There may be situations where you don't want to recompile everything past that point. An example might be where there's an array of data you don't want to have to collect again that would get trashed. In that case, it's easy enough to write a new word that has the corrected behavior or expanded code, and make yourself some simple tools to make the beginning of the old word's parameter field refer to the new word, followed by unnest (or some variation thereof). The first system I started out on compiled slowly enough that it was sometimes worth doing it this way.
How to make a BASIC compiler?
- GARTHWILSON
- Forum Moderator
In Forth, to insert code, you have to recompile everything after the insertion point, since the addresses of any subsequent words will change
However, if even that doesn't satisfy your requirements, I completely agree -- in this case, I would have to say that Forth itself may not be the right language (I never said it was the perfect language for all people). If this were really an issue, I would definitely investigate a language like Scheme or a proper subset of Common Lisp, both of which supports proper garbage collection, and can easily support in-situ code updates without having to recollect data. As I understand it, making a proper subset of CL is not very hard to do, and I was thinking about exploring it someday. It also has the benefit of hiding pointers from the programmer, so you just plain don't have to think about them (as an experienced programmer fluent in many languages, I consider this a good thing overall). However, I know for a fact as well that native Lisp environments still allow direct access to machine resources too. Here's some sample code:
; Print the set of integers from 1 to 10, inclusive. Woohoo!
; Untested code, so I'm not sure if this will work right. I used to have a CLisp
; interpreter on my box, but don't anymore. I'm kinda ticked -- I want to know
; where it went.
(defun last (xs)
"Returns very last element of a list as an atom"
(cond
((= (length xs) 1) (car xs))
(t (last (cdr xs)))))
(defun all-but-last (xs)
"Returns all but the last element of a list, obviously as a list."
(cond
((< (length xs) 2) ())
(t (cons (car xs) (all-but-last (cdr xs))))))
(defun reverse (xs)
"Reverses the order of a list."
(cons (last xs) (reverse (all-but-last xs)))
(defun append (x xs)
"Appends x onto the list xs"
(reverse (cons x (reverse xs))))
(defun range (x)
"Returns a range of integers from 1 to x in a list."
(cond
((= x 1) (list 1))
(t (append x (range (- x 1))))))
(display (range (10))
Another language I would definitely look to implement would be Smalltalk -- like Lisp, it is fully garbage collected, and can do in-place code updates. Note that you don't need the full-blown "Smalltalk-80 Environment" -- I'm talking about just the core language. The syntax may be a little bit more agreeable, but it requires a significantly more sophisticated language parser than either Forth or Lisp (still simpler than BASIC though, I think).
IntegerArray subclass: #IntegerRange
IntegerRange methods
display
0 to: self length - 1 do: [ i | console print: self at: i ].
^ self
range: max
0 to: max do: [ i | self append: i ].
^self
Anyway, you get the idea.
But now you might worry about the performance of garbage collection versus explicit memory management. As long as you do your homework on the subject, you won't have a problem with this. Generational collectors make collection virtually transparent in most cases, and if you do so incrementally, it has even less of a performance impact. One dirty trick that Oberon (a language derived from Modula-II, and written by Niklaus Wirth; highly recommended too!) uses is to perform garbage collection while waiting for an I/O request to complete, for example. There is no reason why you should not be able to do the same in a Lisp environment either.
Interesting. Can you give some idea of how much space you're finding you need for a kernel, compared to what would be needed for the same thing in indirect-threadded?
Second, it was written from scratch and not derived from an extant indirect or direct threaded implemenation, so there isn't really anything with which to make a good comparison. There's FIG-Forth, but it might not be so easy to choose which pieces of FIG-Forth to use for comparison, since there are aspects which differ from the FIG-Forth model.
Currently, there are 86 words (that includes aliases, which only take up head space) that have been tested (several more untested words have been written). Basically, it's only the words necessary for making the QUIT (text interpreter) loop function. Not included in the 86 words would be words such as :, IF, and VARIABLE. Here is how the code is currently organized (it will definitely be reorganized in the finished version):
Heads: 628 bytes (all 86 words)
Primitives: 548 bytes (34 words)
Constants, variables, and deferred words: 66 bytes (16 words)
High-level words (with inline assembly intermixed): 851 bytes (34 words)
System-dependent (I/O) words: 37 bytes (2 words)
The total comes to just over 2k. For the purpose of debugging and experimentation (and partly my own curiousity) the Forth data stack does not sit on the zero page (unlike most Forth implementations). The total comes to 69 fewer bytes if the Forth data stack is moved to the zero page.
