It is currently Thu Jun 27, 2024 6:12 pm
 Post subject: SOLVED: ACIA CDP65C51
PostPosted: Sat Mar 21, 2015 5:53 pm
Hi,
I started a new project and now I'm stuck. I have a minimal 6502A System with 2kbyte RAM and 2kbyte ROM and a CDP65C51AE4. Everything uses a single 1.834MHz clock. "Hello World!!" after RESET works, but it seams the ACIA never receives a character. I already replaced the CDP65C51EA4 but nothing changed. I suspect a most stupid error. I have now the following minimal code to test my system
ACIA1      = $c090
ACIA1dat   = ACIA1 + 0
ACIA1sta   = ACIA1 + 1
ACIA1cmd   = ACIA1 + 2
ACIA1ctl   = ACIA1 + 3
   *=$FF00
reset
      ldy   #0
wait
      iny
      bne   wait
      sty   $0
      sty   $1
      lda   #$1F            ; 19.2K/8/1
      sta   ACIA1ctl         ; control reg
      lda   #$0B            ; N parity/echo off/rx int off/ dtr active low
      sta   ACIA1cmd         ; command reg
      inc   $0
main
      ldx   #0
MAINL
      lda   ACIA1sta      ; serial port status
      and   #$10         ; is tx buffer empty
      beq   MAINL         ; no
      inc   $0
      lda   hello,x
      beq   MAINC
      sta   ACIA1dat      ; put character to Port
      inx
      bne   MAINL
MAINC
WAITC
      inc   $0
      LDA   ACIA1sta      ; Serial Port Status
      AND   #$08         ; Is RCVR Full
      BEQ WAITC
      inc   $1
      lda   ACIA1dat
      sta   ACIA1dat
      jmp   main
hello   .text "Hello World!!"
      .byte $0d, $0a, $00
   *=$FFF8
nmi:   rti
irq:   rti
   .byte   <NMI      ;NMI VECTOR
   .byte   >NMI
   .byte   <RESET      ;RESET VECTOR
   .byte   >RESET
   .byte   <IRQ      ;IRQ VECTOR
   .byte   >IRQ
It prints "Hello World!!" <CR> <LF> and waits for a input character and then just prints the initial message again. Location $1 is not incremented (the RAM is a DP-RAM so I can look into it from the other side). Any ideas what I'm missing?
Regards
Peter
EDIT: I FORGOT TO UNCHECK RTS/CTS FLOW CONTROL IN THE TERMINAL EMULATION PROGRAM I USED :roll: :roll:
PostPosted: Sat Mar 21, 2015 6:52 pm
Is the ACIA's DCD\ input low? The receiver won't operate if it's high.
PostPosted: Sat Mar 21, 2015 8:12 pm
Yeah thanks for the hint. But as mentioned (see edit) I found the stupid problem, the RTS/CTS flow control of the terminal emulation. The Inputs of the ACIA are all tied to ground for the moment.
Users browsing this forum: Google [Bot] and 16 guests
