Can you explain to us how it works, bogax? It would appear that you're from the same "school of commenting" as dclxvi
Do you have a rough cycle count estimate for typical inputs?
Mike B.
actually I tend to think of the code as sort of
incidental to the comments else we'd all be coding
in hex (or something)
that's not to say I do a great job of commenting
code is easy
comments are hard
but I hate to spoil these little puzzles
256 % 40 = 16
256 = 6 * 40 + 16
so if I subtract some mutiple x * 256 from the
remainder and then add back in x * 16 I've reduced
the remainder by some multiple of 40, 6 * x
the most the result (the partial remainder) can
be with a nibble is
15 * 16 + 255 = 495 = 256 + 239
so if the carry is set and I add 15 back in
I've done it again except in this case x is 1
and the most the answer can be is 239 + 16 = 255
and the carry will be clear when you do the high
nibble which is similar in that 4096 % 40 = 16
except that 4096 is already mutiplied by 16 so
no shifting
then it just repeatedly subtracts 40 in a tight
loop
I think worst case is 73 cycles