With no point of comparison, you may be wondering how I can claim that subroutine threaded isn't so bad in terms of space. The answer is that I started out writing the high-level words using only JSRs (and a final JMP of course). Basically, I just started with the colon definition and did simply wrote it using JSRs instead of DWs. As I looked at the code that resulted, I noticed a number of ways of optimizing it by replacing JSRs with (inline) assembly. In many instances, the code was not only faster (as you'd expect), but smaller (or at least the same length) too, so there wasn't even a decison to be made about whether to optimize or not. More on this below.
You don't have to. The quick and dirty way to make a prefix Forth assembler which I used in my Forth was to just make mnemonics that had the address mode built in, like LDA_ABS, LDA(ZP,X), etc.. and comma-in the operand. The mnemonics just compile the appropriate machine-language op code byte. They don't need to even be in a separate vocabulary because they don't conflict with anything else in Forth. For example, AND is always in Forth but if you want the assembly AND, it'll have an address mode associated with it, like AND_ZP or AND#. The branches were a minor challenge, but still not complicated because the assembler in Forth is not normally used for large applications, only writing primitives, runtimes, maybe ISRs, and things like that. I am working on making my branching method more user-friendly though. When I thought of this, I was able to initially write the assembler in an evening. It made me wonder why I didn't do it years earlier. It has been so handy.
However, with subroutine threaded code, inline assembly is available at any time with [ and ]. As I've gained experience, it has become clear to me that an ordinary postfix assembler is the more natural and elegant solution. With a prefix assembler, you need to finish the last instruction and I usually reset the assembler before the first instruction just in case (so it won't store bytes). When you first encounter Forth and postfix notation, you can either think "I'm not comfortable with postfix; I'm going to make Forth behave in a way that I'm more familiar with" or you can simply learn how to work with postfix. I think the decision to use a prefix or a postfix assembler with a subroutine-threaded Forth falls into a similar category.
kc5tja wrote:
APL, J, and K can be implemented with rather trivial interpreters, and still achieve excellent speeds.
BASIC interpreters, on the other hand, tend to be slow. The emphasis of most seems to be the first word of their acronym -- Beginner's -- and I can't really fault slow interpretation when fast interpretation wasn't a goal in the first place. BASIC bears more of a resemblance to other programming languages -- superficially -- than Forth and its postfix nature. So the perception, unfair as it is, is that interpretation is slow, unless you use Forth, no matter how many exotic programming languages exist as counterexamples. A lot of people like to dismiss interpretation by saying that interpreters don't offer the benefits of a good compiler, even though it is equally true that compilers don't offer the benefits of a good interpreter.
kc5tja wrote:
Excellent! This is what I expected to see. I hadn't realized that this was already done. As far as I was aware, AppleBASIC for the Apple IIs didn't do this (at least, I don't remember them doing it), but then again, it was also floating point BASIC too, with the AppleDisk system. Not sure if that made any difference.
Integer BASIC, on the other hand, was replaced in ROM by Applesoft starting with the II+, the second machine in the Apple II line. The only official Integer BASIC documentation was a BASIC tutorial manual (which called it Apple BASIC, rather than Integer BASIC) that didn't even cover all of the commands! Interestingly, the only source code for Integer BASIC was handwritten and hand-assembled by Wozniak himself! (Evidence of this was apparent when the ROM was disassembled. For example, the code would jump from point A to point B back to point A just to insert a single instruction, whereas with an assembler, that instruction would be inserted in the intended place and the remaining code would be moved accordingly.) This was no small task, since size of the object code was about 5k. Ironically, Apple computer published a lot of their early source code, but the handwritten source code prevented a golden opportunity to share a unique approach. (A few adventurous types did some disassembly and published their findings in the form of magazine articles, so some of the internals of Integer BASIC eventually became known.)
As I alluded to in my earlier post, there were several places the efficiency of the Integer BASIC interpreter could be improved (and there were a handful of minor bugs), but the concept itself was quite elegant. I've done enough hand-assembly (nothing anywhere near that long, though) to cut anyone who assembles a 5k program by hand some slack in terms of efficiency.
