Doing it differently in a single loop, I ended up being able to reuse a core routine that updates source, target and length pointers commonly used to move memory (non-overlapping), fill memory and compare memory. I can use the new routines for the monitor functions which fill memory, compare memory, write to the EEPROM insitu (basically a move/compare) and half of the memory move function. Here's some snippets of the core code:
USERFILL TAX ;Save fill byte
FILL_LP LDA LENL ;Get length low byte
ORA LENH ;OR in length high byte
BEQ DONEFILL ;Exit if zero
TXA ;Get fill byte
STA (TGTL) ;Store in target location
JSR UPD_TL ;Update Target/Length pointers
BRA FILL_LP ;Loop back until done
DONEFILL RTS ;Return to callerCode: Select all
;Move memory block first byte to last byte, no overwrite condition, do the move
MVNO_LP LDA LENL ;Get length low byte
BEQ QUITMV ;Exit if zero bytes to move
LDA (SRCL) ;Load source data
STA (TGTL) ;Store as target data
JSR UPD_STL ;Update Source/Target/Length variables
BRA MVNO_LP ;Branch back until length is zero
;Code: Select all
COMPLP LDA LENL ;Get low byte of length
ORA LENH ;OR in High byte of length
BEQ QUITMV ;If zero, nothing to write
LDA (SRCL) ;Get the source data
CMP (TGTL) ;Compare to target data
BEQ CMP_OK ;If equal, continue compare
JSR COMPERR ;Print failed compare address
CMP_OK JSR UPD_STL ;Update Source/Target/Length variables
BRA COMPLP ;Branch back until done
QUITMV RTS ;Return to caller
COMPERR JSR SPC2 ;Send 2 spaces
JSR DOLLAR ;Print $ sign
LDA TGTH ;Get high byte of address
LDY TGTL ;Get Low byte of address
JSR PRWORD ;Print word
JMP SPC ;Add 1 space for formatting and returnCode: Select all
PROG_LP LDA LENL ;Get low byte of length
BEQ QUITPRG ;If zero, nothing to write
JSR BURN_BYTE ;Write a byte to EEPROM
BEQ PRG_OK ;If equal, continue writing
LDA #$FF ;Get flag setting
STA TEMP2 ;Set flag for error
JSR COMPERR ;Print compare fail address
PRG_OK JSR UPD_STL ;Update Source/Target/Length variables
BRA PROG_LP ;Branch back until done
QUITPRG LDA TEMP2 ;Get Prog error flag
BEQ PRG_GOOD ;Branch to good program exit
LDA #$26 ;Get Prog failed message
BRA BRA_PRMPT ;Branch to Prompt routine
PRG_GOOD LDA #$25 ;Get completed message
JSR PROMPT ;Send to console and exit
LDA #$27 ;Get warning message for RTC and Reset
BRA_PRMPT JMP PROMPT ;Send to console and exitCode: Select all
;UPD_STL subroutine: Increments Source and Target pointers
;UPD_TL subroutine: Increments Target pointers only
; then drops into decrement length pointer. Used by multiple commands
UPD_STL INC SRCL ;Increment source low byte
BNE UPD_TL ;Check for rollover
INC SRCH ;Increment source high byte
UPD_TL INC TGTL ;Increment target low byte
BNE DECLEN ;Check for rollover
INC TGTH ;Increment target high byte
;DECLEN subroutine: decrement 16-bit variable LENL/LENH
DECLEN SEC ;Set carry for subtract
SBC #$01 ;Subtract one
STA LENL ;Save it back
LDA LENH ;Get length high byte
SBC #$00 ;Subtract carry
STA LENH ;Save it back
