It is currently Tue Sep 24, 2024 1:36 am
Post new topic Reply to topic  [ 60 posts ]  Go to page 1, 2, 3, 4  Next
PostPosted: Sat Nov 26, 2016 9:47 pm
Hi, 6502.org.
C compilers targeting the 6502 have never been very good--the processor just wasn't meant for C. Part of the problem is a lack of good tools: cc65 (the most commonly-used one) has insurmountable problems owed to its small-C heritage, including relying on a very slow (zp),Y-based software stack for all of its computation, inability to work with banked-memory systems (crucial on development for game consoles using a 6502), and a very weak optimizer. I can't speak for the quality of the WDC compiler's code output, but WDC's tools are not cheaply available. If someone has a license to the software, I would appreciate seeing what kind of assembly it generates.
I believe building a C compiler for the 6502 processor from the ground-up would be in best interest for the 6502 community. This will allow existing C code running on 6502's to run faster, in the case of Fuzix and Contiki. Second, the entry level to the development field will be lowered as well, keeping the community alive. Existing retargetable C compilers like GCC and Clang/LLVM are not made for 8-bit processors (except for, perhaps, GCC's AVR target).
I've read David Wheeler's excellent 6502 Language Implementation Approaches, so I'll be using some of his ideas here. The biggest thing to have would be optimization, especially detecting when 8-bit operations can be used instead of int-sized ops. Standard C promotion rules do not make this easy, but it would go a long way towards well-running code. Call graph analysis would be very helpful as well: to build a call graph of all the static functions in a module and automatically assign static spaces for parameter passing and locals. Or, the static qualifier could be placed on a function parameter to be passed the same way.
Second, splitting the stack into two like Forth does would make calculation much faster: have a zp,X-indexed data stack and a (zp),Y-indexed parameter stack. We might assign some fixed zero-page locations for the first [i]n[/n] bytes of parameters and locals. Extra parameters are stored on the software stack, as well as locals to be preserved.
Finally, compilation to bytecode would be a great for memory-limited platforms, though this would greatly slow down execution. Maybe allow selecting between bytecode and native to combine both advantages?
As for what the C compiler would be named, I'm clueless. Maybe CC650, or CC66, to play off of CC65's legacy, or CCMOS (which is even sort of a pun)?
PostPosted: Sun Nov 27, 2016 12:00 am
jamestn529 wrote:
C compilers targeting the 6502 have never been very good--the processor just wasn't meant for C. Part of the problem is a lack of good tools...
I would suggest targeting the 65C02, not the NMOS part, unless your ultimate target is an eight bit home computer, such as the C-64. The NMOS 6502 is much too outdated and constrained when compared to the 65C02, especially when a compiled language such as C is involved. There are, of course, the classic 6502 bugs with which to deal, e.g., JMP (<addr>), as well as other hardware annoyances. The 65C02 eliminates all that, as well as provides an improved instruction set that will mesh better with a C compiler. Also, current 65C02's can operate at much higher speeds than the 6502, which would help with performance issues that inevitable arise with compiled languages. Garth Wilson, I and others routinely discourage first-time builders from considering the 6502 and instead, build with the 65C02 or 65C816.
Speaking of the 65C816, a C compiler that targets that MPU and is optimized to take best advantage of it would be substantially different than one for the 65C02. The 65C816's 16 bit registers, 16 bit stack pointer, relocatable direct page, stack addressing modes and large address space really make it a different processor than the 65C02 when considered from the standpoint of anything higher level than assembly language.
PostPosted: Sun Nov 27, 2016 12:54 am
David Schmenk has done some nice work in PLASMA:
viewtopic.php?f=2&t=2981&hilit=schmenk
Perhaps some of his ideas and techniques could be leveraged into something a bit more C-like?
Mike B.
PostPosted: Sun Nov 27, 2016 1:52 am
Relating to BDD's post above, I have an article on the CMOS 65c02's many improvements over the NMOS 6502, at http://wilsonminesco.com/NMOS-CMOSdif/ .
