My Arduino-Based 6502 Simulation/Emulation...thing?
Re: My Arduino-Based 6502 Simulation/Emulation...thing?
Right - getting commonality is a big step forward.
One of my bugs was setting the flags for TXS, because it's an exception to the T commands.
(see http://www.visual6502.org/JSSim/expert. ... a&steps=24)
Well, that was fun.. I ported what I could over... and now, it's sadly more broken then before. Because I've changed so much, I'm attaching the new C++ code the core uses. I'm also posting the the current cc65 makefile and active dependencies for the Monitor.
Just to let you know, this is the output I get from the help screen now...
That loops forever. I'll start stepping though the core after work tomorrow to fix up the opcodes. It's pretty late now.
posted below is my work so far
65C02 Monitor v5.1.1 (12-02-12) Ready
By Lee Davison and Joshua Walker
(Press ? for help)
Current commands are :
Syntax = {} required, [] optional, HHHH hex address, DD hex data
[HHHH][ HHHH]{Return} - Hex dMPJSRLDALDXLDYLSRNOPORAPHAPHPPHXPHYPLAPLPPLXPLYROLRORRTIRTSSBCSECSEDSEISTASTXSTYSTZTAXTAYTRBTSBTSXTXATXSTYAWAISTPBBRBBSRMBSMB.DB.DW.DS???
- Attachments
- sbcos.s
- SBCOS Monitor for ca65
- (83.09 KiB) Downloaded 134 times
- sbc.s
- SBC root assembly code
- (344 Bytes) Downloaded 128 times
- makefile.txt
- ca65 makefile for sbcos (Remove the .txt)
- (154 Bytes) Downloaded 122 times
- joshxcore.cpp
- The Core 6502 Emulator for the Arduino (Broken)
- (62.59 KiB) Downloaded 118 times
Nope, I'm stuck again. I'm trying to fix the display error above with the help command.
I've obviously botched up the flags. The reason why I think that's the case is because it was a cute "addition" I added to the code without making sure the other code worked first.
I also don't have a backup if the code that "worked" before I made the changes...
The good news is what's broken is a small bit of code...
Cool, just two opcodes to tear apart. INC and BNE
The data it's using is here...
What is happening in the code is that when AddPtr is wrapping around, and as opposed to incrementing to the next line, it's pointing WAY up above in another text section. It then reads that all the way down and loops again.
Here's my relevant code for INC ZP
and to be complete, here's BNE
which uses this call...
now, here's where it gets strange... These all should work, but I can't see what it's doing wrong
Thinking it's the flag tester I replaced it with the old code...
and it does the same thing.
I'm stuck...
Help_Cmd: lda #<HelpTxt ; lower byte - Menu of Commands
sta AddrPtr ;
lda #>HelpTxt ; upper byte
sta AddrPtr+1 ;
bra Help_Cmd3 ;
Help_Cmd4: cmp #$7e ; "~"
beq Help_Cmd1 ;
jsr Output ;
bra Help_Cmd2 ;
Help_Cmd1: jsr Print_CR ;
Help_Cmd2: jsr Inc_AddrPtr ; <--- This is where it's breaking
Help_Cmd3: lda (AddrPtr) ;
bne Help_Cmd4 ;
rts ;
Inc_AddrPtr: INC AddrPtr ; increments AddrPtr
BNE Inc_addr1 ;
INC AddrPtr+1 ;
Inc_addr1: RTS
.byte "JMP" ;1C
.byte "JSR" ;1D
.byte "LDA" ;1E
.byte "LDX" ;1F
.byte "LDY" ;20
.byte "LSR" ;21
.byte "NOP" ;22
.byte "ORA" ;23
.byte "PHA" ;24
.byte "PHP" ;25
.byte "PHX" ;26
.byte "PHY" ;27
.byte "PLA" ;28
.byte "PLP" ;29
.byte "PLX" ;2A
.byte "PLY" ;2B
.byte "ROL" ;2C
.byte "ROR" ;2D
.byte "RTI" ;2E
.byte "RTS" ;2F
.byte "SBC" ;30
.byte "SEC" ;31
.byte "SED" ;32
.byte "SEI" ;33
.byte "STA" ;34
.byte "STX" ;35
.byte "STY" ;36
.byte "STZ" ;37
.byte "TAX" ;38
.byte "TAY" ;39
.byte "TRB" ;3A
.byte "TSB" ;3B
.byte "TSX" ;3C
.byte "TXA" ;3D
.byte "TXS" ;3E
.byte "TYA" ;3F
.byte "WAI" ;40
.byte "STP" ;41
.byte "BBR" ;42 4Byte Opcodes
.byte "BBS" ;43
.byte "RMB" ;44
.byte "SMB" ;45
.byte ".DB" ;46 define 1 byte for assembler
.byte ".DW" ;47 define 1 word for assembler
.byte ".DS" ;48 define a string block for assembler
.byte "???" ;49 for invalid opcode
HelpTxt: .byte "~Current commands are :~"
.byte "Syntax = {} required, [] optional, HHHH hex address, DD hex data~"
.byte "~"
.byte "[HHHH][ HHHH]{Return} - Hex dump address(s)(up to 16 if no address entered)~"
.byte "[HHHH]{.HHHH}{Return} - Hex dump range of addresses (16 per line)~"
.byte "[HHHH]{:DD}[ DD]{Return} - Change data bytes~"
#define UMASK 0xFF
#define C_FLAG 0b00000001
#define Z_FLAG 0b00000010
#define I_FLAG 0b00000100
#define D_FLAG 0b00001000
#define B_FLAG 0b00010000
#define X_FLAG 0b00100000
#define V_FLAG 0b01000000
#define N_FLAG 0b10000000
void INC(int addr)
int value;
value = memReadByte( addr );
++value;
memStoreByte( addr, value&UMASK ); //mask off the lower byte
setNVflags(value);
//set zero and negative processor flags based on result
void setNVflags(int val)
if( val )
{regP &= ~Z_FLAG;}
else
{regP |= Z_FLAG;}
if( val & N_FLAG )
{regP |= N_FLAG;}
else
{regP &= ~N_FLAG;}
case 0xd0: // BNE
offset = popByte();
if (!zeroSet()) {jumpBranch(offset); }
break;
int zeroSet() { return regP & Z_FLAG;}
void setNVflags(int value)
if( value ) regP &= 0xfd; else regP |= 0x02;
if( value & 0x80 ) regP |= 0x80; else regP &= 0x7f;
I'm stuck...
