Mike Kohn's naken_asm
Re: Mike Kohn's naken_asm
Finally sorted it out, now it uses zp, zpx, zpy for 0-255 but checks to make sure that an instruction is actually available for those modes. If not, then it assumes a 2-byte mode ensuring the passes line up.
So it should work as expected now. Thanks a lot for the suggestions.
I have re-written the 6502 assembler, and added a new one for the 65816. Traditional syntax is supported where possible, but there are some limitations. (The most glaring omission is lack of % for binary.)
A documentation project has been started (still working on '02/'816 docs):
https://github.com/mikeakohn/naken_asm/tree/master/docs
- BigDumbDinosaur
Are you working toward implementing binary notation?
- BigDumbDinosaur
- GARTHWILSON
- Forum Moderator
The assemblers I've used also allow the trailing "B" for "binary" or "H" for "hex," for example AND #10100101B or AND #A5H, just as they would accept AND #%10100101 or AND #$A5. Radix has to be set for decimal of course so the "B" does not get mistaken for a hex digit like it would if Radix were set to hex. A trailing "O" for "octal" might require more careful looking to avoid confusing it with a zero, but I have never had any reason to use octal. Ever.
I think it ignores whitespace (like a C compiler would). Probably not much I can do, but I thought I should mention the quirk.
You can do these currently (need to update docs):
0b11001100
11001100b
0x4444
4444h
$4444
- BigDumbDinosaur
...but I have never had any reason to use octal. Ever.
Supermon 816 accepts octal values, as well as binary, decimal and hex. For example, the operand @077 would be evaluated as octal.
I've added a disassembler for 65816, mainly because that module is needed for list file generation (-l option in the assembler). I'll also need it for the simulator display when I get around to that. In those roles, the number of storage bytes can be known, but for now 16-bit register sizes are assumed if used as a normal disassembler.
The WDC guidelines have aliases for some things, as well as one and two byte results for the byte selection operators > < and ^. I could support those things, but are they that important?
I don't think % for binary is going to work out, but otherwise I think all of the traditional syntax is implemented. Which never was mandatory for this project, but it would have been nice to have my cake and eat it too.
- barrym95838
joe7 wrote:
... The WDC guidelines have aliases for some things, as well as one and two byte results for the byte selection operators > < and ^. I could support those things, but are they that important?
Mike B.
I suppose, Mike, you're saying that a project with some non standard syntax or missing important features is good for the person who built the project, but probably not good for a general audience?
I won't be posting here anymore, but thanks for having me.
Goodness me, Joe7, don't do that! It's always better when we see encouragement here rather than the opposite, but do note that I could easily have misunderstood what Mike meant.
And consider, if just one interaction can push a person away from a whole community, how could any community possibly survive?
Is this a case where a message has gotten misinterpreted due the written medium's lack of cues from tone and body language? I suppose it's bound to happen from time to time. (Myself, I find nothing offensive about Ed's query, or about Mike's answer to the question that was posed).
- GARTHWILSON
- Forum Moderator