Incidentally, both BASICs preceded the Apple disk drive. So the DOS took some fairly unconventional steps to be accessible from either of these ROM-based BASICs, neither of which was designed with existence of DOS in mind.
kc5tja wrote:
Bytecode/tokens is just "token-threaded" -- several Forth implementations have been implemented token-threaded. The most popular of which is OpenFirmware, actually.
kc5tja wrote:
However, with that said, in my experience, recompiling software in Forth is so fast that the application I just beckoned has already been compiled before my finger leaves the ENTER key (assuming your Forth compiler's dictionary lookups are sufficiently efficient). Therefore, the issue of addresses, literally, is a complete non-issue for me.
kc5tja wrote:
What? Subroutine threading takes 3 bytes to store a reference to a word on the 6502, while both direct and indirect threading take 2. The numbers don't lie. Subroutine threading is smaller only for colon definitions with less than four words in the body. At 4 words, the overhead is the same, and beyond 4 words, ITC/DTC is smaller.
Here are some of the reason why STC is not as space inefficient as it seems, along with some potential space optimizations for the 6502. The code below assumes the typical 6502 data stack implementation (i.e. how FIG-Forth implements it), and (unlike FIG-Forth) separated heads (so that one STC -- and for that matter DTC -- primitive can fall through to another). All of the code is untested.
First, there are those things that take the same amount of space in STC as ITC/DTC. The size of a head doesn't depend on threading. ." String" will usually compile an inline counted string whose size doesn't depend on threading (the preceding JSR PDOTQ will of course be larger than a DW PDOTQ). This doesn't affect the difference in size between STC and ITC/DTC, but it does affect the ratio.
Second, at a speed penalty, you can implement constants and variables as a JSR followed by a DW which is the same as DTC and just 1 byte more than ITC (5 bytes vs. 4 bytes, rather than 3 vs. 2). Literals can also be implemented this way which is 5 bytes (STC) vs. 4 bytes (ITC/DTC). Again, this affects the ratio of sizes rather than the difference.
Third, there are high level STC constructs that take less space than their ITC/DTC counterparts. An unconditional branch (compiled by AHEAD or AGAIN) is 3 bytes (JMP destination) with STC, vs. 4 bytes (DW BRANCH,destination) with ITC/DTC. Likewise, a deferred word is 3 bytes (JMP address) with STC vs. 4 bytes (DW DO_DEFER,address) with ITC/DTC.
Fourth, since primitives take less space in STC than ITC/DTC, the ratio of the number of primitives to the number of high-level words affects the total size of STC vs. the total size of ITC. An STC primitive has 4 fewer bytes of overhead than an ITC primitive, so if an "average" high-level word is 4 bytes longer with STC than DTC, a simple 50/50 split of primitives and high level words makes the total size of DTC and ITC (roughly) equal (of course, there will be other factors).
Fifth, since STC has no NEXT, DO_COLON, or EXIT routine, there are that many fewer total bytes in an STC Forth. Counting the cold start code that prepares the zero page for the NEXT routine (i.e. storing a $6C at W-1), these routines take roughly 60 bytes in FIG-Forth (not counting any debugging code). That's 15 "average" STC high-level words just to break even.
Sixth, STC lends itself to optimizing primitives for space better than ITC/DTC. For example, you can implement the standard words 1-, ABS, NEGATE, and INVERT as follows:
ONEMINUS LDA 0,X
BNE ONEM1
DEC 1,X
ONEM1 DEC 0,X
RTS
ABS LDA 1,X
BNE ABS1
NEGATE JSR ONEMINUS
INVERT JSR INV1
INV1 LDA #$FF
EOR 0,X
STA 0,X
INX
ABS1 RTS
AND LDA #$35
BNE MATH
OR LDA #$15
BNE MATH
XOR LDA #$55
BNE MATH
MINUS JSR NEGATE
PLUS CLC
LDA #$75
MATH STA MATH2
JSR MATH1
MATH1 LDA 2,X
MATH2 ADC 0,X
STA 2,X
INX
RTS
Seventh, there are several relatively common high-level sequences that can be replaced by shorter inline assembly sequences. For example, with ITC/DTC, the sequence DUP 0< IF would typically compile to DW DUP,ZLT,QBRANCH,destination but with STC, it could be implemented in 4 fewer bytes with:
LDA 0,X
BPL label
LDA 0,X
ORA 1,X
BNE label
Eighth, one high-level word can fall through to another, which will save 3 bytes. For example, with ITC, the high level definitions : z a b ; : y c z ; compiles to:
z: DW DO_COLON ; JSR for DTC
DW a
DW b
DW EXIT
y: DW DO_COLON ; JSR for DTC
DW c
DW z
DW EXIT
z: JSR a
JMP b
y: JSR c
JMP z
y: JSR c
JMP z
z: JSR a
JMP b
Ninth, the definition : z BEGIN a WHILE b REPEAT ; usually is not optimal because the unconditional branch (compiled by REPEAT) will be executed multiple times. By rearranging the definition to : z AHEAD BEGIN b [ 1 CS-ROLL ] THEN a UNTIL ; the unconditional branch is executed just once. Since there is no DO_COLON routine with STC, the AHEAD can be eliminated (saving 3 bytes) as follows:
zee0: JSR b
zee: JSR a
JSR QBRANCH ; prepare Z flag and pop data stack
BEQ zee0
RTS
Finally, I should point out that using these optimizations does not necessary mean that the compiler must be more sophisticated (and therefore larger). The alternative is to optimize manually by inserting the optimizations yourself. However, adding a few short definitions helps and also makes the code more readable. Most Forth compilers do very little optimization, leaving it up to the programmer to know the most efficient way of doing things. For example, it is up to the programmer to use the single word 1- instead of the two word sequence 1 -.
