I have not read your linked PDFs, but will comment based on my own knowledge/opinion.
a) Why was <BUILDS renamed into CREATE ?
This is half history and half speculation on my part: the original Fig-Forth <BUILDS DOES> was rather inefficient; it compiled an additional cell into the parameter field of each "child" definition. Some clever programmer figured out how to dispense with that. Having done so, someone noticed that <BUILDS and CREATE were identical except in what they compiled into the code field, and since the new DOES> changes the code field, CREATE could be used wherever <BUILDS was used. So for economy, they got rid of the redundant <BUILDS. (If you haven't read it already, my writeup on DOES> is at
http://www.bradrodriguez.com/papers/moving3.htm .)
I should add that I have since found a situation -- compiling directly to Flash memory -- where CREATE cannot be used with DOES>, and I have begun putting <BUILDS (new version, not the old version) back into my own Forth implementations.
b) Given a two-dictionary model (compiler/interpreter/editor/assembler/symbols all in a transient dictionary, headless core dictionary at bottom of memory) what's a good way to set up <BUILDS ... DOES> such that compiler time code disappears along with the transient dictionary, while child-word runtime behavior goes in the core?
The dividing line is DOES>, an IMMEDIATE word that runs at compile time. Right now it commonly compiles the execution token of (;CODE) , complies a machine code fragment, and then the compiler continues through the remaining code:
... foo foo DOES> bar bar ... is compiled to
|foo xt|foo xt|(;CODE) xt|JSR DODOES|bar xt|bar xt|
...foo foo ;CODE assembly-code ... is compiled to
|foo xt|foo xt|(;CODE) xt|assembly code|
(;CODE) is performed while executing the parent word; its action is to stuff the
following address into the code field of the newly created child word, and then exit the parent word. So the child word ends with a code field pointing to the JSR DODOES, and the action of JSR DODOES is to stack the child word's parameter field address, and start the thread that follows the JSR DODOES.
What you'd need to do is have DOES> lay down the xt of (;CODE)
and a pointer to the permanent dictionary, and then switch to the permanent dictionary to continue compilation:
(transient) |foo xt|foo xt|(;CODE) xt|adrs of X|
(permanent) X: |JSR DODOES|bar xt|bar xt|
So now (;CODE), instead of stuffing the following address into the child's code field,
fetches the contents of the following address, and stuffs that into the child's code field.
I hope that's clear. The revised ;CODE is left as an exercise for the student.
c) Who ever uses <BUILDS DOES> for anything?
Lots of Forth programmers. Any time you have a common action that needs to be applied to different data, <BUILDS DOES> can provide economy and simplification. I suspect most people first encounter the use of <BUILDS DOES> when looking at the code for Forth assemblers. (See, for example, my
MSP430 assembler.) I sometimes tell people that Forth is an object-oriented language, with the restriction that each object can have only one method (the DOES> code).
d) Does <BUILDS have to be the very first thing in the definition of the builder? It was in every example I could find. Then it could be coded as (rewinding the dictionary pointer and starting the definition's CFA over)
otherwise it becomes verbose and clunky
Neither <BUILDS nor CREATE must be the first thing in the parent. It may, for example, be necessary to perform some action on the dictionary before creating the new dictionary header. When the logic of the code allows it, it's customary to put <BUILDS or CREATE first, simply to let the reader know that it's a defining word, but that's not a requirement.
e) If I'm calling it <BUILDS (not CREATE), and it's no longer in the standard, can I play fast and loose with how it operates?
Yes you can. Bear in mind that I've resurrected <BUILDS for my own purposes, so there will be at least one competing alternative, but as far as the Standard is concerned, you can do whatever you want. (I would love to see <BUILDS returned to the Standard, but I'd need 80-bit floating point to express the odds of that happening.)
More to follow...
