I just tried the ASCII Mandelbrot BASIC example from the RC2014 Gitgub repo and it works unmodified in EhBasic. Here's a link:
https://github.com/RC2014Z80/RC2014-BAS ... brot/Ascii
I plan to time it on my 1 MHz 65c02 and compare it to my Forth version.
RC2014 ASCII Mandelbrot BASIC Example Runs in EhBasic
- BigDumbDinosaur
Re: RC2014 ASCII Mandlebrot BASIC Example Runs in EhBasic
Martin_H wrote:
I just tried the ASCII Mandlebrot BASIC example from the RC2014 Gitgub repo and it works unmodified in EhBasic. Here's a link:
The elapsed execution time was 21 minutes 48 seconds and produced this output:
....''''''^![!~~~~'''''''''''''''~~~~?[ &&::;/:^!:O!~'',,,,,,,,,,,,,,,,,,,,....
....''''''';![!~~~~~~~~~~~~~~~~~~~~/x ?; /:/ &''',,,,,,,,,,,,,,,,,,,,....
...,'''''''':![^~~~~~~~~~~~~~~~~! O < :?<[~''',,,,,,,,,,,,,,,,,,,,,...
...,''''''''<:!<^!~~~~~~~~~~~~!: [x?X^ '''',,,,,,,,,,,,,,,,,,,,,...
.,,,''''''''''!x[ :/<<[;;;;& : ~'',,,,,,,,,,,,,,,,,,,,,,,.
.,,'''''''''''!: xxOx [ :^!,,,,,,,,,,,,,,,,,,,,,,.
,,''''''''''~!! X/~~'''',,,,,,,,,,,,,,,,,,,,,,
ArnoldLayne
Re: RC2014 ASCII Mandelbrot BASIC Example Runs in EhBasic
On my homebrew 65c02 machine, execution time of the unmodified program was 2.43 minutes @8MHz.
I then tried using INC COUNTER instead of COUNTER=COUNTER+1 in line 150 and got 2.35 minutes.
ArnoldLayne
Martin_H wrote:
I bet my Forth version would finish in about 30 seconds on your machine.
Which Forth flavour would you recommend?
I ported Tali Forth to my machine because it conforms to modern Forth syntax. Here's a link:
https://github.com/scotws/TaliForth
Forth is a neat idea, but on a 65C02 SBC without external storage how do you save CREATE d word definitions?
I suppose you could have them in a text file that is re-submitted every time you boot Forth. Or perhaps there is a method to save the RAM library?
My Forth concepts are a little rusty, so I may be missing something.
- GARTHWILSON
- Forum Moderator
You could save compiled images in a tiny flash module or something like that, but on my workbench computer, I just send it the source code every time I use it, and it compiles or assembles or interprets on the fly, as appropriate.
