Prices for double basses are all over the map. You can find cheaply-made Chinese ones for less than 1000 USD, and as always, you get only what you paid for. At the opposite end, hand-carved instruments from the early 19th century and earlier have been known to fetch as much as 100,000 USD if in excellent condition.
Yeah, in french we have a saying that says "cheap is always too expensive", i.e. you'd better take more time saving money and buy an expensive model of something rather than buy the cheap model.
In either case, my experience is that it takes a minimum of 12-15 years for a new instrument to start to develop its character and tone. [...] Bottom line is I always recommend looking at used instruments, not new ones.
Thanks for the recommandation, and anyway as a complete beginer with that type of instrument it would take quite a while before being able to play it good enough.
Outside of orchestral playing, which is where I started, the double bass is widely used in jazz, blues, Bluegrass, rockabilly, country-and-western, Latin, and swing. There are instances of the double bass being used in rock 'n roll, although there are technical issues involved in amplifying it to the bowel blockage clearing volume rockers like to use.
I am only used to being part of large bands (chors and brassbands) where the group is more important than each of it's members. I have no idea what it is like to be a member of a jazz or rock group with only 4-5 members and each of them who counts. The problem is that those groups are never long lasting as the depart of any member means the end of the group, and also that such groups are closed to arrivals of new members (i.e. if they already have a bassist they don't need a second), so it's extremely though to find a place in a group I guess. Unless you plan the thing very early with friends and decide who learns to play which instruments, but again that's tricky. The ideal would be to know a group whose bassist have to leave and convince themselves that you can replace him, but they'd want you to be skilled, you can't come in as a newbie.
As for amplification I'd be more interested in upright basses as opposed to electric bass guitars because they don't need any. I'm not into all those amplifiers stuff, very complicated and in the end having them is as space consuming as a full sized contrabass, only they require electric current which limits in space where you can play.
As for the five string instrument, I would avoid it until you get proficient on a four string model. The fifth string is either a low B that is three octaves and a half-note below middle C (about 30 Hz) or a C one octave below middle C, the latter often used by soloists looking to play high in the instrument's range. On a four string instrument, the lowest string is tuned to an E that is two octaves and a sixth below middle C (about 40 Hz). I've never owned a five string bass, but have played one. I find it strange, mostly due to the wider fingerboard. Not really my cup of tea.
In my point of view, the very role of a bass is to play low notes. If it cannot reach notes as low as a piano, it is sort of pointless to have a bassist in the 1st place, because you could just play the bassline on a piano for example, or a synthesizer.
That being said I didn't know about C-extentions, they look as good if not better than 5 string basses, since it allows playing the instrument "traditionally" while reaching lower notes.
I can't comment on how easy or difficult the bass is to learn because that is highly dependent on the aptitude of the prospective player. Music comes very naturally to me, so when I first started studying the instrument it didn't seem to be all that difficult to understand. Developing one's chops takes a lot of practice, as it is a fretless instrument. However, playing at jams and open mikes helps in that area.
For me I would get the assumption it is easy to play but I might be wrong that's why I'm asking. There is no wind and mouth related difficulties as in brass instruments, and no poliphonic difficulties as in piano (well there is some places where a bassist can play multiple notes simultaneously but that's the exception not the rule). For me I belive the difficulties would be to hold the instrument correctly, to know where to put your fingers on the fretboard to produce correctly pitched notes, and to know which string to use when. The rest is trivial, if you plug a string the note will always be here, unlike in a brass instrument where you can blow in but not get the note you planned, or get it wrong pitched (this actually happens all the time).
I don't even understand why basses have multiple strings, in theory only one string could suffice as you play one note at a time, besides, there is many notes that can be pulled with more than one string (or even with all 4 of them), so how do you decide which string do you use to play it?
I'm not keen to switch to a 5-string instrument, but luckily there's an alternative that works very well (for fretted and fretless bass guitar, at least -- it's untested on my upright bass). I purchase strings intended for a 5-string bass guitar, and I throw away the skinny one (the G). The remaining four strings are installed with their intended tunings, namely D, A, E and -- way down in the basement! -- B !
(If you're listening on a laptop, this is a note you won't hear.)
Interesting trick! The obvious disadvantage is that you won't be able to reach notes as high, and that you will come with a non-standard instrument, switching from it to other basses will be very hard to say the least.
As for laptops I'm pretty sure they filter out low notes in general, not just the lower B. It's physically impossible to produce low sounds with a small sized speaker.