Of course, there are things that will take more space with STC (manipulating the return stack is one example), but the bottom line is with STC, there are a lot of options available if you wish to optimize for space.
kc5tja wrote:
I don't think anyone was contesting this. I know I certainly wasn't. But it nonetheless is true that STC will consume more space (for a 16-bit Forth implementation on a 6502) than a DTC implementation for the average program size. The average number of words in a colon definition turns out to be 8 in most Forth programs, so each definition, one can estimate, will have four bytes of "overhead" to them compared to other methods. Times the number of definitions, and you can see that it adds up...slightly.
Based on some of the optimizations listed above, I think there is even a chance that it's possible to write a STC Forth that is actually smaller than a ITC or DTC Forth on the 6502, given some reasonable ground rules, and assuming that both have the same functionality and both were optimized strictly for space. It'd be quite a challenge, though.
dclxvi wrote:
For what it's worth, most OpenFirmware environments will run-time recompile token-threaded representation into a more native and faster executing form.
- GARTHWILSON
- Forum Moderator
Sheesh! And I thought I and Samuel were long-winded! That was great though. Thanks for the detailed examples and points of clarification. I guess I can quit saying STC is less memory-efficient. I hope you'll have opportunities to recycle your "book" and get more uses out of it for your time. Although I'm not going to start over on my 65816 Forth because of it, it does give some ideas for future improvements.
I did "cheat" a little though and do some optimizations in my '816 ITC Forth that are similar to what you're talking about. For example, nested structures sometimes result in two or more consecutive branches. Why not just branch to the intended destination the first time. The only disadvantage I could see for some of these things is that if the user wants to use SEE to examine the insides, there could be some confusing results. SEE terminates when it comes to the unnest at the end of a secondary; but there won't necessarily be an unnest in some cases, especially if one word branches right into another without going through unnest-nest or other such overhead. I could probably also expand my inventory of (probably headerless) words that replace occurrences of things like the DUP 0< IF that you mention. I know it's taboo in Forth, but there's nothing that says the code is supposed to be readable after being de-compiled, and we are after all talking about internal optimizations. If the user wants it readable, he'll have to look at the source code I provide that shows what it looks like before these optimizations are carried out.
Something I found so helpful with the '816 is that since it can handle 16 bits at a time, a lot of words that would have taken so much extra space if defined as primitives on the '02 became easy with the '816, resulting not just in faster code but even shorter and easier to write in many cases—the best of all worlds. Because of this, my '816 Forth has around 350 primitives. Having so much higher percentage of the kernel in primitives dramatically reduces the number of times NEXT, nest, and unnest get executed to carry out a particular job, further speeding things up.
- GARTHWILSON
- Forum Moderator
Since we've hijacked pbug's "How to make a BASIC compiler?" long enough now and quickly turned it into Forth material that's way too advanced for those who are new to Forth, why don't we continue this thread under the Forth section of the forum. I'll start a new subject and call it "cont. from BASIC compiler". I am looking forward to more.
