Hi all,
I have done the BRK and RTI instructions. And now I can say implementing other instructions, is somewhat straightforward and I think it's going to be finished until to night. My processor has still no way to handle external interrupts.
Two questions :
- After BRK, should I push B and I flags on to the stack, because they are both 1 ?
BRK is not affected by the interrupt-disable bit; so "I" could be either 0 or 1 when BRK is encountered in the program and executed. The processor status gets pushed onto the stack. along with the 1 in the position of the B bit which does not physically exist in the status register. The I bit is set during the interrupt sequence; but that does not change the status byte that gets pushed.
- After RTI, should I pop B and I flags off the stack, because maybe they are turned off during interrupt handling ?
RTI restores the status that was pushed during the interrupt sequence. Again, there is no B bit in the processor status register. It's just a bit position that gets used when pushing the status. In the case of IRQ\ hardware interrupts, the I bit had to be clear when the interrupt hit, so normally the RTI would restore the I bit as 0; but you can change the status byte record on the stack in the ISR, before reaching the RTI. The way to do that is typically PLA, AND#/ORA#, PHA.