A great C compiler would definitely add a good promotion to the '02. I'm sure WDC (and a lot of users) would be very glad for one. I have an example of the inefficient code produced by the cc65 compiler about half way down my page "Assembly Language: Still Relevant Today." If an improved C compiler were made for the more-capable '816, that would be valuable too.
PostPosted: Sun Nov 27, 2016 7:08 am
I would suggest targeting the 65C02, not the NMOS part...
My apologies, when I say 6502, I generally mean the 65C02. I agree that the 65C02 enhancements are far too useful to be passed up. An NMOS 6502 target should still be available, though, for people compiling for retrocomputers and consoles.
I agree. For example, you want to prefer 8-bit operations compiling for the 65C02, but you want to prefer 16-bit operations for the '816 to avoid having to SEP/REP. Emulation-mode '816 could be targeted as a super-65C02, and full '816 support added later. I don't know how much code could be shared between the two, though.
EDIT: What language is the best to implement the compiler in? OCaml, or another ML-family language, would be my choice. Pattern matching and ADT's are extremely useful in compiler construction.
PostPosted: Sun Nov 27, 2016 8:56 am
CC65 is good for that purpose. My opinion is that the time to be expended in developing a new compiler should be focused on the present state of 65xx technology.
Generally speaking that is true. Where it would get interesting would be in the standard I/O library, in which eight byte operation would be needed to access hardware. Also, that is when the XBA instruction becomes very useful. You also have to be careful about 16 bit loads and stores on memory that is adjacent to hardware, lest you accidentally touch a hardware register when the MSB is fetched or stored.
One thing to consider is that a 16 bit memory access uses an extra clock cycle to load or store the MSB. In the case of an R-M-W instruction, such as INC <addr>, two extra clock cycles get used, since a load and store occur in the same instruction. So there are performance implications to consider, especially inside of loops. In any case, REP and SEP are inexpensive instructions.
You might as well just compile for the 65C02 if the system is going to run in emulation mode. The '816 doesn't offer that much over the 'C02 when running in emulation mode, but can cause development headaches due to subtle differences in instruction behavior, e,g., MVN and MVP can only access zero page in emulation mode.
That would depend on the machine on which the compiler is to be used. Most of us cross-develop 65xx code on Linux or Micro$oft systems. What would be an achievement would be to develop a compiler that would efficiently run on an actual 65C02 or 65C816 system, such as my POC unit, which is native mode '816. :)
PostPosted: Sun Nov 27, 2016 7:33 pm
CC65 is good for that purpose. My opinion is that the time to be expended in developing a new compiler should be focused on the present state of 65xx technology...
While our focus should be on the 'C02, we should support the NMOS as well. The communities that still program on the NMOS (C64, NES, Apple II) will appreciate having a better compiler. There's equivalent code sequences for the additional 'COS instructions.
The extra addressing modes would come in handy, particularly the stack-relative ones. The long addressing modes would be used for far pointers.
OCaml can be compiled on Linux and Windows. It doesn't compile to C as far as I know, so self-hosting wouldn't work. We could prototype the compiler in OCaml and translate it to C, I suppose--the Rust compiler was first written in OCaml and translated to Rust.
EDIT 2: fixed a quoting error
PostPosted: Sun Nov 27, 2016 8:06 pm
When you're constantly dealing with 16-bit quantities as you would in a HLL, the '816 has much better performance than the '02 does. (Veterans here have heard me say this before but...) my '816 Forth runs two to three times as fast as my '02 Forth at a given clock speed. Obviously the exact ratio depends on what you're doing, as text operations for example will generally be 8-bit and not benefit as much as math and address operations which are usually 16-bit. The accumulator is kept in 16-bit mode almost full-time, and the index registers are kept in 8-bit mode almost full-time, with very few instances of REP and SEP (and when they are used, it's in macros to make them a lot more readable). When you want 8-bit operations, you can frequently use one of the index registers instead of A so you can avoid the two-instruction, four-byte, four-cycle round-trip switching overhead. Also, even with A, X, and Y set to 8-bit, the '816 offers more instructions and addressing modes, increasing capabilities and performance if you take advantage of them.
