Starting with ATMEL CPLDs: ATF1504AS
- BigDumbDinosaur
Re: Starting with ATMEL CPLDs: ATF1504AS
cbscpe wrote:
Surprisingly these are quite powerfull and a full decoder with memory mapping and ROM overlay logic can be easily put into one single ATF1504AS.
So, this is an entirely general-purpose TQFP44 to DIP48 adapter? Sounds handy!
[Edit: had PLC44 previously... have I got it right this time?]
It looks like this one:
http://www.ebay.co.uk/itm/310725315598
I have adapters for these parts, but nothing that would plug into breadboard. Very nice.
Hi Aslak,
yes thats those, I got mine from the dipmicro shop in ebay.de but those you linked are the same prototype boards. To make them real DIP-48 compatible and pluggable I used these
http://www.aliexpress.com/item/AE-50pcs ... 88854.html
you can get them from the bay as well e.g. here
http://www.ebay.de/itm/50Pcs-Gold-Plate ... 4adfe37f2c
They have a fine and a coarse side. The fine side fits neatly into breadboards and DIP Adapters and you just solder the coarse side to your prototype boards. I have also PLCC44 to DIP adapters but they use much more real estate on a breadboard as they are much broader, see also the link in the first post of this thread of futurlec.
cheers
Peter
cheers
Peter
This place in Canada has some nice-looking adapters, including vertical PLCC-DIP adapters that could save a lot of room on a breadboard:
http://www.technologicalarts.ca/shop/st ... pters.html
- BigDumbDinosaur
Hi TomC,
thanks for the link to the site, they really have some very fancy adapters, especially this http://www.technologicalarts.ca/shop/st ... 0-pin.html one I was looking for since a very long time. And of course the PLCC adapters are really handy. Can't wait until they arrive.
Peter
Peter
Peter, thanks for all this info, I'll be surely using it in the months to come for my own project.
cbscpe wrote:
Hi,
to save real-estate on my breadboards and to have my favorite IC form factor (DIP) I have create a few of these for my projects that use a ATF1504AS CPLD.
after various tests and small projects (some sort of "Hallo World" and "Blinkenligths" for CPLDs) I will now start with a new SBC using one of the DIP-48 format CPLDs. Surprisingly these are quite powerfull and a full decoder with memory mapping and ROM overlay logic can be easily put into one single ATF1504AS.
cheers
Peter
cheers
Peter
Talking about your SOJ32 to DIP conversion, you are aware that there are various 128kbyte Cache SRAMs still available in DIP, e.g. the DIP version of your AS7C1024 exists as AS7C1024-20TPC (thin plastic case a 300mil 32-DIP) or as AS7C1024-15PC (plastic case a 400mil 32-DIP) and there is also the IS61C1024-15N (300mil 32-DIP).
- GARTHWILSON
- Forum Moderator
Here's a source of WW PLCC sockets that Ed pointed out a couple of years ago:
http://uk.rs-online.com/web/c/connector ... LCC+socket
Two alternative ways to wire-wrap PLCCs are described here. The option using plain pins (lower photo) is remarkably inexpensive.
- Attachments
- wire-wrap PLCC with machined pins.JPG (17.85 KiB) Viewed 2228 times
- wire-wrap PLCC with plain pins (bottom).JPG (38.04 KiB) Viewed 2228 times
Which software and do you normally use with ATF1504AS?
I've never used JTAG apart form to rescue an AVR using my AVR Dragon.
Looking at this link, it seems that yoiu have to purchase an ISP JTAG USB cable and use WinCUPL?
I don't think my AVR Dragon will work with JTAG with this chip as the Dragon is almost certainly for AVRs only (unless someone has tried this already and found it works?).
- BigDumbDinosaur
- Attachments
- AtmelISP.zip
- Atmel ISP Software
- (7.78 MiB) Downloaded 199 times
