Win32/64 6502 Disassmebler
banedon
Post by banedon »
Hi guys
Does anyone know of a decent Win32/64 6502 disassembler? I.e. one that they've used and can recommend?
I've found a few already, but they're either web based or Win16 or Linux/Unit.
Any recommendations?
[edit]
I've found this one: http://sourceforge.net/projects/dis6502/
Seems ok, but will have a play. Recommendations still welcome, though :).
Re: Win32/64 6502 Disassmebler
You might try Ruud's disassembler:
http://www.baltissen.org/htm/auto_dis.htm
I use the very basic facility in Ian Piumarta's lib6502: can dump a disassembly of memory and then get to work in a text editor.
banedon
Post by banedon »
Thanks for the recommendation, Ed. Unfortunately, it won't run under windows 7 x64 (it's a 16 bit DOS app). However, I do like the idea of his data auto detection routine that he mentions on the main page.
Oops!
magicaros
Post by magicaros »
for running 16bit dos app under Win7/8 64bit or whatever else there is DOSbox
HansO
Post by HansO »
Turbo Pascal source is included, so perhaps Freepascal will compile it. Or run it in a VM or MS- DOS emulator
See if there's one in the list on my links page at http://wilsonminesco.com/links.html#assem that suits you. One or two of the links there are to other pages with further long lists of 65xx assemblers.
White Flame
Post by White Flame »
I've got one here that's quite powerful: http://www.white-flame.com/wfdis/ It requires HTML5 & Javascript enabled, but will run anywhere that runs. You can even download & run a local copy; it's not technically "web based", as it runs completely in local javascript.
It's currently Commodore 64 specific, but if you have a binary, prepending the 2-byte load address to the file will make it work as a "prg" file.
Features:
  • Tracing 6502 disassembler
  • CBM BASIC detokenization, finding SYS addresses and disassembling from there
  • Very slow emulator for running relocation or decompression code, allowing you to disassemble further from that
  • Understands .prg and .sid formats, as well as .d64 images containing them
  • Edit formatting (indentation, blank lines), and comments
  • Create or rename labels
  • Built-in C64 ROM & I/O labels
  • View areas as some C64 graphics types
This is technically just the front-end to my AI-driven disassembler back end, but I am also keeping it fully runnable client-side with just the rudimentary tracing disassembler.
Big caveat: no saving/export yet. Saving & loading the disassembler state does work, but there's no UI hook for it yet. Still, you can explore the workings of a file, and copy/paste out if you're desparate. :)
Small caveats: No "illegal" opcodes yet. Manually switching things from gfx back to binary sometimes doesn't register quite right.
To get more features in, just bug me.
Re: Win32/64 6502 Disassembler
A timely post from Peter Fröhlich mentions a resurrection of "a flow-tracing 6502 disassembler first published in 1986 by Robert Bond" - it's a work in progress.
The project page has a link to Eric Smith's dis6502 page (including the original dis6502 sources)
Note that this is a command-line program and needs lex and yacc to build it - probably OK using cygwin or similar on Windows, but it's not a GUI program as was originally sought. Might be interesting anyway.
There's a mention of the impressive-looking open source 'radare' reverse engineering tool, and at least one simple command line disassembler, over in this thread.
White Flame
Note that radare actually is an interactive disassembler, as the main part of its tool. I had to search to try to find how to do a simple commandline disassembly dump of a file, for that particular thread. :)
I'm glad you did search - for someone who prefers command line, it's essential to know that a GUI-looking tool also supports the command line.
