1080p HD Video on custom FPGA/VDAC/2MBx18 SyncRAM board
ElEctric_EyE
Re: 1080p HD Video on custom FPGA/VDAC/2MBx18 SyncRAM board
Post by ElEctric_EyE »
Initial 3-D Vector animation success! Not so fast as it does the plotting&clearing during the 1/60th of sec vertical refresh.
Will attach U-tube video link soon:
Here it is!
ElEctric_EyE
Got 2 more boards outputting the same triangle animation. Small problem I've noticed now that the display is dynamic: The other 2 boards are drawing at least 1/4 speed. I've surmised this is because the boards' hsync&vsync are delayed in order to line up all 3 parallel pixel streams in hardware, and the software is waiting for vsync to go high in order to start drawing.
Coincidentally, this was going to be my next area of focus, i.e. how to read/write to the videoRAM when the videoRAM is simultaneously outputting data to the videoDAC. I will have to do some research, but I think Arlet used a dual ported blockRAM the depth of which was one scan line. Does this seem correct? A FIFO buffer and then the DP blockRAM. I only have 2 RAMB16BWERs left. I may have to sacrifice some of the 16 16Kx11 X&Y scratchpad RAMs.
But first, I'm going to have some 3D Vector fun with just the one board in another thread. :)
ElEctric_EyE
The other 2 boards are drawing very slow. No doubt due to the way I'm syncing them up. I'm not pleased with this...
I've added a 32-bit 148.5MHz pixel cycle timer so I can try to analyze what is going on. Since the cpu is run at 1/2 speed it can analyze (it's own) cpu cycles as well. I calibrated it for a NOP and got back a value of 4 cycles, then tried an additional NOP and got a hex reading of 8 cycles, which is correct.
In the video the fast spinning green cube is the OUPUT PVB and uses its counter to count and display the cycles for those 2 NOPs, just to calibrate the identical counters in the other 2 pass-thru boards.
This OUTPUT board sends it's HSYNC, VSYNC and pixel clock to the 2nd board... This 2nd board is outputting the yellow pixels and its 32-bit counter is measuring the time VSYNC is high, the vertical retrace. The hex value is extremely large and interestingly, the HEX values cycle from 04308442, 04308442, 0438448. I say it's interesting because there are 3 different values, maybe for 3 different boards?
I've not quite gotten the 3rd board up to speed yet... In the video it is just displaying data from one of the sinwave BRAMs and rotating the red cube at an even slower rate although all boards are running with extremely small delays.
Sorry for the bad quality, Video is ==> Here
The blinking in the red and yellow boards is not seen in real life...
ElEctric_EyE
Thanks Ed! It has been a long day here...
ElEctric_EyE
I went off on a tangent after reading about the amiga video chips, namely the Amiga OCS...
After 4 weeks of attempting to digitally mix a 960x540 RGB video stream generated from PVB2 into a 1920x1080 output from PVB1, today I had to finally give up.
Using a 74.25MHz pixel clock for PVB1 (1/2 derived from PVB2 148.5MHz pixel clock), and arriving at the same horizontal frequency as PVB2, the horizontal pixels were stretched as expected, but the vertical pixels were not... I threw alot of effort into trying to stretch the vertical, but nothing would 'stick'. The vertical video was doubled, i.e. 2 identical pictures. I tried making a scanline doubler unsuccessfully. Since I can't see what is happening in simulation since this involves more than 1 board, I have to quit at this point. All PVBoards will have to output the same video frequencies for now.
ElEctric_EyE
This morning I finally tracked down the last of the problems and now have successful READ from the SyncRAM. In this instance, the cpu sends the X-coordinate then the Y-coordinate. On reception of the Y coordinate, the graphics accelerator halts the cpu and puts the pixel color info into a read-only register and then frees up the cpu.
All of the accelerator functions are performed after it receives a Y coordinate.
So far the hardware graphics accelerator can perform:
Draw Line
Copy/Paste
Pixel Plot
Fill (simple rectangular)
8x8 Character Plot (background/foreground colors)
Pixel Color Read
What's strange is I had early success on the blitter, so I assumed I could take the READ part of that state machine and use it for a another READ only state machine, as opposed to a READ-WRITE-READ-WRITE... This was not the case and more observation is needed to fully comprehend why this is so. 3 weeks spent on this one!
ElEctric_EyE
I'll continue developing on the four populated boards I currently have, but I've been wanting to delve into the BGA world of Xilinx FPGAs and design a new more capable board. Earlier I've had my eye on a larger Spartan 6 1mm 256-pin BGA. I forget the price, something like $50+.