I'm probably stating the obvious; but within limits, probably whatever you're already proficient in. I say "within limits" because Most BASICs for example would probably not be able to do the job. Execution speed and memory efficiency are a much greater concern for the target than for the compiler and the computer (PC?) running it.
PostPosted: Sun Nov 27, 2016 11:31 pm
I maintain that such a approach will saddle you and your compiler with a feature that is of limited value but difficult to correctly implement. Going the route you are considering, you are looking at four major compilation targets: NMOS eight bit, CMOS eight bit, 65C816 eight bit emulation mode, and 65C816 16 bit native mode. There is also the 65C802, but that device is very rare and was never used in a production system—Garth Wilson is the only person I know who has one.
  • NMOS
    If the target is an NMOS part you also must consider the specific MPU and any deviations it may have relative to the archetype, which would be the MOS Technology 6502. For example, what if the target machine has a 6507, which is used in the Atari 2600 game console? This MPU can only address eight kilobytes and has no interrupt capabilities—IRQ and NMI aren't wired to any pins.
    Or, consider the Ricoh 2A03/2A07 used in the eight bit Nintendo game console. It's an almost-6502 with no BCD mode and a multitude of on-chip, memory-mapped I/O ports, forcing yet another memory footprint than with the real 6502 or the 6507 (see this article for 2A03/2A07 specifics).
    Then there is the 6512, found in some BBC products. Last, but certainly not least, are the CSG variations created for specific Commodore computers, such as the 6509 (B-128), 6510 (C-64) and 8502 (C-128), none of which precisely conform to the 6502 memory accessing ISA.
    So it wouldn't be enough to have a pragma that says "NMOS"—it would have to say "6502" or "2A03" or similar, and your compiler would have to know exactly what it can and can't do in the object code it generates. For example, if the pragma "2A03" is present your compiler would have to be careful to not use decimal mode in any operation.
  • CMOS
    The CMOS sphere is much simpler, as only the 65C02 has seen widespread use, as well as being in current production. Even there, the WDC 65C02, which is the CMOS archetype, is subtly different than the 65C02s second-sourced by Rockwell and others. However, your compiler could readily efface those differences if you are willing to restrict the object code to the least common denominator, which would be the Rockwell version.
  • 65C816 Emulation
    The 65C816's emulation mode, which is automatically enabled at power-up or reset, is mostly like a WDC 65C02, but with several important differences. For example, all of the $Fx opcodes are for the "long" addressing modes in the '816, but are the BBx instructions in the 65C02. Excepting STP and WAI, which exist in the WDC version of the 65C02, the $Bx opcodes are NOPs on the 65C02. The entire $3x set of opcodes are also NOPs on the 65C02 but are unique '816 instructions for stack relative addressing and other features.
    The overarching peculiarity of the '816 is that all opcodes are legitimate in either mode, but some will behave differently. My previous comment about MVN and MVP is one such case. These instruction will function in emulation mode, but are essentially useless, as they can only access zero page.
    More seriously is what may happen if you decided to treat the emulation mode as an eight bit version of native mode, as you are suggesting. For example, consider the following contrived code:
    002000   LDA #$41              ;uppercase A
    002002   JSL $04C000           ;make it lowercase
    002006   STA $003000           ;save it
    04C000   ORA #%01000000        ;maps UC to LC
    04C002   RTL                   ;should take us back to $002006
    JSL works the same in emulation mode as it does in native mode: the return address consists of three bytes, which would in this case be $00 $20 $05, going downward on the stack. I'll come back to this in a moment. For now, consider what will happen when an interrupt hits while the instruction at $04C000 is being executed. The '816 will finish the instruction and then take the interrupt. In native mode, the '816 would push PB (program bank), PC high (program counter) PC low and SR (status register), after which it would load $00 into PB and jump through the interrupt vector in the $00FFEx range. An RTI will reverse the process, which means whatever program bank was in context prior to the interrupt will be in context after the interrupt (note that DB is not automatically pushed or pulled—the ISR must do that if necessary).
