Retro SYM
Retro SYM
To celebrate the Synertek Sym's 35th anniversary this year, I decided to play with the concept of a Retro SYM project.
In thinking what the designers may have done if the product line had continued past the SYM-2, while taking into account later technology beyond the 80's, I came up with the following features that such a project should have..
USB interface
RS232 interface, utilising a Max232 style driver and 6551 ACIA chip
MicroSD card slot for storage
GAL address decoding
DIP switches for the address decoding selection
0.1" Headers for the E, A and AA connector and various jumpers
Tact Switches for the Keypad
TTL Oscillator in place of a Crystal for the clock.
Ability to use large capacity EPROMs, Flash memory and SRAM
Many weekends later, this is what I came up with.
USB interface
- BigDumbDinosaur
Re: Retro SYM
USB interface
https://dl.dropbox.com/u/103294228/SYMtiff.tif
USB interface
Your link didn't work, so I fixed it in this reply. Your going to build one of these?
Re: Retro SYM
What's the advantage of using a TTL oscillator over using a crystal?
- BigDumbDinosaur
Re: Retro SYM
Convenience, lower parts count and less board real estate.
Re: Retro SYM
Yes, I am intending to build one of these. Still finalising the PCB design at this stage.
The reason for going down the TTL Oscillator route, is because 1MHz crystals are becoming difficult to obtain.
For that matter, so are 1 MHz Oscillators, but at least for the moment RS Components and Element14 (Farnell) still show them in their catalog.
Re: Retro SYM
I thought circuit based oscillators were not as stable or regular as crystal oscillators. Am I mistaken? Or was that a "it used to be true but not any more" kind of thing?
- GARTHWILSON
- Forum Moderator
Re: Retro SYM
- BigDumbDinosaur
Re: Retro SYM
If you buy a pre-made oscillator in a can, that should all be taken care of for you. I have not shopped for one in years, but I remember they used to be current hogs, and just the oscillator might take close to 100mA! I expect that problem has been taken care of by now, but it would be good to check the specifications.
The can oscillator (half-size) I use in POC draws about 18-20 MA. These things always work without any problem.
Re: Retro SYM
Re: Retro SYM
Boards received from Fab.... ready to build!
Re: Retro SYM
Wow! -- the SYM-3 board looks terrific, andysa. Are you going to stuff it with 74LS series glue chips (per the silk-screen legends)? I know I personally would use CMOS wherever possible (74HC or 74HCT series), but maybe you feel that would dilute the "retro" feel.
cheers,
cheers,
Re: Retro SYM
jdrose wrote:
Well done.
Where can we order a PC Board?
I'm however thinking that the supply of 6532's will be sticking point...
Re: Retro SYM
Good point. But you only need one.
If you come across an Atari 2600 you can desolder the 6532 out of that. And they do show up on eBay once in a while.
Are the WDC W65C22 chips drop-in replacements for the 6522 chips required by this board?
http://www.westerndesigncenter.com/wdc/w65c22-chip.cfm
Re: Retro SYM
1pcs R6532P R6532 8-BIT Microprocessor From adeleparts2010 on eBay $3.80 plus $3.00 shipping.
