Daryl's 6502 SBC help
Re: Daryl's 6502 SBC help
Quick note... I dont have the 6551 IRQ (pin 26) connected to the 6502.
Could that be an issue?
- GARTHWILSON
- Forum Moderator
The 51's IRQ line does not need to be connected if you don't operate it by interrupts, but usually you would, at least for receive.
$92 is STA (zp), in indirect addressing mode with no indexing. NMOS didn't have it.
Just out of curiosity... on the sbcOs rom file, I see $92 on address 7F0D
Is that an opcode? Just wondering what it does.
Hi Garth,
On SBC-2, $7F0x is un-decoded IO space, so anything there is random noise. If you are talking about the offset from $0 in the ROM file, that would point to $FF0D. $FF0D is in deed a $92. That routine is used to zero RAM. See below:
Hope that helps!
.ff00 78 sei Reset SEI ; diable interupts
.ff01 d8 cld CLD ; clear decimal mode
.ff02 a2 ff ldx #$ff LDX #$FF ;
.ff04 9a txs TXS ; init stack pointer
.ff05 a9 7f lda #$7f Zeromem lda #$7F ; top page of RAM
.ff07 85 01 sta $01 sta $01 ;
.ff09 a9 00 lda #$00 lda #$00 ; top of page & fill chr
.ff0b 85 00 sta $00 sta $00 ;
.ff0d 92 00 sta ($00) Zeromem1 sta ($00) ; loop will fill loc 0 of each page then
.ff0f c6 00 dec $00 dec $00 ; fill from ff->01 of that page
.ff11 d0 fa bne $ff0d bne zeromem1 ; then will drop one page and fill loc 0
.ff13 c6 01 dec $01 dec $01 ; doing that until page is back to FF
.ff15 10 f6 bpl $ff0d bpl Zeromem1 ;
.ff17 85 01 sta $01 sta $01 ; fix last byte from ff to 00Daryl
Darn, I just re-read's Garth's post. This OS was written for the 65C02. If you are using an NMOS 6502, it will not work right. Somewhere, I ported a copy for the 6502. Let me know if you need it.
I'm using a WDC 65c02, so I guess its no issue.
Sooooooo.... after some debugging I found out that EVERYTHING WORKS!
My only debugging tools are an arduino that can generate a slow clock or step clock using a button.
And some LEDs so I can monitor the address bus.
When I use the can oscillator it goes too fast and I cants tell if an LED is blinking or not.
So I used an arduino to generate a slow clock, but it's too slow
It takes quite a few ticks before the os goes to the 6551.
But after a a minute or so I can see that the 6551 is being accessed. the 138 pin 7 goes low!
So 6551 is being selected... crystal is generating a signal... not sure what could be the issue
I wonder if my ftdi breakout board is bad. I bought it from china on ebay.
ftdi ic seems legit, but who knows. When I connect to my computer I can see the ftdi Tx led light up when i type.
Next test: going to monitor the 6551 tx (pin 10)
Will it turn on/off at 19200 baud rate? Is that too fast for my arduino?
Thanks
Thanks
Since its first job is to zero RAM, I can see why it takes a while to get to the 6551 with a slow clock.
Easiest way to test the FTDI is to loop its TX to its RX and type in your PC terminal. you should get an echo. Remove the loop and typing should not echo. If that does not work, then the FTDI may be suspect.
If it works, then try putting just the FTDI RX on one of the 6551 tx/rx pins, reset, and watch. If nothing, switch the RX pin to the other 6551 pin and try again. The welcome message will be sent without needing to receive anything from the FTDI, so leave the FTDI TX pin floating.
After that, I'm not sure what to try, other some custom code to just interrogate the 6551. You could read a 6551 register and send it to a 6522 output port. Then write a different value to that register and read it again to see if its changing. the 6522 has two ports so the second read could go to the other port and then the program can just loop.
Thanks Daryl.
I tested the 7F7x (6551 pin 3) and it's been set low 16 times.
I checked the Tx pin but nothing.
Will try reading the 6551 register and output on the 6522 and test if my 6551 is not working properly.
I hope my 6551 is not dead!
Thanks
Thanks
- GARTHWILSON
- Forum Moderator
You could also put LEDs with 470 or 1000-ohm resistors on RTS\ and DTR\ and write to the command register to make those outputs high or low for an indication of whether you're communicating with the ACIA. My workbench computer has three ACIAs, but two of them were for purposes I wasn't going to use much and might never use again, and I put four annunciator LEDs on the front that are fed off the RTS\ and DTR\ outputs of these two. I wrote Forth words to turn them on and off. A usage example is:
TURN ON #3 LEDhttp://WilsonMinesCo.com/ lots of 6502 resources
I did a simple program that sets the value $AA on $7f70, $7f71, $7f72 and $7f73.
Then I read these registers and used the 6522 to output them, here's what I got:
$7f70 -> #11111000
$7f71 -> #00001000
$7f72 -> $AA
$7f73 -> $AA
So I guess that means the control and command registers are working.