    In emulation mode, PB will not be pushed during interrupt processing, nor pulled when RTI is executed, but will be forced to $00. Hence the above code will miserably fail because the RTL instruction will never be executed—PC will have been loaded with $C002 but PB will be loaded with $00, not $04 as it should be. The next "instruction" will come from $00C002, not $04C002.
    Getting back to the JSL instruction, it, as I noted, pushes three bytes for the return address. In emulation mode, if it so happens that SP (stack pointer) is $(01)01 when JSL is executed, the LSB of the return address will end up at $00FF, possibly stepping on something important. Complicating matters, SP will have wrapped and when RTL is executed, the '816 will not be able to access the return address LSB at $00FF, causing it to return to who-knows-where.
    You also mentioned use of the stack pointer relative addressing instructions in emulation mode. They do work, but not always as you might expect. In the above example, the stack pointer will have wrapped after executing JSL, which means stack pointer relative addressing will not work as you think it might. This is very unlike how it works in native mode, given that the 16 bit stack pointer has a lot of head room and is very unlikely to wrap, unless a program error sets it at or near $0000.
    I could give you some other examples of emulation mode peculiarities, but I think it's quite clear that emulation mode is so specialized in nature it really should be considered an entirely different processor—neither a 65C02 or a 65C816. I would not support it at all in your compiler.
  • 65C816 Native
    65C816 native mode is also very specialized in nature, as the native mode '816 has vastly more capability than any other 65xx processor. Fortunately, native mode operation is very logical in nature and none of the booby-traps present in emulation mode will get you. In fact, the enhanced instruction set makes the '816 well-suited for use with compiled languages, especially those that make heavy use of the stack for parameter passing (that would be C).
    There are some native mode '816 behaviors that may be quite useful, such as indexing beyond a bank boundary during a load or store operation, or what happens with an instruction such as LDA [$FF]. If you haven't already done so, reading the Eyes and Lichty programming manual should be your first priority so you fully understand the 65C816's characteristics and attributes. It is not an overgrown 6502, as some consider it to be.
One thing for sure, designing your new compiler will keep you busy. :D You are going to have a lot of different cases to consider.
PostPosted: Mon Nov 28, 2016 7:19 am
@BigDumbDinosaur, I had no idea how non-specific I was by using the term "NMOS 6502"! A general NMOS 6502 target should cover most use cases. I don't see anyone using a C compiler for Atari 2600 code, but 6507 support should be no problem—just a reduced address space. As for the 6510, the $00/$01 registers are indistinguishable from memory-mapped IO as far as I know, so there should be no problem there. The 8510's bank switching hardware may pose difficulty, but adding banking support is far down the road.
I don't see the compiler using decimal opcodes unless we added an extension for a decimal integer, so the 2A03/2A07 targets won't be much different at all. As for more exotic 65xx processors such as the 6509, I'm not convinced they're worth supporting.
I have a feeling that the NMOS 6502 should be the primary target at first, and then add 65C02's additional instructions. Paring a 'C02 backend down to work with the '02 seems more difficult than building a 'C02 backend on top of the '02. As for '816 support, that would be far down the road.
Probably the hardest part, aside from a well-working backend, would be supporting systems with banked memory like most game consoles. There are a myriad of bank switching schemes for many different consoles; there are over 200 mappers alone for the NES (though most of them aren't used for development anymore. I suspect a half-dozen at most would be the number we have to implement).
