Hi
I am building a project that uses an Intersil HIN232ACPZ, which is a TTL-RS-232 level shifter like the Maxim MAX232. In fact, the two have identical pinouts and so I was wondering if they are supposed to be exchangeable. I'm asking because I don't have the Intesil part, but I've got some spare MAX232s and I'm thinking of substituting.
Thanks
JonB
Intersil HIN232ACPZ vs Maxim MAX232
- GARTHWILSON
- Forum Moderator
Re: Intersil HIN232ACPZ vs Maxim MAX232
I haven't looked at the data sheet, but I suspect it's the same thing. I ordered MAX232's one time and got Sipex SP232's, probably from Jameco. (Mouser and Digi-Key wouldn't substitute like that.) I got them for boards laid out by someone else though, and ended up never using them. For my own stuff, I use the MC145406 which has three line drivers and three line receivers in a 16-pin DIP, so you can have TX, RX, RTS, CTS, DSR, and DTR, with no external components. It requires the higher + and - voltages, but I always have those for other things anyway.
The MAX232 requires larger capacitors (1µF) than the HIN232A (.1µF). Either use a MAX232A or replace the capacitors including the decoupling capacitor (5 caps total).
- BigDumbDinosaur
jonb wrote:
Hi
Thanks
JonB
Thanks
JonB
Technical note: every so often, one will see a schematic in which the MAX232 is used with charge pump capacitors that are larger than 1µF. That is incorrect design and according to Maxim, may cause the MAX232 to eventually fail. What happens is the larger capacitors draw more current at initial power-on than the MAX232 is designed to handle. The charge pump circuitry in the MAX232 is overloaded and eventually goes south. There is absolutely nothing to be gained by oversizing these capacitors.
