need some assistance on assembler LABELS
Hello everybody,
First of all, I have to tell you that I'm relatively new to assembler.
For my homebrew 6502 project I took "Kowalski"s 6502 assembler and simulator to program the ROM because it looked very simple to use.
I also took some code-parts I found in the internet (e.g. Daryl Rictors PC keyboard connection and others) - and adopted or rewrote to adapt it to my little computer, were necessary. Up to now everything worked fine.
Unfortunately I am now encountering a very strange behaviour dealing with labels. Sometimes it works and assembles, sometimes not.
I have the impression, that it has to do maybe with "how far" the label is. But in my opinion, this shouldn't be. (e.g jsr address - where address can be anywhere in memory)
Or maybe similarities in the name of the labels (like .lp0 .lp1 ??), or my syntax is wrong ?
Maybe it's somehow my fault ... I don't know.
Did someone ever had similar problems with "Kowalskis" 6502.exe ? I'm just completely in the dark !!
Too bad...
I'm willing to upload s.th more concrete, but the code will be a bit longer, because I encountered this only when code gets bigger.
vespacla
Too bad...
vespacla
Re: need some assistance on assembler LABELS
The difference between my file version 3 (_ver3) and version4 (_ver4) is only row 415 and 416. Please have a look at it.
The assembler tells that .printacc is an unknown label name, though it has been used havily before. _ver3 works (using .printacc many times)
I don't understand what I'm doing wrong ...
- Attachments
- BANANA-I-ROM01_ver4.asm
- (44.83 KiB) Downloaded 220 times
- BANANA-I-ROM01_ver3.asm
- (44.77 KiB) Downloaded 227 times
Preceeding something with a dot is reserved for directives in this assembler. It is in general never a good idea to start a label with anything other than an alphabetic character (a-z, A-Z) unless the assembler calls for it (for example some assemblers ask for a backslash to preceed local labels).
- BigDumbDinosaur
Assembler Labels
The Kowalski simulator's assembler not only recognizes pseudo-ops as dot-something, e.g., .BYTE, it recognizes dot-labels, e.g., .0000010, as local labels whose scope is bounded by the nearest global labels. A simple example will explain this:
In reviewing your source code I noted several attempts to reference a local label that was not in scope at the point where the reference was made. For example:
In the above code fragment, .printacc would not be in scope, as it is bounded by the labels kbreinit and KBINPUT.
As a fairly general rule, subroutine entry points should be demarcated with global labels. Also, as a matter of style, I use all lower case labels and symbols. Not all assemblers are case-insensitive—the Kowalski assembler is configurable to either recognize or efface case in labels, symbols, mnemonics and pseudo-ops. For consistency, I recommend that you make .opt proc65c02,caseinsensitive the first line in your program. This statement tells the simulator that 65C02 instructions should be supported (but be aware that it is the Rockwell 65C02, not the WDC one, that is supported) and that case-insensitivity is in effect. Case-insensitivity, of course, doesn't apply to quoted strings, such as .BYTE "Text String".
GLOBAL01 <————— a global label
.0000010 <———— a local label <————+
goto .0000010 ———————————+
.0000020 <— another local label <—+
goto .0000020 ———————————+
GLOBAL02 <————— another global label
.0000010 <————————————————————————+
if some condition
goto .0000020 ;won't work, as .0000020 isn't in scope
GLOBAL03 etc.Code: Select all
kbreinit JSR KBINIT ;
LDA puntouno
jsr .printacc
KBINPUT JSR kbtscrl ; turn off scroll lock (ready to input)
- barrym95838
BDD,
Your explanation and recommendations make a lot of sense. One puzzle remains: why did two almost identical (but similarly defective) sources receive such different reactions from the assembler? Just dumb luck (no offense intended vesplacla) for version 3???
Mike
Mike
- BigDumbDinosaur
- BigDumbDinosaur
Also, there appears to be some sort of pecking order in the error processing, such that different source files with a common error are treated differently depending on when the code in error is encountered during assembly.
Thank you very much indeed !
All you guys helped me a lot, and after quickly changing all local labels to global ones, as BDD explained - it worked !! Well, now I can go on with the real task, which is debugging. That's great.
What I am doing is obviously a hobby. It's wonderful to know you in this forum, thank you once again for spending your time on my problem !
- BigDumbDinosaur
Local labels are most useful in subroutines and code blocks. For example, here's some code from a SCSI utilities program I wrote for my POC unit, in which local labels are used:
;probebus: PROBE SCSI BUS FOR DEVICES
probebus shortr
ldx #0 ;starting SCSI ID
.0000010 stx workid ;current device
stz devtab,x ;clear device flag
cpx hbaid ;this the HBA?
beq .0000020 ;yes, mark it present
jsr dotstrdy ;see if device responds
ldx workid
bcc .0000020 ;device present & ready
cmp #ed_check ;check condition?
bne .0000040 ;no, device not present
.0000020 lda #%10000000
sta devtab,x ;mark device present
cpx hbaid ;HBA?
bne .0000030 ;no, actual device
lda #%11111111
sta devtab,x ;identify as HBA
bra .0000040 ;skip ahead
.0000030 jsr dostart ;device start/load...
; DOSTART may return an error but we don't care at this point.
jsr doinqry ;get device type
ldx workid ;current ID
.0000040 printchr '.' ;show some progress
inx
cpx #n_scsiid ;all IDs checked?
bcc .0000010 ;no, next device
rts
;seldev: SELECT DEVICE FOR OPERATION
seldev shortr
termprn selctdev,0 ;prompt user
seldevAA lda #1 ;max input size
ldx #'0' ;set input range
ldy #n_scsiid-1 | m_binasc
jsr input ;get device ID
bcs .0000010 ;aborted
lda strbuf ;get input
and #m_ascbin ;change ID to binary
sta workid ;set working ID
jsr getdtype ;get device type
bcs .0000020 ;device not present
.0000010 rts ;return w/device type
.0000020 termprn devnotpr,0 ;alert user
sleep 3
bra seldev ;try again
;Incidentally, I generally step local labels by 10 so that I can insert new ones if needed without having to rearrange the existing labels.
- GARTHWILSON
- Forum Moderator
Use of local labels in this way eliminates the need to have to think up new label names that will never be referenced outside of the subroutine or code block in which they have been defined. Note how I reused the same label names in both subroutines without conflict.
teamtempest
I use three (or so) letters abbreviating the name of the routine, then put digits after them, like "lmd1", "lmd2", etc..
- BigDumbDinosaur
The commercial assemblers I've used don't have that capability outside of macros...
Dev-Pak recognized a local label as one with a trailing dollar sign in its name, such as L0000010$. The dollar sign didn't count as a character in the name, and Dev-Pak recognized label, symbol and macro names up to 32 characters in length. Most of RAM1 was used to maintain the symbol table and macro dictionary. which meant that the cross-bank kernel subs had to be called to manipulate the table and dictionary. Hence the assembler was rather slow and as the symbol table expanded, the assembler got even slower. However, it was better than nothing.
- GARTHWILSON
- Forum Moderator
as the available assemblers of the time only supported six character label and symbol names. It was a constant challenge to come up with meaningful names and also maintain the basic naming with labels within code blocks.
- BigDumbDinosaur
I remember it well! I think even Fortran IV run on mainframes was limited to about that many, right?
- BigDumbDinosaur
Dev-Pak recognized a local label as one with a trailing dollar sign in its name, such as L0000010$...Most of RAM1 was used to maintain the symbol table and macro dictionary. which meant that the cross-bank kernel subs had to be called to manipulate the table and dictionary.
