It is currently Fri Nov 22, 2024 11:42 am
Post new topic Reply to topic  [ 109 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8  Next
 Post subject: Re: The RTF65002 Core
PostPosted: Fri Apr 04, 2014 4:44 am
The RTF65002 core has been updated to add 65c816 backwards compatibility. It's currently untested, but synthesizes. The core size increased by about 20% and slowed down to 40MHz.
Code is on Github.
http://www.finitron.ca
PostPosted: Fri Apr 04, 2014 9:22 am
Wow, nice work - could this be the first HDL core with '816 operation?
Here's the link: https://github.com/robfinch/Cores/tree/ ... 5002/trunk
What's the license Rob?
PostPosted: Fri Apr 04, 2014 10:33 am
Wow, nice work - could this be the first HDL core with '816 operation?...
The T65 cpu has limited 65C816 compatibility. Not sure how limited though... Good job Rob!
PostPosted: Sun Apr 06, 2014 7:49 am
The license is currently LGPL.
I've found and fixed several bugs in the core over the last couple of days. The '02 and 32 bit modes seem to work still as I can run my test system, but I really need some '816 code for testing.
PostPosted: Sun Apr 06, 2014 9:44 am
> LGPL
Great - thanks!
Here's a short 65816 program:
viewtopic.php?p=15531#p15531
It might not be terribly suitable as a test...
Here's a pointer to a C compiler: viewtopic.php?p=8321#p8321
I wonder if rigging up an Apple IIGS type environment would be useful, and then running the ROMs for that machine, as a test?
PostPosted: Mon Apr 07, 2014 7:37 pm
I got it to work as spec'd I think. It displayed 359 zeros on the screen :) Methinks there is a software bug.
I managed to fix several "hardware" bugs while trying to run this program.
I think this would be quite an undertaking, but it might be about the best way to test. Likely at least have to mod the keyboard/mouse code to use a PC style interfaces. Got to wondering what a bare-bones GS system would look like.
I have an real IIe sitting at home with an 65C802 cpu in it.
PostPosted: Mon Apr 07, 2014 7:53 pm
(It should print the digits of pi - 314 zeros would be forgivable, or even 360, but preferably the first digit should be 3.)
PostPosted: Tue Apr 08, 2014 9:09 am
I haven't figured it out yet. There must be an instruction that's failing. When I dump the P array it's all zeros. So candidates are a store that stores zero, (sta P-1,x) or perhaps a shift/rotates fails when doing multiplication or division. It's slow going debugging at the moment because it take 1 1/2 hours place and route. It does seem to iterate properly.
I repost the PI calc code in case I copied it wrong somewhere.
P   EQU      2
Q   EQU      1193*2 + 2
R   EQU      Q + 2
SSS   EQU      R + 2
Test816:
      clc
      xce
      cpu      W65C816S
      rep      #$30      ; acc,ndx = 16 bit
      mem      16
      ndx      16
      lda      #$1800      ; setup stack pointer
      tas
      jsr      INITSUB
      ldx      #359
      ldy      #1193
L1S:
      phy
      pha
      phx
      stz      Q
;      txa
;      ldx      #5
;      wdm
;      xce
;      cpu      RTF65002
;      jsr      PRTNUM
;      clc
;      xce
;      cpu      W65C816S
;      rep      #$30
;      plx
;      phx
      tya
      tax
L2S:
      txa
      jsr      MULSUB
      sta      SSS
      lda      #10
      sta      Q
      jsr      ADJ1SUB
      lda      P-1,x
      jsr      UNADJ1SUB
      jsr      MULSUB
      clc
      adc      SSS
      sta      Q
      txa
      asl
      dea
      jsr      DIVSUB
      jsr      ADJ1SUB
      sta      P-1,x
      jsr      UNADJ1SUB
      dex
      bne      L2S
      lda      #10
      jsr      DIVSUB
      sta      P
      plx
      pla
      ldy      Q
      cpy      #10
      bcc      L3S
      ldy      #0
      ina
L3S:
      cpx      #358
      bcc      L4S
      bne      L5S
      jsr      OUTPUTSUB
      lda      #46
L4S:
      jsr      OUTPUTSUB
L5S:
      tya
      eor      #48
      ply
      cpx      #358
      bcs      L6S
      dey
      dey
      dey
L6S:
      dex
