16-bit wide memory?
Re: 16-bit wide memory?
Thanks for the explanation, guys. I was just a bit concerned that there was a speed issue which seemed to be elluded to by Garth saying "Someone looking for fast video generation won't be interested in the '816".
I've already purchased some 65C816's, but was planning putting off using them until I had gained more experience with 65C02's.
- GARTHWILSON
- Forum Moderator
Perhaps I should clarify-- Yes, the '816 is a hotter performer than the '02. It definitely does not fall short of the '02 in horsepower. But where the '02 has an advantage in both nostalgia and simplicity, there were few home computers with 816's in them to produce the nostalgia now 30 years later, and someone who is interested in high-performance video will probably be looking at more-complex processors to get there. I'm not the one to talk to about video and calculating hi-res frames in real time on 3D graphics stuff, but that seems to me to be way, way up there in computing performance, way beyond processing audio in real time, or doing word processing, etc.. Many computing applications (including what I do on the workbench) have no need for anywhere near that level of performance, so it becomes needless complexity and cost. The fastest off-the-shelf 65816's today will do three or four MIPS (millions of instructions per second) on 16-bit data, and that's way beyond what we had in any 8-bitter 35 years ago. For the 6502 to keep up while doing a steady stream of 16-bit operations, it would have to do 10 or 12 MIPS. I seem to remember though that even the 6502 outperforms the 32016 32-bit processor National produced for a while many years ago, meaning that bus and register width by themselves are not everything.
Since the topic has developed a bit slowly and I did not re-read to see where we were on it, I see I repeated myself, in the comment about Forth speed. I wasn't trying to be insistent.
You could still start with the '816 if you want, and initially use it as a 6502, then start picking up the new instructions and addressing modes little by little. Even in 6502-emulation mode, it still has a lot more to offer. If you want more than 64K of memory though, going the '816 route would sure be simpler than trying to add extra logic and handling the associated programming difficulties on the 6502.
Why does the 65816 fall short speed-wise?
Originally I meant to point out that people nowadays don't use the 65816 much because they have no nostalgic attachment to it, which is why people use the 6502 and it is not fast enough compared to modern chips to be picked over the above mentioned chips. For your retro project it should be fine.
- GARTHWILSON
- Forum Moderator
Compared to modern chips like newer Pic32s (with 512k internal SRAM)
I've never used any PICs. I was just impressed by the specs of some of their chips, and the MaxiMite BASIC computer seems like something people here might be interested in. We are all attached to the 6502 in some way but it is hard to argue with 330MIPs
http://www.microchip.com/wwwproducts/De ... EC)+family
http://en.wikipedia.org/wiki/Maximite
- BigDumbDinosaur
Something that also must be considered is just how much work gets done during each instruction. The 6502 family tends to be quite efficient in that regard.
- GARTHWILSON
- Forum Moderator
MIPS don't always translate to perceived high performance. [...] The PICs do have a high MIPs rating, but that is internal, not the performance of the overall system.
Druzyek:
That was an interesting device that you linked to above.
The PIC32 family is based on the well known MIPS 4000 architecture which can deliver high performance like the 32-bit ARM architecture. An interesting feature of the PIC32 that I took note of is that it core supports a reduced width instruction like the ARM's Thumb instruction set. Coupled with the wide data path (128 bits) to the 2MB of on-chip Flash, the PIC32 can fetch as many as 8 instructions in a single Flash memory read cycle.
After reading over the architecture description, I can certainly agree that PIC32 will run circles my M65C02A core even when using its single cycle 16-bit arithmetic/logic modes.
The PIC32's wider data buses and on-chip Flash and SRAM will likely allow it to sustain its advertised instruction ratings.
It is certainly warrants consideration as an embedded controller. With its on-chip High-Speed USB 2.0 interface and 10/100BaseT MII/RMII Ethernet MAC, the PIC32 will give an ARM core a run for the money.
Michael A.
- BitWise
- In Memoriam
Curiously my next project will be an emulation of the WDC chip that never was, the 65832, using a PIC32. I suspect it will work best in 16-bit mode as a 65816 dipping into 8-bit and 32-modes when needed.
I've found a nice PIC32 developement board (the Diligent ChipKit Wi-Fire) using a PIC32MZ2048ECG100 200 MHz device (330 DMIPS) with 2MB Flash, 512KB RAM, USB OTG, a Wifi adapter and micro SD card. I think you only get the full MIPS rating if you run the code from RAM so I'm reserving 384KB for the emulator and keeping 128KB for RAM based functions, stack and variables.
I'm coding a new emulator in C and want to add monochrome graphics output using DMA driven SPI plus enough of a USB host to access a wireless keyboard and mouse.
Andrew Jacobs
The quad-core AMD Opteron in my office's Linux server produces about 22500 BogoMIPS
Also, a 200MHz 6502 is not really relevant to this discussion if we are talking about what chip to use for a hobby project since it seems the 14MHz version is the only one any of us will ever get our hands on.
Again, I'm not trying to beat up on the 6502 or 65816. They are both really neat.
- GARTHWILSON
- Forum Moderator
DMIPS (as in 330 DMIPS) refers to the Dhrystone benchmark. I suspect the PIC32 MIPS number is probably about half of that. I have no idea how a given speed of 6502 would compare in Drystones, but obviously the PIC32 with its 64-bit accumulators and mostly single-clock instructions is in an entirely different league, for entirely different applications.
- BigDumbDinosaur
White Flame
- BigDumbDinosaur
White Flame wrote:
Again, high MIPS doesn't necessarily translate into high performance. Although the 65C816 in the SuperCPU cartridge ran at 20 MHz, all I/O was carried out at 1 MHz, as the I/O silicon in the host computer (other than the 8563/8568 VDC in the C-128) could not run any faster than that. Hence while much compute-bound processing was accelerated by the presence of the SuperCPU, reads and writes on the computer's memory, which was relatively slow DRAM, were not.
That doesn't quite tell the whole story, BDD, because it seems the SuperCPU has 128k of full speed onboard RAM. So accesses to the slow memory on the host machine would be minimised.
http://ftp.giga.or.at/pub/c64/supercpu/superinfo.html
We did a similar thing on our beeb816 project: put fast memory near the fast CPU and shadow as much as you can.