<later> Ok, it's at http://www.6502.org/forum/viewtopic.php?p=3336#3336
pbug, you can go back to talking about BASIC compilers. I for one will still be interested—even if I do think you'd be better off going to Forth
It occured to me that no one has mentioned the BASIC compiler for FIG-Forth in Forth Dimensions. Early issues of Forth Dimensions are online at www.forth.org in the form of .pdf files. The article appears on p. 178 (the .pdf page number, p. 175 is printed at the bottom of the page itself) of the Volume 3 .pdf file (~12MB!). There is also a related article on converting infix to postfix on p. 14 of the Volume 4 Number 6 .pdf file (~3MB). There are also source code files around, so you don't have to type it in from the article.
Anyway, you can use the FIG-Forth source code in the (6502.org) Repository with the Forth Dimensions article to get an example of a BASIC compiler for the 6502. It's the same concept as converting infix to postfix at parse time that I mentioned in an earlier post. The BASIC program (to be compiled) will seem to be spaced a little strangely as compared to a traditional BASIC, because the compiler uses the ordinary FIG-Forth parsing method, i.e. space delimited words. You could write your own parser if you wish to change this. Also, it will compile BASIC to (indirect threaded) Forth, but it could be altered to compile to assembly (or to translate the Forth into assembly).
Just an update here: it seems the forth.org website no longer has direct links to the FD scans.
You can still find them at the direct URL:
http://www.forth.org/fd/contents.html
teamtempest
Ruud wrote:
I'm working on a Pascal compiler but one written in Pascal. The idea is that, once compiled on the PC, the user can improve and compile it on the native machine.
But I must confess there is a little snag in it: the executable so far is over 200 KB and I don't think it will ever be small enough to run it on a C64, 8032, Apple ][ or any other 6502 machine. The Apple2GS or a C64/128 with SuperCPU (=65816) could cope with it.
http://homepages.cwi.nl/~steven/pascal/
It was used as the basis of the UCSD Pascal compiler, which certainly ran on the 6502.
Also, don't forget that early compilers couldn't fit into available core in the early days even on "big machines" like the PDP series. C is an example, where you had a master driver program, cc, which in turn invoked c1, c2, and as in that order, to lex and parse, then to generate code for, then to assemble (respectively) the binary you're creating.
If you can split your one executable into multiple components, or even somehow implement an overlay system, that will allow you to run your compiler on the C64 natively.
teamtempest
dclxvi wrote:
My BASIC was partly inspired by Apple (Integer) BASIC, which was written by Steve Wozniak. Wozinak used ideas from HP BASICs (he had worked at HP), and of course HP was well-known for their stack-oriented RPN calculators. "Integer" BASIC is really not all that far away from the address interpreter you suggest. It uses a sophisticated parser which does all of it's syntax checking at parse time rather than execution time. It also converts constants at parse time to their twos complement reprepresentation rather than storing them as ASCII. Therefore, unlike many BASICs (e.g. EhBASIC and Applesoft) you never got a SYNTAX ERROR at run time, and you weren't converting constants (e.g. the statment PRINT 99) or line numbers (e.g. the statement IF A < B THEN 10) each and every time they were encountered.
There were other things that could have been handled at parse time, but weren't, such as checking for too many parentheses in an expression, and determining whether you needed the address of a variable so you could store a value in it (e.g. a LET or an INPUT statement) or if only the contents of the variable were needed (e.g. PRINT A). (Determining the latter at parse time would have sped up expression evaluation considerably.)
http://users.telenet.be/kim1-6502/6502/absb.html
Although it isn't perfect either:
http://www3.sympatico.ca/maury/other_st ... basic.html
teamtempest wrote:
There is also Atari BASIC, which contains a lot of these same ideas:
Although it is perfect either:
teamtempest wrote:
Have you looked at the P4 compiler?
But thanks anyway!
___
/ __|__
/ / |_/ Groetjes, Ruud
\ \__|_\
\___| URL: www.baltissen.org
nitrofurano
Re: How to make a BASIC compiler?
i was trying to help extending Boriel’s ZX-Basic Compiler to 6502 - my humble efforts are at https://gitlab.com/nitrofurano/6502basiccompiler - the official Boriel’s ZX-Basic Compiler git repository is at https://bitbucket.org/zxbasic/zxbasic - whatever help on this is indeed hugely appreciated!
(just imagine, an ansi-basic cross-compiler coded in Python, able to run on whatever actual operating system, like GNU/Linux, BSD or MacOS-X)
