Programming 6530
Programming 6530
How can I program the ROM of a MOS 6530?
Sam
"OK, let's see, A0 on the 6502 goes to the ROM. Now where was that reset vector?"
I downloaded the 6530 datasheet from the 6502 datasheet archive. As I thought, the ROM is mask programmed. That means it was programmed during manufacturing and cannot be reprogrammed. There are a few other options that were mask programmed also. You might want to look over the datasheet for all of the specifics. Here is the link:
http://www.6502.org/documents/datasheet ... 0_riot.pdf
hope this helps!
hope this helps!
Re: Programming 6530
___
/ __|__
/ / |_/ Groetjes, Ruud
\ \__|_\
\___| URL: www.baltissen.org
