6502 Stock
BitWise
In Memoriam
6502 Stock
Post by BitWise »
My current stock of 6502 parts.
Rockwell and Synertek parts are pulls. WDC parts were purchased direct or through a UK distributor.
6502 Parts.xlsx
(11.07 KiB) Downloaded 168 times
Andrew Jacobs
Re: 6502 Stock
Thanks. I put the link to this in the "65xx parts sources" head post.
Edit, 1/2/20: BitWise posted an updated inventory at viewtopic.php?p=72448#p72448 .
Re: 6502 Stock
However, the file can't be opened unless one has a recent version of MS Excel.
Re: 6502 Stock
I opened it in Open Office 3.2, from 2010, from Oracle, under Linux, with no problem. I don't use Microsoft software.
Re: 6502 Stock
(Microsoft offer a freely downloadable viewer for their newer formats)
Re: 6502 Stock
I have it but it didn't want to open that file.
What I'm really getting at is any files that are posted on publicly-accessible sources really should be in neutral formats.
Re: 6502 Stock
Here's a cropped screenshot:
barrym95838
Re: 6502 Stock
Post by barrym95838 »
You should write us up a petition (in a neutral format) and I'll be one of the first to sign it. That should really shake things up a bit around here! :lol: :wink:
Mike
BitWise
In Memoriam
Re: 6502 Stock
Post by BitWise »
But it is in an open standard format.
http://officeopenxml.com/
:wink:
Andrew Jacobs
BillO
Re: 6502 Stock
Post by BillO »
Not to add fuel to the fire, but I can open it with Excel 2000 with the updates. I am not sure if the updates are still available from MS or not, but they are probably out there somewhere.
Aslak3
Re: 6502 Stock
Post by Aslak3 »
Agree. Also, files should be in the simplest format needed to express what needs to be expressed, in this case a csv format would probably do.
But that is enough of format wars ;-)
Lawrence
