In theory, like, following the manual and the schematic (http://www.westerndesigncenter.com/wdc/ ... 265SXB.pdf), clearing bit 3 of the Chips Select enable register (CS3B, pin 73) at 00:DF27 should enable the external 32k SRAM chip that is on the 265SXB and turn on the the little LED. In other words, because that RAM is enabled out of the box, that bit should already be clear and the LED on.
However, the monitor gives me a $FB (%1111 1011) at this address (bit 2 are the on-chip registers and whatnot, which is perfectly correct). In fact, when I clear CS3B by changing 00:DF27 to $F3, it seems to disable the 32k RAM. This would be the exact reverse of the documented behavior. No LED then, either.
Or am I missing something?
Are you taking into account that the chip select lines are 'active low' e.g. a low output selects an address range.
Also if you turn a chip select off then you should ensure that the corresponding data register bit for the pin becomes a high output on the SXB board otherwise a memory chip could think it is always active.
