in a register?
- barrym95838
Yeah, what nyef said. The memory footprint is slightly different, but if (x == SP0), then the stack is empty. Period.
Mike B.
Mike B.
so, X is still the stack pointer, and you INX and DEX it, but the TOS just happens to be in a register, so the "normal" TOS is essentially an under word of memory, is that it?
- barrym95838
Yeah, here's what an empty stack looks like with TOS in RAM (higher numbered addresses on top for all examples):
Here's what what a stack with two items looks like with TOS in RAM:
Here's what an empty stack looks like with TOS in A:
Here's what what a stack with two items looks like with TOS in A:
The memory cell at SP0 should never be touched in either method unless you under-flow the stack (assuming that you pre-decrement before a push and post-increment after a pull).
The register nonsense in the last example came from whatever happened to be in A when the stack was initialized, and can be safely ignored.
Mike B.
[@Scot: you appear to have a typo in line 496 of https://github.com/scotws/LiaraForth/bl ... forth.tasm]
SP0-> nonsense <-sp
nonsense
nonsense
SP0-> nonsense
NOS item
TOS item <-sp
SP0-> nonsense <-sp A = register nonsense
nonsense
nonsense
SP0-> nonsense
register nonsense
NOS item <-sp
nonsense A = TOS item
Mike B.
Neat drawings - when this is all over, we should write some sort of document on this
After actually recoding various parts of Liara to TOS-in-X, it turns it really doesn't change stuff much (which I think was Garth's position all along). It makes some things slightly clearer, but also requires adding lda.dx 00 (LDA $00,X) at some spots where before you could just use Y as TOS. So it's slightly slower.
Since I set out to make this a "speed first (within reason)" Forth, I'm going to take the "dude, stop whining and fix your damn code" path and stick with TOS-Y despite the added complexity. Going back did make stuff clearer (especially thanks to Mike), so this was worth the time to go over it again.
- barrym95838
I should have been more specific about the typo. Just search for the string "sty.d 00", and you should find it. It has drifted to line 507, as of this morning.
Mike B.
Mike B.
Ah, got it now. Thank you!
- GARTHWILSON
- Forum Moderator
My approach in my '816 (actually '802) IDT Forth was to reduce the number of times NEXT, nest, and unnest have to run by making a lot more of the standard words primitives (ie, code definitions), words that are usually written as secondaries (ie, colon definitions). Then there are the headerless optimizations like DUP >R which goes a lot faster if it is merged and made to be a single primitive.
- barrym95838
I think that Scot is using a custom variety of STC, Garth.
@Scot: have you considered the possibility of changing:
to something like:
Mike B.
stx.d tmpdsp
lda.# dsp0
sec
sbc.d tmpdsp
bpl quit_ok
lda.# es_underflow
jmp error
quit_ok
cpx.# dsp0
bcc quit_ok
beq quit_ok
lda.# es_underflow
jmp error
quit_ok
Mike B.
barrym95838 wrote:
@Scot: have you considered the possibility of changing: (...)
Also, congratulations! You are now officially the second person on the planet to have written code in Typist's Assembler Notation. Amazing growth rate, right?
- barrym95838
scotws wrote:
... Thank you, definitely better, will include and test this evening ...
cpx.# dsp0+1
bcc quit_ok
lda.# es_underflow
jmp error
quit_ok
lda.dx 00 ; NOS
sty.dx 00 ; TOS
sec
sbc.dx 00
tya
eor.# 0-1
sec
adc.dx 00
sty.d tmp1
lda.# 0000
sec
sbc.d tmp1
tay
tya
eor.# 0-1
tay
iny
cmp.# 0ffff
bne refill_source_is_not_string
; Simply return FALSE flag as per specification
dex
dex
sty.dx 00
ldy.# 0000
inc.a
dex
dex
sty.dx 00
tay
You can eliminate the jsr nibble_to_ascii rts at the end of byte_to_ascii.
I can't find @ (FETCH) and ! (STORE) in your source ... did you really make it this far without using them, or am I just looking in the wrong places?
Mike B.
Thanks for all the improvements, though I am getting an headache for slapping my forehead with each one.
Won't get to implement the changes until this evening, so just theoretically - I assume that's a CLC and not a SEC, or am I not doing the logic in my head right?
Not FETCH or STORE yet, you are right, which is kind of silly, I'll see about getting to that this evening (since I can't enter numbers other than 0, 1 and 2 yet, STORE is not that useful at the moment).
I've been trying to code Liara so that there is always some form of a working system after every step, starting the point where I got the main loop going, and so far, that has worked. With EVALUATE in place, I can get rid of most of the "scaffolding code" for printing the boot strings (need .( before, of course, but that is now trivial). Next big steps will be CREATE so I can work my way to COLON and SEMICOLON after testing stuff with VARIABLE and CONSTANT. Then things should go faster.
Thanks again!
barrym95838 wrote:
tya
eor.# 0-1
sec
adc.dx 00
Thanks again!
