The last time I tried to interface an SD card I did in in hardware, using a shift register on an FPGA and a Picoblaze core to read data. I don't remember the details other than it was very touchy, worked with a small selection of cards I have on hand, and was an incredible pain in the butt (prone to not working for no reason, then working again). I somehow got it working well enough for the project, but had always meant to go back at figure it out. So here goes.
This time I decided to bitbang SPI (since I'm running at 45MHz I can do it pretty fast). SD Cards are pretty lax about operating speed - at least some of my cards initialize at 2Hz!. Also, clock jitter seems to not matter much as far as I can tell. With software I can monitor the signals and make adjustments easier. And I can share the results - this can be done with any 6502 that has 3 output lines and 1 input lines available.
There is a lot of conflicting information about connecting SD cards, and the flavor of SPI to be used. Some indicate mode 0, some mode 3. I finally got consistent results using mode 3 - clock is normally high, transitions happen on the falling edge, and are sampled on the rising edge.
First thing: send 74 clocks to the card:
; Cold-start procedure - 74+ clocks
sd_cold:
jsr sd_clk_up ;normal=1
jsr sd_data_up ;normal=1
jsr sd_sel_dn ;assert SEL
sd_init:
jsr tick
ldx #74 ;output 74 clocks
sd_init_loop: jsr sd_clk_dn
jsr tick
jsr sd_clk_up
jsr tick
dex
bne sd_init_loop
jsr tick
jsr sd_sel_up
; For some reason, it really helps to send 8 more
sd_init1:
lda #$FF
jsr sd_op
rts
; read/write a single byte.
sd_op:
sta TEMP ;preserve byte
ldx #8
sd_op1:
jsr sd_clk_dn
; output a bit and shift TEMP
lda TEMP ;load rcv/transmit byte
sta SD_MOSI ;store high bit to SPI
clc
rol a ;<< Free up low bit
sta TEMP ;and save
jsr tick
;---------UP----------------------
jsr sd_clk_up
; input low bit
lda SD_MISO ;read low bit from SPI
ora TEMP ;or in current value
sta TEMP ;and save back
jsr tick
dex
bne sd_op1
jsr tick
jsr sd_data_up ;data up is normal
lda TEMP ;return value
rts
After sending a command, the response has the high bit 0, but first, one or more $FF may be sent. So I send $FF and check return values like this:
; wait for an R0 response. R0 has bit 7 clear...
sd_R0: lda #$FF ;send $FF
jsr sd_op
rol a ;high bit set?
bcs sd_R0 ;continue waiting
ror a
rts
init: jsr sd_cold ;intialize the SD card
jsr sd_sel_dn ;select
lda #$40 ;CMD0 - reset and idle
jsr sd_op
lda #$00
jsr sd_op
lda #$00
jsr sd_op
lda #$00
jsr sd_op
lda #$00
jsr sd_op
lda #$95
jsr sd_op
ldy #8
init1: lda #$ff
jsr sd_op
jsr hex_out
dey
bne init1
jsr cr
jsr cin
xxx: jmp init
Here is where trouble starts. Out of 4 cards I have on hand, only one returns the expected
FF 01 FF FF FF FF FF FFAnother card returns
3F 01 FF FF FF FF FF FF3F has a low high bit, so it would be confused with a proper R0 response byte... However, running init again returns
BF 01 FF FF FF FF FF FFThis is disturbing, but more acceptable (BF is meaningless and would be filtered).
This reminds me of the trouble I had the last time... I could just skip any bytes with high bit set, and re-initialize if the response is not 01. However it could be indicative of some kind of a problem with the shift registers getting out of sync. It might bite me later...
I will proceed as if it makes sense to re-initialize until a reasonable response is obtained.
