It is currently Thu Nov 14, 2024 10:27 pm
Post new topic Reply to topic  [ 64 posts ]  Go to page Previous  1, 2, 3, 4, 5
PostPosted: Mon Dec 19, 2016 10:17 am
DerTrueForce wrote:
Trouble is, I'm after cross-platform tools if at all possible. Kowalski sounds useful, but it's Windows-only. I think I'll use the SB-assembler 3, as i actually already have it, as it turns out.
My assembler/linker are written in Java and run on anything with a JRE.
Andrew Jacobs
PostPosted: Mon Dec 19, 2016 7:44 pm
BitWise's (above) does look really good. Do look into it. He even implemented, as a built-in part of the assembler, program structures, and it automatically uses JMP instructions where branches won't reach.
PostPosted: Mon Dec 19, 2016 9:05 pm
I need to upload some new zips with the latest files.
Andrew Jacobs
PostPosted: Tue Dec 20, 2016 4:19 pm
Hi DerTrueForce!
It seems, we go in parallel, as someone says, neck and neck... :wink:
During the last three days I tortured an LCD display. This is my first experience with it (and with 6502 assemly language too). Several times I was going to throw that device into the trash, but each time found a mistake in the program and continued to experiment. And finally, I won. It works.
Now I need to optimize the program, because after all quick fixes and patches it looks terrible.
The connection made through port A of R65C22. MPU clock is 1.8432 MHz. The display type is LCM1602K-FSPG-YBW-R. I have no right datasheet, so I don't know the type of controller (HD44780, KS0066, SPLC780D or any other). I went through one by one initialization algorithms (from all available datasheets), trying to find the working one. Two of the tested ones were suitable.
In the process revealed the need for the time delay between characters, otherwise it turns out the garbage on the display (it seems, the program is too quick :D ).
If you have questions for me, I will try to answer.
Vladimir
