Not sure if that's the right place, but I'm going to post my updates on my 6502 project here.
Hope that's okay
Got my 65c02 running! did both a "free run" and a "tight loop" using logic ics and the arduino.
https://www.youtube.com/watch?v=YmNbVczc618
https://www.youtube.com/watch?v=qPJ2ZzTwDSk
I have now my arduino monitoring the 65c02 and setting opcodes on the data bus. It also reads the data bus when RW pin is writing.
Haven't connected RAM yet, but hope to get it done soon
I wrote a simple program and so far it's working:
LDA #$03 ($A9, $03)
STA $05 ($85, $05)
JMP $0000 ($4C, $00, $00)
The program does the loading and storing, then repeats the jump. When it gets to the jump I have the arduino repeating the jump so it ends on an infinite loop. You can see the A0, A1 and A2 leds light on/off one after the other just like the version using logic ics.
When it sets the STA part I can read the 65c02 trying to store the value on address $05. The address bus shows $05, but the data bus shows $FE instead of $03 (which should be the value stored in the A register, right?) I'm almost sure its $FE... or maybe $7F
Doesn't seems like the 6502 is reseting/interrupting, it moves forward fine and the VectorPull pin doesn't trigger.
My arduino generates the clock, detects vectorpull and RW. Sets data in the dataBus when RW is reading and reads the data bus when RW is writing.
I use the RW pin to switch the 8 digital ports from input to outputs, to create a tristate. So when RW is reading the 8 ports are outputs and can send + or - Voltage. When the RW is writing, the 8 ports are set to input, thus having impedance.
Any ideas why data bus is writing this value?
Thanks for your awesome support!
Playing with a 6502 is addictive