PostPosted: Mon Nov 28, 2016 4:02 pm
It seems to me that using bytecode would be a good way to hide the underlying CPU -- NMOS, 'C02, '816, whatever. You could start by using an NMOS routine to support each of the virtual instructions. After you've got that working you could, at your leisure, replace some or all of the NMOS routines with 'C02 or '816 upgrades that perform the same virtual instructions more efficiently. (I realize I'm probably glossing over some associated issues.) As for slowing down execution, even the NMOS chip has an indirect jump that can fairly quickly take you from a byte token to its associated routine. Self-modifying code is another alternative for a speedy, N-way dispatch.
PostPosted: Mon Nov 28, 2016 4:36 pm
Nice project idea! Don't forget the other 6502 communities: Acorn, Oric, VIC-20, PET, OSI! (Acorn is certainly large and active, not sure about the others. There are also homebrew 6502 fans - a C Compiler will suit some of them too.)
PostPosted: Mon Nov 28, 2016 5:16 pm
I like your approach to the problem. Once the bytecode backend works, we can start working on a native-code backend. As for if the native code is generated from the bytecode, I'm not sure. It's probably best to generate native code from 3-address code in SSA form. Take this bytecode for example:
    LOAD_ARG_B 1
    LOAD_ARG_B 2
    ADD_B
    LOAD_ARG_B 3
Assuming these are ~5 instructions each, internally, straight-up emitting the code from the interpreter will give you a sequence that's 20 instructions long, while my hand-optimized code is only 7:
    ldy #1
    lda (SP),Y
    clc
    iny
    adc (SP),Y
    iny
    sta (SP),Y
Of course, that's always been the case with the compiler/assembly dichotomy. But I have no reason to believe the second code can't be generated by an optimizing compiler. It's just not clear that the second code could be easily generated from the bytecode above.
Challenge: what's the most compact bytecode interpreter you can write with and without self-modifying code? Heres's one with self-modifying code that works even on the NMOS 6592. The opcode table is page-aligned with 128 entries:
next:
    lda $9999           ; (4)
    inc next+1          ; (5)
    bne @0              ; (3/2)
    inc next+2          ; ( /5)
    sta @0+1            ; (3)
@0: jmp (opcode_table)  ; (5)
Inside the zero page, that's 14 bytes, or just over 5% of the zero page, and 20 cycles (24 in a page crossing).
PostPosted: Mon Nov 28, 2016 9:03 pm
There's no reason to do this kind of optimization. Specifically, there's no reason to work on "intuiting" whether operations are 8 bit or not. If the coder wants to use 8 bit values, they can select the proper data types and use them. The trick is ensuring that the run time library has a full set of 8-bit support so as to not constantly be promoting 8-Bit to 16-bit bit values, and back again, and the compiler is perhaps more aware of 8 bit operations so it can do the right thing natively.
I don't think C has this concept of allow a function to have a static parameter area, maybe it does. Specifically it prevents the function from being re-entrant, since there's less of a call frame for the function.
Obviously UCSD Pascal chimes in here. Mind, UCSD's charm (beyond being the full kit OS it offered) was beyond the byte code, but notably, UCSD was particularly adroit is handling overlays, which is how they squeezed such a large system on to a small machine in the first place. Clearly, we have modern linkers and runtimes to handle things like overlay management (well I dunno if we do on the 6502 or not), but notably because the P-Code was inherently relocatable, it made such processes much simpler to implement.
Adding assembly based routines to UCSD was mostly straightforward, but mostly focused on driver work.
Then you have something like ACTION!, which was an Atari based high level Algol-esque language that ran quickly and compiled quickly. It didn't allow reentrant code, all of its parameter passing was done through static structures. But then you're no longer talking C, you're talking some other language.
PostPosted: Tue Nov 29, 2016 1:45 am
Standard C doesn't the allow static qualifier on parameters, but it would make a nice extension. It would make the function re-entrant, yes, but the speed increase would be worth it. In some cases, a function could be called with only a [b]JSR[/n]; locals are automatically saved, after all. Of course, the advantage isn't present unless every parameter is marked static. Maybe something like __staticcall to mark a function would be better?
Users browsing this forum: Google [Bot] and 12 guests
