; Jim Butterfield described the post-processing of Supermon 64 binaries
; in a posting to comp.sys.cbm on Dec 20, 2003:
; I should note that, since Supermon+64 is relocatable code, the source
; does not assemble into the final binary file. It may seem crude, but
; I follow this procedure: (1) The source is carefully structured so
; that there are no "dispersed addresses" such as might be created with
; something like LDA #>VECTOR .. LDY #<VECTOR - every relocatable
; address is two adjacent bytes; (2) I assemble the source TWICE, to
; two different page addresses; the only difference in the binaries will
; be the high-order bytes of the relocatable addresses; (3) a small
; post-processing program blends the two binaries into a relocatable
; package, adding a Basic driver to complete the bundle.
; Source:
https://groups.google.com/forum/#!searc ... _UQlwVnPcJ
; This code was disassembled from the original Supermon+64 V1.2 binary.
; The relocation stub starts at the Start of Variables pointer (VARTAB) and
; works backwards through the Supermon64 machine code, copying it to the top
; of basic memory pointer (MEMSIZ), and decrementing the pointer as it goes.
; Relative addresses that need to be adjusted are marked with a $36 byte
; immediately following them. Since we're working backwards, the marker is
; encountered first, then the high byte, then the low byte of the address
; needing to be adjusted. The relative addresses are calculated such that
; adding the top of memory to them will yield the absolute address of the
; jump target in the relocated code.
; The next step will be to build a Python script that will take Supermon64
; binaries assembled to two different addresses and output relocatable code
; with the relative addresses and $36 address markers.
