It is currently Sat Nov 23, 2024 12:55 am
PostPosted: Sat Mar 05, 2016 4:41 pm
In one of my classes we have been learning how to program in assembly language using the 6502 microprocessor. The program is supposed to print "You entered a one." if the user enters a 1, "You entered a two." if the user enters a 2, and "You entered a three." and the program should exit if you enter a 4. I have written the program to do this. The problem arise when I go to run the automatic grading code. The grading code not only inputs the numbers 1-3 but it also attaches an "enter" along with the each number. I have tried to fix this but everything I have done does not work. Also thank you for any help.
PostPosted: Sat Mar 05, 2016 6:03 pm
Welcome, VetteGuy777. How is your program supposed to input a keystroke? Does it read an I/O port, for example, or call a subroutine supplied for this purpose? And, similarly, how is it supposed to output the characters to be printed?
If you show us the program you've written so far then it'll help answer some questions. Right now we don't have enough to go on.
cheers,
PostPosted: Sat Mar 05, 2016 6:22 pm
The program uses subroutines to both accept input and print messages.
OutChar: equ E003h
GetChar: equ E006h
GetCharW: equ E009h
PrntMess: equ E00Ch
OutSpace: equ E00Fh
OutHex: equ E012h
DgtToBin: equ E015h
GetLine: equ E018h
org 0200h
Main:
jsr GetCharW
jsr DgtToBin
sta num
jsr GetCharW
Compare:
ldx num
cpx #1d
beq Message1
cpx #2d
beq Message2
cpx #3d
beq Message3
cpx #4d
beq EndOfProgram
Message1:
ldx #Mess1<
ldy #Mess1>
jsr PrntMess
jmp EndOfProgram
Message2:
ldx #Mess2<
ldy #Mess2>
jsr PrntMess
jmp EndOfProgram
Message3:
ldx #Mess3<
ldy #Mess3>
jsr PrntMess
EndOfProgram:
brk
Mess1: dbt 0ah,0dh
dbt "You entered a one."
dbt 0d
Mess2: dbt 0ah,0dh
dbt "You entered a two."
dbt 0d
Mess3: dbt 0ah,0dh
dbt "You entered a three."
dbt 0d
num: dbt 0d
end
I would also like to point out that we use an emulator for this class. Also everything after a colon should be spaced away from the left edge.
PostPosted: Sat Mar 05, 2016 6:52 pm
There are some issues, but I'm not gonna point them all out. I'm short of time this afternoon, and anyway it's better to give clues rather than actual answers.
cpx #1d
beq Message1
Does your program branch -- or not -- as you expect it to here? Try single-stepping to find out if the branch occurs. Keep in mind the two values being compared. What is 1d? What is the other value? Do they match? Should they?
BTW I notice there are two similarly-named subroutines. What's the difference between GetChar and GetCharW ? And, did you intend to call GetCharW twice?
GetCharW: equ E009h
What does the "h" signify? Would it make a difference if it were omitted?
You can bracket your program with the code and /code tags so it'll appear on the forum in monospace font, which most people find easier to read. Use square brackets around the tags.
PostPosted: Sat Mar 05, 2016 8:15 pm
The "h" I believe has to do with the emulator to distinguish between hexadecimal, decimal, and binary so it does matter. The branches work and the difference between GetChar and GetCharW is that the second one waits for input from the serial port and the other does not and yes I was trying to solve the problem by calling GetCharW twice.
PostPosted: Sat Mar 05, 2016 9:00 pm
And a "d" suffix indicates decimal? My bad! :oops: My Forth assembler doesn't use that convention, and I mistook your intent. To me, "1d" (for example) looks like a hex number. I thought you meant 1dh but had forgotten to append the "h".
So the extra GetCharW is to get rid of the "enter"? Probably "enter" is actually two characters -- 0Ah and 0Dh (carriage-return and line-feed; I forget which is which). Maybe you need two extra calls, not one.
Just checking: you're saying the program works alright when you enter keypresses manually, but fails when you run it with run the automatic grading?
PostPosted: Sat Mar 05, 2016 9:14 pm
The program does work when I run it manually but the automatic grading uses this ("send", "1" ~ UnicodeToString(13)) but my program does not know what to do with the "enter" I will try and see if your suggestion works.
What would you do with any other stray input?
PostPosted: Mon Mar 07, 2016 2:48 pm
Good question. In general, how does any program you write react to unexpected input?
As written, your program expects to see only four specific input values and has no provision for what to do if the input is not one of those four. It is a very brittle design, IMHO.
Although it is a nuisance that idiot users will not always do the correct thing, you'll have to find a way for your programs to deal with it. In this particular case it might be a good idea to check that the input is one of the four digits you want to react to even before you convert them by calling DigToBin (ie., check their ASCII values, or whatever other encoding convention you are using). If it is not one of them, ignore it and loop around to the start, or print a message to the effect of "unrecognized" and then loop around to start.
'Cause if I was your instructor, I'd throw a "5" into the input just to see what your program would do. I'm mean that way.
PostPosted: Mon Mar 07, 2016 4:19 pm
You guys are going to play the "undefined-behavior" card this soon? Well, maybe the task has been more thoroughly defined than we have yet seen, but I would try to get a fragile version working first (to avoid a failing grade). Then a more robust version would follow, if I wasn't backed against the wall time-wise (yeah, right).
Here, there be "Nasal Demons":
http://www.complang.tuwien.ac.at/kps201 ... ion_29.pdf
(page 2, footnote 1)
Mike B.
PostPosted: Mon Mar 07, 2016 4:36 pm
I wasn't so much thinking about undefined behaviour, although it kind of amounts to the same thing. More that the best way to understand what a program is doing is to step through it mentally carefully thinking what happens at each step. In this case, combine what Jeff is saying about how the extra end-of-line characters might appear to the program with thinking about what happens with this branch:
cpx #4d
beq EndOfProgram
It might be that the problem here is in the challeng of thinking about input character by character, which is how the program necessarily is going to work. It might be that the programmer is thinking line by line, or entry by entry, instead of byte by byte.
Oh, and of course: Welcome VetteGuy777!
PostPosted: Mon Mar 07, 2016 4:43 pm
I just made it so it will only accept the input of the numbers 1-4. I do not think this is possible but is there a way to retrieve a previous number or something from the A register right after you placed something else in it.
PostPosted: Mon Mar 07, 2016 6:54 pm
PHA and PLA are your friends here; you just need to practice how and when to use them.
Mike B.
PostPosted: Mon Mar 07, 2016 6:58 pm
There's a very neat diagram which might be useful: see
viewtopic.php?p=42766#p42766
It might be that you haven't yet ventured into using memory or zero page to store data, VetteGuy77 - if so that's something to think about.
PostPosted: Mon Mar 07, 2016 9:23 pm
I think I have found out why it is not working but how to fix it is still beyond me. When the automatic grader inputs the test numbers it not only enters the number but it enters the code for "enter" aka carriage return. My program automatically starts to do stuff with the input before an enter command can be given but since it is computerized I believe the test number and enter are being strung together. Thus it does not work. My professor, I think, told me to make it either use or ignore the enter. So does anybody have any ideas.
Users browsing this forum: Google [Bot] and 15 guests
