Development Tools Survey
I'm a Windows 10 user, but all of my programming (work and play) I do on Linux. At work I use Linux x86 development machines for MIPS32 firmware work (with simulators when needed) and at home I run a Linux virtual machine under VMWARE Player on Windows.
Tools wise, I use vi and make to build. When tinkering with 6502 I'll use ca65 (from the cc65 suite) to assemble, with a pieced together 6502 emulator taken from the MAME distribution (http://www.mamedev.org). I use ca65 just because it was there and I needed something trivial. I might use atasm or similar if I wanted to write something significant.
Some questions for active 65xx developers:
What operating system do you develop on? Any particular reason for the choice?
What's your edit/assemble environment (e.g. IDE+F5, vi+make, other)?
What assembler do you use? Have you tried others? Why/how did you make your choice?
Do you use an emulator? If so, which one? Does it include device models?
Are there 65xx software tools that you wish you had that as yet haven't existed?
Re: Development Tools Survey
Hi,
Linux (Ubuntu). The Unix stuff is handy and it's actually easier to cross-compile a Windows binary from Linux anyway.
VIM and Make.
I wrote the 6502 and 65816 modules for naken_asm, so I use that. I prefer a newer syntax style (0xBEEF vs $BEEF), but I'm almost done supporting the older syntax also.
I currently use SXB boards to test routines against the real hardware, which is even easier than using an emulator. They are expensive, though.
joe7 wrote:
[SXB boards] are expensive, though.
Yeah, I have the '265 and '134 boards. It's nice to have both the 6502 and 65816 in hardware form. I'm more of an analog electronics and software guy, so the cheaper microcontroller boards are plenty enough for me. Still trying to come up with a good project, maybe a music synth or something.
All good questions, by the way.
I use C64ASM.EXE to assemble my 6502 code. This is a DOS program which I run in DOSBOX on my Linux system. A MAKE.BAT file makes it easy to do the necessary assembling without having to remember the switches each time.
For small editing purposes, I will use MSDOS's EDIT program or another DOS program like VI or VDE. For larger jobs I will use a Linux based editor like leafpad or geany.
I also use VICE as my emulator of choice when running my programs.
- BitWise
- In Memoriam
I use either my own 'Dev65' cross platform (Java based) assembler or the WDC tools with a Makefile and some batch files under Windows (XP, Vista and 7)
Andrew Jacobs
I mostly use emacs, make and cc65, usually on Linux and sometimes on OS X. For specific projects, I'll use the appropriate assembler: Dev65, HXA, AS65 and so on. I also use the assembler inside easy6502. For emulation, I'll use easy6502, visual6502, jsBeeb, lib6502 or others depending on what I'm trying to do. I do have a BBC Master hooked up with a serial cable for when I want to run on hardware, and a BBC nearby similarly.
Windows 8 and 10 are making me think about braving the driver issue again.
- BigDumbDinosaur
Thanks for the responses.
OSes: DOSBox(Linux), Linux, MacOSX, Windows XP, Windows 7, Windows 10
Editors: edit, emacs, feany, leafpad, Notepad++, pspad, vim
Build: make
Assemblers: 64tass, as65, c64asm, ca65, dev65, Kowalski, naken_asm, xa,
Emulators: custom, Kowalski,none, VICE
Tools are a very personal choice, so it's no surprise there's a wide selection, although I expected there to be a front-runner for the assembler. Perhaps within cliques (e.g. Atari programmers vs. C64 programmers) there are more preferred tools, but this group appears diverse. VICE was mentioned 3 times, so gets a special mention.
For those of you who bypass emulation and go straight to target, how do you load the code onto the target?
Build: make
The assembler that I wrote for my Forth system if far more powerful and I may switch to using that permanently once my Forth is completed.
- GARTHWILSON
- Forum Moderator
OS: DOS, LInux. I can develop with my handheld HP computers from the 1980's also, but it's not very practical.
Assemblers: Used 2500AD (now distributed by Avocet Systems) 65(c)02 assembler from '86 to '93, then C32 (Cross-32) from Universal Cross Assemblers in Canada (now distributed by Data Sync Engineering) [edit: I can't find anyone distributing it anymore). The latter is able to assemble for dozens of processors, including for the 65(c)02 and '816. Both are great macro assemblers. For PICs, I use MPASM. For the workbench computer, my own Forth kernel with onboard assembler.
At the moment, I'm trying to get a Displaytech graphic LCD going, and it has been rough, as Displaytech's documentation seems to be a mess and their website is not helpful. They have a forum to ask your questions, but most questions go unanswered, or their answer just refers you to a particular data sheet, and the sheet obviously does not match my display even though the model number is exactly the same. [Edit, several months later: I got it going. I had one bit wrong in one of the LCD's set-up instructions. Here's a few seconds of demo video done for experiment purposes, using a random number generator to produce sets of 25 random segments then displaying the screen memory: http://wilsonminesco.com/6502primer/Dis ... 8Ademo.mp4 ] There's no problem sending it commands with the workbench computer, and writing the code to do what I want is a trivial time-taker in my system. What I'm lacking is an understanding of what the code needs to do to get the results I want. How would a simulator or even an emulator help with that? It wouldn't. But that's my life as far as the little computers go. It's about interfacing to hardware, sometimes to make sure I correctly understand how to interface to a new IC to use in a product (or in this case, a graphic LCD). It is trivial to try things in Forth, on the actual hardware. Once I have a collection of routines working for it, I can translate it to PIC assembly or other language where development would have been much slower if I hadn't first been able to use the workbench computer with Forth.
- If for (E)EPROM, I use the Needham's PB-10 programmer that's plugged into a slot in the PC.
- For PICs, I send the Intel Hex file to the 65c02 workbench computer which controls my home-made PIC programmer.
- If it's something to run on the workbench computer itself, I just mark a block in the source code in the text editor on the PC and "print" the block on the RS-232 port as if to a serial line printer. The PC thinks it's just printing; but the workbench computer takes that text and compiles, assembles, or interprets on the fly, as appropriate. For short additions, turn-around time is virtually instant, from writing a piece of code to adding it to the system on the workbench to actually watching it run. In the Forth system, it is not necessary to re-compile the whole application, only the little piece you're working on. If I crash it, the reset routine gives me the option to start new, or to pick up where I left off instead of having to re-compile everything (since most crashes just get stuck in a loop with no way out and they're not writing trash all over the dictionary), or do the latter and even run a specified routine again to set things up and get a process going again. This way, a crash may cost less than five seconds' time. I've even changed interrupt-service routines between timer interrupts, without pausing interrupts that are hitting at tens of thousands of times per second. How do you do that? By assembling the new one, then watching for when the interrupt was just processed, then when you know you have enough time before the next one, quickly swap out the vector, so the next interrupt gets serviced by the new routine. It's instant, without a simulator, emulator, debugger, etc.. The few times I've shown people, they've had a hard time believing there wasn't a TSR or some other hidden software on the PC.