      beq      L7S
      jmp      L1S
L7S:
      jsr      OUTPUTSUB
      wdm
      xce
      cpu      RTF65002
      rts
      cpu      W65C816S
INITSUB:
      lda      #2
      ldx      #1192
IS1:
      jsr      ADJSUB
      sta      P,x
      lda      P,x
      eor      #48
      jsr      OUTPUTSUB
      eor      #48
      jsr      UNADJSUB
      dex
      bpl      IS1
      rts
MULSUB:
      sta      R
      ldy      #16
M1S:   asl
      asl      Q
      bcc      M2S
      clc
      adc      R
M2S:   dey
      bne      M1S
      rts
DIVSUB:
      sta      R
      ldy      #16
      lda      #0
      asl      Q
D1S:   rol
      cmp      R
      bcc      D2S
      sbc      R
D2S:   rol      Q
      dey
      bne      D1S
      rts
ADJSUB:
      pha
      txa
      asl
      tax
      pla
      rts
UNADJSUB:
      pha
      txa
      lsr
      tax
      pla
      rts
ADJ1SUB:
      pha
      txa
      asl
      tax
      pla
      dex
      rts
UNADJ1SUB:
      pha
      txa
      lsr
      tax
      pla
      inx
      rts
OUTPUTSUB:
      wdm      ; switch to 32 bit mode
      xce
      cpu      RTF65002
      jsr      DisplayChar
      clc      ; switch back to 816 mode
      xce
      cpu      W65C816S
      rts
PostPosted: Tue Apr 08, 2014 9:34 am
As you have a 65802 system, can you add some instrumentation to the code and debug the difference that way? Going around a 90m P+R loop does sound arduous!
PostPosted: Thu Apr 10, 2014 4:32 am
The 802's not a system I've really used a lot in the past. I got it because I wanted the case at one point, but never really got around to using it. 90m P+R isn't really acceptable to me, so I tweaked the core a little bit and reduced the time to 10m. It's amazing how the slightest change can cause the P+R time to vary by a lot. It's because the core is complex so a slight change in routing makes/breaks it.
But, phew! I finally fixed the bug and now it works ! It displays the digits of PI. The bug was in storing 16 bit data, it would place the same data for both the first and second write cycles. It didn't matter with eight bit data.
PostPosted: Thu Apr 10, 2014 8:53 am
That's great! And you got a quick-build option out of it too...
PostPosted: Fri Apr 11, 2014 12:52 am
Rob Finch wrote:
...90m P+R isn't really acceptable to me, so I tweaked the core a little bit and reduced the time to 10m. It's amazing how the slightest change can cause the P+R time to vary by a lot. It's because the core is complex so a slight change in routing makes/breaks it...
What are the spec's of your desktop machine Rob? That is a terrible time to wait! Also, what version of ISE are you using?
PostPosted: Fri Apr 11, 2014 3:54 am
I'm using a quad-core 3.4GHz machine (3 levels of caches) 12GB RAM with Webpack 14.4 (on Windows 8). Webpack sometimes describes the routing as "heavily congested" which may mean there is too much combo logic with not enough regs. Webpack reports using 600MB memory for the design.
I can easily do other things on my desktop (like browsing the internet or working on the software) while waiting. It's just the turn-around time for testing a bug fix can be annoying sometimes.
One issue with using a larger FPGA is the undoutbedly longer P+R times.
PostPosted: Tue Apr 22, 2014 5:57 am
RTF65002 now incorporates a spinlock (SPL) instruction. This instruction continuously polls a memory location until the contents of the memory location are non-zero.
The memory must be set to non-zero by another processor OR by an interrupt routine. (The SPL instruction is interruptible).
The instructions replaces spinlock code that looks like:
j1:
   lda   semaphore+1
   beq  j1
The code becomes just:
   spl   semaphore+1
The idea is to use the instruction in conjuction with hardware semaphoric memory. Note the new code is two bytes shorter and several cycles faster as a branch has been eliminated.
PostPosted: Tue Apr 22, 2014 6:26 am
If you execute a
        spl  65002
do you trigger an Easter Egg? :P :wink:
Mike
