Just finished a write up... my clock is finally up and running. No cheating with PICs, all 6502 here!
http://www.hack.net/nixie
Thanks for the help with my questions here guys, I ended up going with the 6522 per your suggestions!
-Ryan Brooks
6502 powered Nixie clock write-up
- Mike Naberezny
- Site Admin
Re: 6502 powered Nixie clock write-up
Mike
A workmate of mine showed me a battery driving one transistor and one coil (and a few other discretes) driving a nixie digit.
It was very low current, and you could touch the electrodes without feeling anything.
IIRC, the digits needed a high-ish voltage to strike but a lower voltage would then keep the digit glowing.
Certainly safer than driving them from the mains.
Shift to the left,
Shift to the right,
Mask in, Mask Out,
BYTE! BYTE! BYTE!
Shift to the right,
Mask in, Mask Out,
BYTE! BYTE! BYTE!
- GARTHWILSON
- Forum Moderator
High frequency high voltage sources are painless to touch - the current travels over the surface of the skin and does not penetrate to the nerves. This does not mean it is safe - the current is painlessly cooking you as it passes through your body!
The 1x4" piece of wood in one hand was lit on fire by the sparks a couple of feet long coming out of it. He purposely holds it so the top of it above his head, so that after 30 years of doing this, he still has more hair than I.
http://www.wondersofscience.org/sfs/MILLION.HTM
From when I was working with AM broadcast transmitters in the early 1980's however, I do remember what it feels like to touch a non-grounded cable or wire that's right next to an antenna tower putting out anywhere from 5,000 to 50,000 watts at a little under a MHz.
