65SPI
Ruud
Post by Ruud »
fachat wrote:
Hi Ruud, did you look at my SD-Card interface?
YES, this is what I'm looking for: simple and 6502 driven!
Thank you very much !!!
    ___
   / __|__
  / /  |_/     Groetjes, Ruud
  \ \__|_\
   \___|       URL: www.baltissen.org
8BIT
Post by 8BIT »
I have updated the 65SPI project on my website. I had originally set all of the Slave Select (SS) outputs to default to low. However, most if not all SPI devices have active-low SS pins. I have updated the device to initialize with the SS pins high and updated the datasheet accordingly.
Thanks to Andre for pointing this out. I had corrected this with the SBC-3 and SBC-4 versions, but forgot to go back to the original 65SPI and fix it there.
Here's a link to the 65SPI Page:
http://sbc.rictor.org/io/65spi.html
There's a download link at the bottom of the page.
DerTrueForce
Re: 65SPI
Post by DerTrueForce »
One thing to note on the topic of the XC9572 CPLD is that Rochester Electronics are still making them. Trouble with them is that they have a minimum purchase price of $100(probably USD) on them, and unfortunately, they aren't available in PLCC, but it appears that the 3.3v ones(100-pin TQFP only) can be run at 5v(just from a quick look at the datasheet).
These might be viable, but it may be a bit of a pain to do. It would probably need a breakout board(in my ignorant opinion).
Many thanks to Dr Jefyll for bringing up Rochester Electronics, here.
Re: 65SPI
DerTrueForce wrote:
One thing to note on the topic of the XC9572 CPLD is that Rochester Electronics are still making them. Trouble with them is that they have a minimum purchase price of $100(probably USD) on them...
Just to be unambiguous, Rochester has a 100 dollar minimum per order, not per item.
DerTrueForce
Re: 65SPI
Ooh, good thing you picked up on that, BDD. That would've bit someone where it hurt.
Re: 65SPI
You're welcome! But I'm just as surprised as you are. (I only searched a few parts, but I found stuff I thought I'd never see again.)
Huh? Are we looking at the same site?? What I get is 100 dollar minimum per line (ie, quantity of a single item), and a 250 dollar minimum per order (or pay the difference as a service charge).
"Note: To meet the $100 line minimum the minimum order qty for this part is 295."
"Note: Orders under $250 can be completed if you agree to accept a service charge."
Re: 65SPI
A group-buy could make that workable - if 10 people want something, it could be approx $10 each, double that for shipping, and that's a good price for something you can't get anywhere else - even if you end up with lots of parts when you only needed two or three!
Re: 65SPI
Oops! :oops: You are right! I apparently can't see that print due to color, but my wife, who happened to be looking over my shoulder as I was reading your post, could see it. Good thing I have her around. :lol:
Re: 65SPI
Hullo, Mrs Dinosaur! Nice to have you with us! :)
Re: 65SPI
:D :) :lol: :wink:
8BIT
Re: 65SPI
Post by 8BIT »
Step 1 of converting the 65SPI from a Xilinx 9572 to Atmel 1504 is finally done. I have a successfully compiled JED file. I had to remove a few features to get it to fit.
Step 2 will be trying to optimize the code to fit a few features back into the design, if possible.
Step 3 will be to actually test a ATF1504 on my SBC-4 using the CF adapter and the ENC28J60 Ethernet module.
Stay tuned. My progress will be slow, but I'll do my best to keep it moving.
Re: 65SPI
Was this due to insufficient logic resources, insufficient pins, or both?
8BIT
Re: 65SPI
Post by 8BIT »
Really not sure... it would not provide a fit report for some reason and the error reports I could find talked a bout conflicts with clocks. I suspected the latches I had were the problem so I eliminated the clock divider and associated latches. I had also added some intermediate logic to help simplify some of the state machine logic. The current resource usage is:
Logic Array Block	Logic Cells	I/O Pins	Foldbacks	TotalPT		FanIN	Cascades
A: LC1	- LC16		10/16(62%)	8/16(50%)	0/16(0%)	34/80(42%)	(27)	0
B: LC17	- LC32		16/16(100%)	8/16(50%)	1/16(6%)	43/80(53%)	(27)	0
C: LC33	- LC48		15/16(93%)	6/16(37%)	1/16(6%)	40/80(50%)	(27)	0
D: LC49	- LC64		12/16(75%)	5/16(31%)	0/16(0%)	27/80(33%)	(27)	0
Total dedicated input used:	1/4 	(25%)
Total I/O pins used		27/32 	(84%)
Total Logic cells used 		53/64 	(82%)
Total Flip-Flop used 		37/64 	(57%)
Total Foldback logic used 	2/64 	(3%)
Total Nodes+FB/MCells 		55/64 	(85%)
Total cascade used 		0
Total input pins 		9
Total output pins 		19
Total Pts 			144
I have enough pins but the logic cells are nearly maxed so that may have been one problem.
The current setup has all features except the SPI clock divider. There are 2 clock choices: use PHI2 or an external shift clock. 95% of the time I ran the SPI clock direct from PHI2 on both SBC-3 and SBC-4, so I'm not too worried about losing that option. I really need to go back now and verify all the other logic translated correctly and that the state machine functions are still correct.
Re: 65SPI
Total input pins 		9
Total Pts 			144
Are you letting the fitter decide where to place pins?
Alarm Siren
Re: 65SPI
Post by Alarm Siren »
In my experience, it mainly refuses to spit out a fit report if you have a semantic (not syntactic) error in the CUPL code. E.g. you make reference to a NODE's output, without defining the necessary inputs (such as .d & .ck) for it to know what kind of NODE it is.