As for the TxRxdata and status registers, not sure why I got these values, but looks like I can read them. And they are consistent.
Im gonna try a simple program to test more. I was looking at Jeff's post http://jefftranter.blogspot.com/2012/03/6551-acia.html
Trying to understand how the 6551 works so I can write the simples test program.
Hi Garth, will try that too! That sounds like a simpler test, so I think I'll do that one first. Thanks!
$7f70 -> #11111000
$7f71 -> #00001000
$7f72 -> $AA
$7f73 -> $AA
I checked both RTS\ and DTR\ and I can get them to turn on/off
Sounds like 6551 is ok
Will burn sbcOs again on my eeprom and test it again.
Just double checking if that's correct for a 6551 to ftdi connection:
6551 has /CTS, /DCD, /DSR connected to ground while RXC, /DTR and /RTS no connected at all
ftdi has DTR, CTS not connected
6551 tx(pin 10) goes to ftdi rx, and ftdi tx goes to 6551 rx (pin 12)
Thanks for all the help!
Cant wait to have serial working
- GARTHWILSON
- Forum Moderator
$7f70 -> #11111000
$7f71 -> #00001000
$7f72 -> $AA
$7f73 -> $AA
$7f70 -> #11111000
$7f71 -> #00001000
$7f72 -> $AA
$7f73 -> $AA
Let me suggest we all use capital letters A-F in hex numbers, like in your "$AA". The lower-case "f" (as in "$7f73")on my monitor looks almost like a "1".
Sorry Garth, will keep capital for Hex
So I copied Jeff's test code to my eeprom : http://jefftranter.blogspot.com/2012/03/6551-acia.html
I can now see the Tx blink once (maybe twice, but is so fast i cant see)! Code outputs "OK" then echoes whatever the pc sends
I can also see the ftdi Tx blink so I got data from both ways
Im using hyperterminal with connection at 19200, data bits 8, no parity and 1 stop bits
Will keep testing more. Im getting closer!
Thanks
Thanks
Quick question:
Does the 6551 crystal has to output a perfect 1.8432 Mhz signal?
I noticed on my oscilloscope that its value fuctuates a bit between 1.83 and 1.85.
I have a 22pf capacitor and 1Mohm resistor.
Would that cause an issue?
I did quite a few tests over the weekend and can confirm that the 6551 works fine.
I'm buying an FTDI breakout board from sparkfun to make sure mine is not bad.
I did notice that if I dont connect the FTDI board's 5v pin to my SBC's 5v I can see the Rx (or 6551 Tx) led light up.
But if I connect the pin then it stops.
Thanks
Thanks
- GARTHWILSON
- Forum Moderator
If the 'scope has a counter on it, it sounds like you're saying it only has two and a half digits, and if the counting period is short, there may be some vacillation in the least-significant digit. If the error in the actual frequency is under 2% you should be fine. I expect a good counter would find it to be within whatever the accuracy of the crystal is specified to be. Even the cheap ones are something like .01%.
Good point Garth! I believe is just my scope that doesn't have more precision.
So I wrote a small code that should output the value $AA on the 6551 constantly.
For test I have the ACIA status registers being output on a VIA so I can monitor with my aduino.
Here's the code:
* = $8000
ACIA_DATA = $7F70
ACIA_STAT = $7F71
ACIA_COMM = $7F72
ACIA_CTRL = $7F73
VIA1 = $7F50
VIA2 = $7F51
lda #$FF
sta $7F52
sta $7F53
sta VIA1
sta VIA2
lda #%00001011
sta ACIA_COMM
sta VIA1
lda #%00011111
sta ACIA_CTRL
sta VIA2
TX
lda ACIA_STAT
sta VIA1
and #$10
beq TX
lda #$AA
sta ACIA_DATA
sta VIA2
jmp TX
After I store the value $AA on the ACIA data bus ($7F70) the status register always gives $00
Seems like the Transmitter data register is not being emptied (set to 1)
If the ACIA (or in this case the FTDI chip) is not connected to my computer, does it mean that the transmitter register will never get emptied?
In simpler (noob) words: does the ACIA clears this register itself, or do you need the machine on the other side of the connection to set this value?
I connected the ftdi USB to my computer at 19200 with the hopes of seeing $AA constantly, but nothing happens.
Thanks for the help!
Here's the code:
* = $8000
ACIA_DATA = $7F70
ACIA_STAT = $7F71
ACIA_COMM = $7F72
ACIA_CTRL = $7F73
VIA1 = $7F50
VIA2 = $7F51
lda #$FF
sta $7F52
sta $7F53
sta VIA1
sta VIA2
lda #%00001011
sta ACIA_COMM
sta VIA1
lda #%00011111
sta ACIA_CTRL
sta VIA2
TX
lda ACIA_STAT
sta VIA1
and #$10
beq TX
lda #$AA
sta ACIA_DATA
sta VIA2
jmp TX
