What goes on in PCs' video cards, sound cards, and graphics engines to take a big burden off the main processor?
This is much too open-ended a question to answer here, even succinctly.
Samuel has occasionally touched on how GEOS (software) on the Commodore 64 computed the video for various fonts and sizes,
I did?? Where?
I sometimes wonder how much of that work of figuring out what value to give each dot is done by the main processor and how much by the video chipset.
With today's clock speeds, it doesn't really matter. However, in most cases, it's almost always done in the video chipset, and rarely in the CPU.
When scrolling a window, for example, the software will call a graphics procedure to "blit" (
BLock
Transfer) a submatrix of pixels from one location to another. This task is performed by the GPU or some comparable coprocessor.
If you have transparency effects, then this won't work -- in this case, you need to compose the image from primitive images, just as a graphics artist would create a composite image. You start by blitting the background image, then you blit all foreground images, one on top of the other, until every layer is displayed. 3D hardware acceleration takes most of this logic off of the CPU's hands -- the CPU still has to tell the GPU which images to render and where, however.
I don't even know if there's still a separate floating-point co-processor in the same package with the main processor (not that the video calculations use FP very often)
The 80487SX was Intel's last discrete FPU. From the 80486DX onwards, all FPUs have been fully integrated onto the die of the CPU.
As far as floating point calculations for video, in fact, yes, it's used all the time. All OpenGL procedures accept floating point coordinates and transformation matrices. Many procedures dealing with outline fonts also use floating point coordinate systems because of the possibility for anti-aliasing and subpixel rendering.
For the streaming audio and video, I have no doubt that the audio and video chipsets do a lot of buffering, maybe even several seconds' worth
Most audio chipsets I'm familiar with buffers about half a second's worth of audio. Hardware-accelerated MPEG decoders
do not buffer -- they decode and render video frames in real time.
and I suspect these may even access the sets of samples by DMA; but the control of the timing is atrocious, as witnessed by the fact that the audio may lead or lag the video by a tenth of a second or even more, which is totally unacceptable for my kind of work, to put it mildly.
I simply must take exception to this -- you are ascribing to the hardware what is clearly a fault of the encoder software.
Unsynchronized audio and video during playback can come from one of two sources
only -- either the video and audio fail to synchronize in the video file itself (meaning the problem lies with encoder), or the problem lies with the player itself.
The hardware
very clearly cannot be problem, for
nobody has ever complained of synchronization issues when playing video games. And, believe me, since all the GPU and DSP functionality in video cards are
market driven by the requirements in video games these days, clearly video games place a
much larger stress on the video and audio interfaces than simply isochronously blasting a bitmap and simple PCM stream to the audio card is.
This is obviously a common problem as we frequently see it even on TV, from major stations that can afford all the processing power they could want.
Again, let me re-iterate -- this has ZILCH to do with CPU power, nor with DMA performance, nor with buffering, nor with the DSPs or other hardware on video or audio cards.
ANY AND ALL synchronization issues is always a software problem.
So what can the home computer builder apply from all this in order to improve performance without losing control of timing?
I'm not sure what your question is asking.
