I just watched the Kansasfest presentation a little while ago. Super cool stuff!
One thing that wasn't immediately clear to me reading the documentation was whether the function frames were something that paired with a function definition or a function invocation. Given the comments about recursion, I'm assuming that they are allocated at function invocation, is that correct? (I suppose it wouldn't make sense any other way, but you never know with memory-constrained systems.)
Also interesting, I think, is how object-oriented the architecture seems. Functions look a whole lot like objects, or at least like PostScript procedures, dictionary stack and all.
One of my long-term goals is some day implementing a PostScript-like programming environment, so maybe that's just my bias showing. :-)
Glad the video was beneficial. KFest is a blast and has some very hard-core technical membership and content. You've guessed correctly regarding the call frames - they are allocated per invocation. I've tried updating the documentation to make it more clear.
As for the object oriented nature of PLASMA, that is probably more of a function (no pun intended) of it being modular and some of the syntax I chose (on purpose) to make it more familiar. There isn't any kind of OO enforcement, but you can fake it pretty well. I tried it with the TCP/IP modules. Hiding the different hardware implementations and state behind a common interface made it clean and easy to write the higher level code.
When implementing a language for the 6502, I've decided that "less is more".
Dave...