You need to do the masking before you test the value.
This comment is not necessarily helpful for your current problem, but it might help in the future.
The function you are using to set the N and Z flags is named setNVflags() instead of setNZflags(). The BIT instruction sets the N and V flags, so at some future point you may have a conflict, and a lot of code to correct.
Michael A.
-Tor
It appears that the Addr+1 is getting decremented instead of incremented.
You may want to add some dumps inside your code to your LCD to show the pre/post values:
Another thought might be to define value as a char instead of int.
If INC works well, then check your lda (AddrPtr) to be sure the indirect is working right.
Have it dump the target address to the LCD to confirm.
void INC(int addr)
int value;
dmplcd(value); /* substitute your lcd dump code here */
++value;
setNVflags(value);
For the record, here's my INC:
private int setFlagsNZ(int i) {
status &= ~(ZERO_MASK + NEGATIVE_MASK);
if (i == 0) {
status |= ZERO_MASK;
if ((i & NEGATIVE_MASK) != 0) {
status |= NEGATIVE_MASK;
return i;
public void doInc(int addr, int value) {
int result = fetchByte(addr);
result = result + value;
if (result == -1) {
result = 255;
if (result == 256) {
result = 0;
setFlagsNZ(result);
putByte(addr, result);
public void INC(int addr) {
doInc(addr, 1);
public void DEC(int addr) {
doInc(addr, -1);
When doing bit wise operations on chars, don't they cast to ints in the process?
Oh, and BTW, you guys rock
- BitWise
- In Memoriam
Andrew Jacobs
progress... kind of
Fixed the flag issue, but bugs remain.
Looks like I have a bug in ROR (for the flag printing) and something is going funny with the list dump (4C is a JMP instruction, not an INX), however it sorts itself out later.
I don't think I'm setting carry right on the shifters.
(Press ? for help)
>R
PC=CD30 A=11 X=00 Y=BF S=6C P=FF (NVRBDIZC)=11111111 <----huh?
>E800L
E800- L 4C INX <----- Nope!
E801- LiL 4C E9 4C JMP $4CE9
E804- . 88 INX
E805- h E8 INX
E806- L9h 4C B9 E8 JMP $E8B9
E809- L6 4C B6 LDX $B6,Y
E80B- hL1 E8 4C B1 JMP $B14C
E80E- hL" E8 4C A2 JMP $A24C
E811- hL. E8 4C 99 JMP $994C
E814- hL. E8 4C 95 JMP $954C
E817- hL< E8 4C 3C JMP $3C4C
E81A- iLB E9 4C 42 JMP $424C
E81D- iL4 E9 4C 34 JMP $344C
E820- iL. E9 4C 2E JMP $2E4C
E823- iL8 E9 4C 38 JMP $384C
E826- iLA E9 4C C1 JMP $C14C
E829- hLE E8 4C C5 JMP $C54C
E82C- h P E8 20 50 JSR $5020
E82F- C= 43 3D 20 AND $203D,X
E832- A 20 41 EOR ($41,X)
Hi !
I'm new in this forum; actually I have just registered to be able to post here.
I'm becoming more and more interested about this project, I was wondering how much memory is needed by the emulator itself.
Would it be possible to run it with an Arduino Mega, without the memory expansion ?
My idea would be to leave only the minimum memory for the 6502 space, if I'm not wrong (it's been a long time since I used a 6502 for the last time), with 1kb it should be enough.
Thanks !
Thanks !
Old computers with IDE drives are a good source of ribbon cable. I deliberately made the expansion port on my little Orwell machine with a 40 pin IDE type connector just so I can reuse old PC IDE cables on it.
I used to have great fun with the special characters on those little LCDs. Doing small running men animations (think Loderunner) and the like.
As an extra goal make a little stand alone computer that can be used for something. I am using mine to review old 80s computer books.
Cool little project you've got there!
Simon
Simon
My 6502 related blog: http://www.asciimation.co.nz/bb/category/6502-computer
- BigDumbDinosaur