But recently I've seen the 28nm 256-pin BGA Xilinx Artix FPGA for sale for $35 for the slowest version: XC7A35T-1FTG256C. This may be the path I choose, but I do not see it available in ISE. Will do more research... New thread here.
BTW, here are the resources currently used (from that thread). The project has almost Max'd this LX9:
ElEctric_EyE
So the project had 2 16Kx16 BRAMs to store X & Y coordinates, only single port mode was used. The cpu would send an 10-bit 'phase' value to the sin/cos LUT. The sin/cos LUT outputted 10-bit data back to the cpu.
The software stores 2 sinewaves into 2 BRAMs. A sin shifted by 1/4 (i.e. 256/1024) is actually cosine. These (sin,cos) (X,Y) coordinates will plot a circle. Modifying the phases of either the X register or the Y register will make an ellipse:
                  LDA #650
                  STA XORG
                  LDA #450
                  STA YORG
                  LDWi $0000
                  LDX #0
                  LDY #256
sinwave1          STX phase
                  LDA sinout
                  CLC
                  ADC XORG
                  STAaw scratchx1
                  STY phase
                  LDA sinout
                  CLC
                  ADC YORG
                  STAaw scratchy1
                  CPX #1024
                  BMI XNZ1
                  LDX #0
XNZ1              INX
                  CPY #1024
                  BMI YNZ1
                  LDY #0
YNZ1              INY
                  INW
                  CPWi $0400
                  BNE sinwave1
Now I have added a state machine to the hardware accelerator that does the above in hardware. In addition I've added another LUT so that the X & Y values can be computed simultaneously and sent to each BRAM. (I love hardware!) :D
Now the software looks something like this, although different offsets. It auto starts and puts the cpu in RDY upon receipt of the Yphase value:
                  LDA #0                 ;0-15 1K blocks
                  STA Xblock
                  STA Yblock
                  LDA #20                ;pixel offset values for screen placement
                  STA Xoffset
                  STA Yoffset
                  LDA #0
                  STA Xphase
                  LDA #256
                  STA Yphase
                  LDA #1
                  STA Xblock
                  STA Yblock
                  LDA #1920-20-1024
                  STA Xoffset
                  LDA #20
                  STA Yoffset
                  LDA #0                  ;10-bit phase resolution
                  STA Xphase
                  LDA #256
                  STA Yphase
It was nice to realize after coding the Verilog for DP BRAM initially, that ISE14.7 actually recognized I was trying to infer DP BRAMs. So on port A the cpu can read and write to the 16Kx16 X & Y BRAMs, on port B the hardware accelerator also can read and write simultaneously. Granted, the cpu is halted when the hardware accelerator is reading or writing, but the dual ports really make a design easy.
On the top_level the X & Y SCRAMs (scratchpad BRAMs) are instantiated like this:
    SCRAM SCRATCHRAMX (	.clkA(clk),
								.weA(SR1WE),
								.rstA(SR1CS),
								.addrA(cpuAB [13:0]),
								.dinA(cpuDO [15:0]),
								.doutA(cpuDI [15:0]),
								.clkB(clk),
								.weB(xwe),
								.rstB(1'b0),
								.addrB(addrx [13:0]),
								.dinB(xdata [SINaw:0]),
								.doutB(xdataout [SINaw:0]));
	SCRAM SCRATCHRAMY (	.clkA(clk),
								.weA(SR2WE),
								.rstA(SR2CS),
								.clkB(clk),
								.weB(ywe),
								.rstB(1'b0),
								.addrB(addry [13:0]),
								.dinB(ydata [SINaw:0]),
								.doutB(ydataout [SINaw:0]));
The actual SCRAM code:
// 16Kx11 scratch page FPGA dualport blockRAM
`timescale 1ns / 1ps
module SCRAM ( input clkA, clkB,
					input weA, weB,
					input rstA, rstB,
					input [13:0] addrA, addrB,
					input [15:0] dinA, dinB,
					output reg [15:0] doutA, doutB
reg [10:0] RAM [16383:0];
always @(posedge clkA)
	if (weA)
		RAM[addrA] <= dinA;
		else
			doutA <= rstA ? 16'h0000 : RAM[addrA];
always @(posedge clkB)
	if (weB)
		RAM[addrB] <= dinB;
		else
			doutB <= rstB ? 16'h0000 : RAM[addrB];
endmodule
EDIT: Uses just abit more resources. Next goal is to modify the size of the output which will require adding a certain value in 2 quadrants, and subtracting that value in the other 2 quadrants.
