It is currently Sat Nov 23, 2024 7:40 pm
Post new topic Reply to topic  [ 26 posts ]  Go to page Previous  1, 2
 Post subject: Re: 6502 Assembler
PostPosted: Fri Apr 08, 2016 3:32 pm
I've never used Cross-32 so I can't comment on how good it is. But I have to admit I got a little chuckle when I read this on their site:
35,000 lines/min of 68HC05 source code on a 75 MHz Pentium
Funny part is, I'm actually trying to get together a low-end DOS machine (386/486) to play some DOS games.
PostPosted: Sat Apr 09, 2016 12:47 am
It would certainly be better to use a tool which the NES community use, if your objective is to write NES code.
cool, ill do that thanks man
iv'e downloaded the demo for it but I'm going to try and find a good free assembler and in the event I cant I'll get that but its looking like the free ones could be just as good from what I've read its just finding one and getting it setup lol
PostPosted: Sat Apr 09, 2016 7:57 am
I use 64tass and I'm quite happy with it. It's free and the documentation is good.
PostPosted: Sat Apr 09, 2016 4:25 pm
Is this nes specific? ive managed to get a couple of assemblers open in the command prompt etc. but how do I know if its nes specific or setup properly?
PostPosted: Sat Apr 09, 2016 5:43 pm
What is an "nes (sic) specific" assembler? Traditionally, assemblers are "specific" to the microprocessor for which they assemble code. The machine architecture itself is not a part of the assembly language, as the MPU could be used in widely varying architectures, as was the case with the 65xx family.
The Nintendo Entertainment System is built around the Ricoh RP2A03 or RP2A07 processor, both of which are fundamentally a 6502 without the BCD instructions. Any 6502 assembler is usable with the RP2A03/7, as long as the CLD and SED instructions are not used in the source code. You can add your own source code references to the memory mapped I/O registers and other NES architectural features and Voila! you have an "NES specific" assembler.
PostPosted: Sat Apr 09, 2016 6:23 pm
(I believe I read that Nintendo cartridges do use CLD at reset time - perhaps for safety, perhaps to help on some development environment.)
I think the point here is that a console is a platform, not just a micro, so a NES-specific tool will know how to build a correct cartridge image, and might well know things about the video, the audio, the game controllers and so on. It's not that any old assembler won't work, but it would put more burden on the person doing the programming.
PostPosted: Sun Apr 10, 2016 4:31 pm
okay so Ive decided Im going to stick with ca65 for now, but when I open the cmd prompt and type in ca65 or cc65 it literally just says no input files. Im assuming that means its found it but somethings missing? lost here lol
PostPosted: Sun Apr 10, 2016 4:37 pm
These are command line programs, not interactive environments. When you invoke the tool, you tell it what you want it to do, and how. I think there's a guide somewhere, but meantime see
viewtopic.php?f=2&t=2455
PostPosted: Mon Apr 11, 2016 1:57 pm
Okay got that managed to get ASM6 and NESASM open in the command prompt by changing the path directory in the environment variables but not ca65. I dont know what Im doing wrong but apparently it is a bit of a nightmare to set up (so Ive read). you also said in that link you shared you can use any convenient text editor, do you mean like notepad++? if so how do i set that up? and do you code in notepad then copy/assemble in ca65 for example?
thanks
PostPosted: Mon Apr 11, 2016 5:57 pm
Yes, Notepad++ is a popular choice. You edit a file - let's say hello.a65 - in your editor, save it, then run something like
ca65 -l hello.a65
cl65 hello.o --target none --start-addr 0x0600 -o hello.bin
and that will write a file called - in this case - hello.bin and you then find a way to load that bin file into your emulator of choice.
PostPosted: Tue Apr 12, 2016 11:00 pm
Okay I'll try that out, cheers mate
Users browsing this forum: No registered users and 47 guests
