Martin_H wrote:
Because the arguments are already on the stack, a function call in Forth is really cheap compared to a language like C which builds a call frame on the stack.
For all that, I find Forth a lot more fun.
: HEAPM ; ( for FORGETting )
512 CONSTANT NALLOC ( minimum size of new block allocated )
( define a "header" structure )
: >next ; IMMEDIATE ( does nothing, first element in structure )
: >size CELL+ ;
2 CELLS CONSTANT headerSize
( global variables )
CREATE startBase 2 CELLS ALLOT
VARIABLE freep
: mallocClear ( initialize base, freep )
startBase DUP >next !
0 startBase >size !
startBase freep !
: allocateBlock ( prevp p nunits -- address )
( if this function is called then p is big enough for nunits )
OVER >size @ OVER = ( prevp p nunits p.size=nunits? )
IF ( remove from free list )
DROP 2DUP >next @ ( prevp p prevp p.next )
SWAP >next ! ( prevp.next = p.next )
ELSE ( allocate tail end of p )
OVER >size @ OVER - >R ( prevp p nunits [ p.size-nunits ] )
SWAP R@ OVER >size ( prevp nunits p newsize &p.size [ newsize ] ) !
R> + ( prevp nunits newp )
SWAP OVER >size ! ( prevp newp )
THEN
SWAP freep ! headerSize +
: startOrEnd? ( bp p -- flag )
DUP >next @ ( bp p p.next )
OVER > ( bp p p.next>p? )
IF 2DROP 0 EXIT THEN
2DUP > -ROT ( bp>p? bp p )
>next @ < ( bp>p? bp<p.next? )
OR
: betweenBlocks? ( bp p -- flag )
AND
: free ( addr -- )
headerSize - freep @ ( bp p )
BEGIN
2DUP betweenBlocks?
IF
-1
ELSE
2DUP startOrEnd?
IF
-1
ELSE
>next @ 0
THEN
THEN
UNTIL
OVER DUP >size @ + ( bp p bp+bp.size )
OVER >next @ = ( bp p bp+bp.size=p.next? )
IF
OVER >size ( bp p &bp.size )
OVER >next @ >size @ ( bp p &bp.size p.next.size )
SWAP +!
2DUP >next @ >next @ ( bp p bp p.next.next )
SWAP >next !
ELSE
2DUP >next @ ( bp p bp p.next )
SWAP >next !
THEN
2DUP DUP >size @ + = ( bp p bp=p+p.size? )
IF
OVER >size @ ( bp p bp.size )
OVER >size +!
SWAP >next @ ( p bp.next )
OVER >next ! ( p )
ELSE
SWAP OVER >next ( p bp &p.next ) !
THEN
freep !
: morecore ( nunits -- address )
DUP NALLOC >=
IF
HERE OVER ALLOT ( nunits addr )
SWAP OVER >size !
headerSize + EXIT
THEN
HERE NALLOC ALLOT ( nunits addr )
2DUP >size !
SWAP 2DUP + ( addr nunits freeptr )
NALLOC ROT - ( addr freeptr leftover )
OVER >size ! ( addr freeptr )
headerSize + free ( addr )
headerSize +
: malloc ( size -- address )
headerSize + ( nunits )
freep @ DUP >next @ ROT ( prevp p nunits )
BEGIN
OVER >size @ OVER >= ( prevp p nunits p.size>=nunits? )
IF
allocateBlock EXIT
THEN
OVER freep @ = ( wrapped around? )
IF
NIP NIP ( nunits ) morecore ( addr ) EXIT
THEN
ROT DROP ( p nunits ) SWAP DUP >next @ ROT
AGAIN
mallocClear ( starts the ball rolling )
+ - 1+ 1- 2* >BODY @ ALIGN ALIGNED AND branch C@ CELL+ CELLS CHAR+ CHARS DROP DUP enter EXECUTE EXIT INVERT NEGATE NIP OR SWAP UNLOOP XOR [ ] Code: Select all
: line \ plot solid line ( 'x 'y -- )
\ Draw a solid line from x,y to 'x,'y
\ x and y are global variables, and update to 'x,'y
\ . means "delta "
\ ' means "updated value of "
\ ~ means "sign of delta " ... -1 if <0, +1 if >=0
\ | means "absolute value of delta "
y @ - \ calculate .y ( 'x .y )
dup 0< 1 or swap \ ~.y ( 'x ~y .y )
abs dup >r \ |.y ( 'x ~y |y ) ( R: |y )
rot x @ - \ calculate .x ( ~y |y .x )
dup 0< 1 or swap \ ~.x ( ~y |y ~x .x )
abs \ |.x ( ~y |y ~x |x )
dup \ c is slope accum. ( ~y |y ~x |x c )
dup r> + \ k is loop counter ( ~y |y ~x |x c k ) ( R: )
negate 1 swap do \ main loop ( ( ~y |y ~x |x c ) ( R: 1 -k )
plot \ plot (x,y)
i 0< if \ is line finished? ( ( ~y |y ~x |x c )
dup 0< if \ n: c < 0? (
over + >r \ y: ( c += |x ( ~y |y ~x |x ) ( R: 1 'k 'c )
3 pick y \ y += ~y ( ~y |y ~x |x ~y y )
else \ )
3 pick - >r \ n: ( c -= |y ( ~y |y ~x |x ) ( R: 1 'k 'c )
over x \ x += ~x ( ~y |y ~x |x ~x x )
then \ )
+! r> \ update x or y ( ~y |y ~x |x 'c ) ( R: 1 'k )
then \ )
loop \ ) ( ~y |y ~x |x 'c ) ( R: )
drop 2drop 2drop \ delete temps ( )
