Here's what I have, but this was 2008/2009 so things will probably have changed, and some of the links may now be dead:
The chip was ST2205U from sitronix
http://www.sitronix.com.tw/sitronix/pro ... enDocument (
https://archive.is/4RRyp)
One brand with the right chip at the time was Coby.
"coby keyring project, 6MHz 6502-like processor in a small battery powered LCD display usb-slave device."
A possible other match was sold as
Yuraku Photo 1.5" Digital Photoframe Keyring
"So for a tenner you get a battery powered 6502 computer with colour lcd display and a usb interface, in a nice consumer case"
http://blog.makezine.com/archive/2008/0 ... 6B48984890http://spritesmods.com/?art=picframehttp://picframe.spritesserver.nl/wiki/i ... /Main_PageYou might be able to find the datasheet if you search for ST2205U_datasheet_v1.0.pdf
A google search for one specific model
http://www.google.co.uk/search?q=Coby+DP-151Note that models do change. at
http://picframe.spritesserver.nl/wiki/i ... ch_chipset we see a note to the effect that the ones with a driver CD are a good bet. One type of wrong kit is based on "AX203 basically a souped up 8051" "suspiciously similar to the CPF5102" and presents itself as a CDROM perhaps containing "DPFMate.exe"
Long comment thread here
"Sprites mods: Use a cheap digital photoframe as a second display for your PC - Result"
http://spritesmods.com/?art=picframe&pa ... owall=truewhich contains some drivel and some pointers
The hack, at one time, demands a device bigger than 1M flash
There's a project wiki at
http://picframe.spritesserver.nl/wiki/i ... /Main_PageThe hardware we're looking for should show up as
Bus 002 Device 002: ID 1403:0001 Sitronix Digital Photo Frame
which just might be (as of jan 2009) Yuraku 1.5" digital photo-frame
This one from amazon comes with cdrom and may be the right stuff
http://www.amazon.co.uk/Yuraku-Photo-Di ... =de_a_smtdbecause this chap posted the usb id:
https://lists.ubuntu.com/archives/ubunt ... 16250.htmlRelevant web pages:
http://picframe.spritesserver.nl/wiki/i ... hotoviewerhttp://code.google.com/p/photokeychain/source/checkouthttp://www.neophob.com/serendipity/inde ... -Hack.htmlhttp://sitronix-dpf.svn.sourceforge.net ... dpf/trunk/http://code.google.com/p/photokeychain/ ... id=3&can=1http://picframe.spritesserver.nl/wiki/i ... _unbranded
