It is currently Sun Nov 17, 2024 4:46 am
Post new topic Reply to topic  [ 27 posts ]  Go to page Previous  1, 2
 Post subject: Re: VDU, V9958
PostPosted: Thu Jan 22, 2015 3:26 pm
Is that like a 64-pin SODIP breakout??
PostPosted: Thu Jan 22, 2015 5:46 pm
Yup. It is my Shrink DIP64 adapter. It spans two breadboard slabs.
As to whether you can buy a ready made one... Probably, but it would cost a fortune.
Where do you live legacy? I could possibly make you one, for the cost of parts - a few pounds at most. If you want a SDIP socket attached, I should have a (recycled) one of those available as well. Let me know.
PostPosted: Thu Jan 22, 2015 5:53 pm
oh, really thanks, it helps me a lot with the breadboard =D
i live in italy
the guy on ebay should has sold me a V9958 chip with the SDIP socket
not sure about this, the item will arrive in weeks (shipped from china)
PostPosted: Thu Jan 22, 2015 7:00 pm
about where-to-buy, in this topic (MSX forum) i got a lot of useful information about where-to-buy =)
PostPosted: Thu Jan 29, 2015 12:05 am
is there any package PDIP64 of pinch 1.778mm for eagle/CAD ?
PostPosted: Thu Jan 29, 2015 12:59 am
0.070 inches.
Michael A.
PostPosted: Thu Jan 29, 2015 12:50 pm
i have redesigned the VDU V9958 (and its package 1.778mm) as Eagle/CAD library's item
PostPosted: Thu May 07, 2015 9:29 am
Should post that in a link so that everyone doesnt have to redesign that part for their library.
PostPosted: Mon Jul 20, 2015 8:43 am
Spotted a V9958 Video board here :
http://www.primrosebank.net/computers/m ... _specs.htm
I also spotted a DIP64 adaptor for breadboarding a V9958 IC
http://www.primrosebank.net/computers/m ... design.htm
I believe he still may have some of the adaptors left.
PostPosted: Fri Jul 31, 2015 12:51 am
Hi Folks,
The quoted site is mine :-)
And yes, I do have a few adapters left if anyone is interested. They are the second version of the board, about 1/2" narrower than the photos shown of the V1 board on the webpage
Regards
Dave
PostPosted: Thu Aug 27, 2015 2:23 am
Does anyone know if it is possible to use two D41464 DRAM's with a TMS9918a rather than 16 4116 (16k x 1)? Besides reducing the part count significantly, I would avoid the 4116's need for negative and 12 volt power.
The reason I am considering using a TMS 9918a over 9958 is that I can avoid the issues with 0.7 " spacing, and I've found much more information on the TMS9918a.
PostPosted: Mon Aug 31, 2015 7:52 pm
Some further research let me answer my own question. I read through the data sheets of the 41464 and 4116 DRAMs. The four bit wide chips multiplex their pins for input and output, while the one bit wide chip has separate input and output. I found an article which says that this approach won't work. If you want to avoid the 12v and -5v requirement the way to do it are eight 64kbx1 DRAM's which are 5v only parts. At that point the use of latches with static RAM is probably the best approach.