ElEctric_EyE
Resizing a circle/ellipse using the sin/cos LUT's only work when shifting values to the right, which is a divide by 2, 4, 8 etc. This is unacceptable because only ~10 sizes of circles are realizeable for 10 bits in 1920x1080 resolution. Duh, right?
So, after much time and effort, the sin/cos LUT's are not going to work for the limited BRAM space inside the FPGA.
I had early success with the hardware plotting of a circle using 8 octants with Bresenham circle in hardware (ie Verilog). Plotting directly to the video SyncRAM in (X,Y) Cartesian coordinates was easy with the algorithm I adapted from Wikipedia, but this was not sending coordinates to the BRAMs. Looking forward, adapting the state machine where it used to plot 8 octants for immediate plotting into linear addresses for storage is going to be a challenge.
Tomorrow I'll post a 1920x1080 static pic (and more explanation)of the 10 sin waves in blue, cosine waves in red and circles in green. Right now most is in purple and I've got no time left tonight.
MichaelM
Post by MichaelM »
EEyE:
Have you looked at Jack Crenshaw's Real-Time Math Toolkit? He has a very readable writing style for many practical mathematical tools. In particular, he has a good description of how to use range reduction to extend the practical use of sine/cosine tables. It may be that his book may offer a way to extend your circle and ellipses so that you may continue to use a look up table far at least a portion of your plotting routine.
Michael A.
ElEctric_EyE
MichaelM wrote:
...Have you looked at Jack Crenshaw's Real-Time Math Toolkit?
Thanks for the input Michael! I'll look into it.
Colors are correct now.
MichaelM wrote:
EEyE:
Discussed at viewtopic.php?f=2&t=1971. EEye was the last to post on that topic. I have the paper book which our professional-programmer daughter-in-law got me.
math book2.jpg (26.4 KiB) Viewed 1641 times
ElEctric_EyE
...Discussed at viewtopic.php?f=2&t=1971. EEye was the last to post on that topic...
I did read Jack Crenshaw's chapter on sines and cosines today... All I can say is wikipedia contributors seem to know their integer math, as well, when it comes to Bresenham circle and line algorithms. That's where I translated C/C++? code into Verilog a few months ago. I rechecked the site and it has even more information now. I've an idea I'm going to try. Thanks for the input. I just need something that works first, then I can optimize based on that book. After all, who wouldn't listen to what a NASA engineer has to say?!
ElEctric_EyE
I modified Jack's square root algorithm on page 86 to work in Verilog. Takes 50 cycles and actually works on 2 16-bit numbers up to a value of 46,340 (for the formula SQRT(X^2+Y^2)), except I had to perform the last shift right 2x, not 1x like in his algorithm on the last line.
Jack's Code:
unsigned short sqrt(unsigned long a){
unsigned long rem = 0;
unsigned long root = 0;
for(int i=0; i<16; i++){
root <<= 1;
rem = ((rem << 2) + (a >> 30));
a <<= 2;
root ++;
if(root <= rem){
rem -= root;
root++;
else
root--;
return (unsigned short)(root >> 1);
My copy of his work in Verilog. The variable 'a' is 32-bit.:
.......//SQRT state machine
			SQRTINIT:
				state <= CALC3;
			CALC3:
				state <= CALC4;
			CALC4:
				state <= CALC5;
			CALC5:
				if (i<16)
					state <= CALC3;
					else state <= CALC6;
			CALC6:
				state <= WAIT;
//square root generator
		SQRTINIT:
			begin
				LGREADY <= 0;
				i <= 0;
				rem <= 0;
				Root <= 0;
				a <= Xs*Xs + Ys*Ys;
			end
		CALC3:
			begin
				Root <= Root << 1;
				rem <= ((rem << 2) + (a >> 30));
			end
		CALC4:
			begin
				a <= a << 2;
				Root <= Root + 1;
			end
		CALC5:
			begin
			i <= i + 1;
			if (Root <= rem) begin
				rem <= rem - Root;
				Root <= Root + 1;
			end
				else Root <= Root - 1;
			end
		CALC6:
			Root <= Root >> 2;
At the conclusion of the chapter on page 87 he says:
If there’s any one lesson to be learned from this chapter, it is this:
Never trust a person who merely hands you an equation.
So maybe he did this on purpose?
Looks like the ISE 14.7 has offloaded some work to the DSP48A1 tiles:
