Concept & Design of 3.3V Parallel 16-bit VGA Boards
ElEctric_EyE
Post by ElEctric_EyE »
What about in UG381, Select IO Resources User's Guide, where it talks about the IODELAY2 primitive? Also in the HDL library.
Seems like it uses the same delay elements in the IO section of the FPGA?
Arlet
Post by Arlet »
The IODELAY2 primitive was what I was thinking of. Reading a bit in UG381, I noticed that it has a calibration mode. It requires applying a known clock on the input pad, but that may be accomplished by writing a known pattern to SRAM and reading it back as a burst.
ElEctric_EyE
Interesting, seems like that way would use more resources. I started a thread in the Xilinx forums. I probably should have searched the forums first. I'll do now. :oops:
Arlet
Post by Arlet »
The IODELAY2 resources are already there, whether you use them or not. The calibration feature, assuming it is possible, would only take a modest amount of extra state.
ElEctric_EyE
Yes, I guess that calibration state is there for those that want to push the speeds such that when temperature changes start to affect performance, they could re-run the calibration. Personally, I'm not one that wants to push the speeds to that level. I'd prefer to find out what works across all temps. Seems like setting the simpler constraints values might be the way to go... But there is no discussion of what the values actually mean.
ElEctric_EyE
I just noticed an error I made using the pclk for the SyncRAM clock. I fixed that and use the dcm_clk100, now the pixels are appearing nice and small and square.
EDIT: So I noticed that
wire dcm_clk100;
wire clk;
are no longer needed, as the DDR FF and the buffer take the place of the wires.
ElEctric_EyE
Since I'm forced to learn proper Verilog syntax, and sometimes I feel like a monkey typing almost randomly to achieve some Shakespeare novel, I prefer typing as little as possible and so I think I am learning some shortcuts. But I've come across a shortcut that appears to work only sometimes. Other times ISE13.4 sees it as a straight "syntax error".
I will post Arlet's main.v module which I've modified with his permission. I've modified it even further today and the latest modifications meld the X & Y pixel counters into the output register for the external SyncRAM address. It works, but I'm posting not for questions about functionality (although that would be useful too!), but observe some of the syntax that ISE actually passes. But only sometimes. Early on, it let's me do
wire fifo_write,
     fifo_full;
but later on it will not accept the same syntax for:
wire xdone = (x == 639) && !fifo_full;
wire ydone = (y == 480);
wire [20:0] SRAtemp;
 * top level module
 * (C)2012 Arlet Ottens <arlet@c-scape.nl>
 *	 -modified by ElEctric_EyE-
module main(
    input clk100,
	 input [15:0] SRD,					//SyncRAM data
    output pclk_out,
	 output SRCLK,							//SyncRAM clock
    output [4:0] red,
    output [5:0] green,
    output [4:0] blue,
    output vsync,
    output hsync,
	 output reg DACBLANKn = 1,
	 output reg SRCS = 1,				//SyncRAM CS, active high
	 output reg WEn = 1,					//SyncRAM WE, active low
	 output reg [20:0] SRA				//SyncRAM Address
wire [15:0] rgb;
assign blue = rgb[4:0],
		 green = rgb[10:5],
		 red = rgb[15:11];
wire fifo_write,
     fifo_full;
reg [15:0] fifo_data;
wire pclk0,
     vtrigger;
/* pixel clock output using DDR flipflop */
ODDR2 ODDRA (
    .Q(pclk_out),
    .C0(pclk),
    .C1(~pclk),
    .CE(1'b1),
    .D0(1'b1),
    .D1(1'b0),
    .R(1'b0),
    .S(1'b0)
/* SyncRAM Clock output also using DDR flipflop */
ODDR2 ODDRB (
    .Q(SRCLK),
    .C0(dcm_clk100),
    .C1(~dcm_clk100),
    .CE(1'b1),
    .D0(1'b1),
    .D1(1'b0),
    .R(1'b0),
    .S(1'b0)
/* clock buffers */
IBUFG IBUFG_clk( .I(clk100), .O(dcm_clk100) );
BUFG BUFG_clk( .I(dcm_clk100), .O(clk) );
BUFG BUFG_PCLK( .I(pclk0), .O(pclk) );
/* Use DCM to generate 25 MHz VGA pixel clock from 100 MHz main clock */
DCM_SP #(
         .CLKDV_DIVIDE(4.0),
         .CLKFX_DIVIDE(8),
         .CLKFX_MULTIPLY(2),
         .CLKIN_DIVIDE_BY_2("FALSE"),
         .CLKIN_PERIOD(10.0),
         .CLKOUT_PHASE_SHIFT("FIXED"),
         .CLK_FEEDBACK("1X"),
         .DESKEW_ADJUST("SYSTEM_SYNCHRONOUS"),
         .DLL_FREQUENCY_MODE("LOW"),
         .DUTY_CYCLE_CORRECTION("TRUE"),
         .PHASE_SHIFT(0),
         .STARTUP_WAIT("FALSE")
) DCM_SP_inst (
        .CLKFX(pclk0),      // 0 degree DCM CLK output
        .CLKFB(pclk),      // DCM clock feedback
        .PSEN(1'b0),       // no variable phase shift
        .CLKIN(dcm_clk100),       // Clock input (from IBUFG, BUFG or DCM)
        .RST(1'b0)
//wire clk;
 * VGA generator
vga vga(
	.clk(clk),
	.pclk(pclk),
	.hsync(hsync),
	.vsync(vsync),
	.fifo_data(fifo_data),
	.fifo_write(fifo_write),
	.fifo_full(fifo_full),
	.rgb(rgb) ,
	.vtrigger(vtrigger)
 * when vtrigger is pulsed, generate new frame by sending 640x480 pixels
 * to FIFO.
reg [10:0] x = 0;
reg [9:0] y = 0;
assign SRAtemp[10:0] = x,
		 SRAtemp[19:11] = y,
		 SRAtemp[20] = 0;				//possible future bank switch bit
 * count x, reset at end of line, and pause when FIFO is full
always @(posedge clk)
    if( vtrigger || xdone )
        x <= 0;
    else if( !fifo_full )
        x <= x + 1;
 * count y, reset at start of new frame, and increment at end
 * of line. Pause when FIFO is full.
    if( vtrigger )
        y <= 0;
    else if( xdone && !ydone )
        y <= y + 1;
 * only write fifo during active pixels
assign fifo_write = !ydone;
 * SyncRAM address generator
		if( vtrigger )
			SRA <= 0;
		else if ( !fifo_full )
			SRA <= SRAtemp;
 * SyncRAM output into FIFO
always @*
    fifo_data <= SRD;							// RAM data
endmodule
ElEctric_EyE
I know it's not good practice for flow, but the syntax is interesting nonetheless. This is the furthest I could get away with:
 * top level module
module main(
    input clk100,
    output [4:0] red,
    output [5:0] green,
    output [4:0] blue,
    output vsync,
           hsync,
			  pclk_out,
wire [15:0] rgb;
wire fifo_write,
     fifo_full,
     pclk0,
     vtrigger;				//when vtrigger is pulsed, generate new frame by sending 640x480 pixels to FIFO
wire xdone = (x == 639) && !fifo_full,
     ydone = (y == 480);
		 green = rgb[10:5],
		 red = rgb[15:11],
		 SRAtemp[10:0] = x,
		 SRAtemp[19:11] = y,
		 SRAtemp[20] = 0,					//future bank switch bit
		 fifo_write = !ydone;			//only write fifo during active pixels
reg [10:0] x = 0;
reg [9:0] y = 0;
ODDR2 ODDRA (
    .Q(pclk_out),
    .C0(pclk),
    .C1(~pclk),
    .CE(1'b1),
    .D0(1'b1),
    .D1(1'b0),
    .R(1'b0),
    .S(1'b0)
ODDR2 ODDRB (
    .Q(SRCLK),
    .C0(dcm_clk100),
    .C1(~dcm_clk100),
    .CE(1'b1),
    .D0(1'b1),
    .D1(1'b0),
    .R(1'b0),
    .S(1'b0)
/* clock buffers */
DCM_SP #(
         .CLKDV_DIVIDE(4.0),
         .CLKFX_DIVIDE(8),
         .CLKFX_MULTIPLY(2),
         .PHASE_SHIFT(0),
) DCM_SP_inst (
        .RST(1'b0)
 * VGA generator
vga vga(
	.clk(clk),
	.pclk(pclk),
	.hsync(hsync),
	.vsync(vsync),
	.rgb(rgb) ,
	.vtrigger(vtrigger)
        x <= 0;
        x <= x + 1;
    if( vtrigger )
        y <= 0;
        y <= y + 1;
		if( vtrigger )
			SRA <= 0;
			SRA <= SRAtemp;
always @*
endmodule
Arlet
Post by Arlet »
I would rather just keep the extra 'wire' in there.. makes it easy to move lines around without breaking things.
ElEctric_EyE
Cool. I was just experimenting...
Tomorrow, I would like to come up with a machine that writes coordinates into the SyncRAM using the hardware line plotting routine White Flame helped me out with towards the end of this thread and your FIFO machine.
Arlet
Post by Arlet »
Hmm.. I think my FPGA died. I can't program it any more. Impact returns with an red error flag. I can still program other boards, so the JTAG adapter is okay. I'll have to order another Spartan, and see if I can repair the board.
ElEctric_EyE
I doubt the regulator was overloaded. That stinks...
In an effort to get the SyncRAM timing closer to being correct, I tried to add the CLK0 (before trying CLK90) output to the DCM. Then that goes to a BUFG. That clk1 output then goes to:
always @(posedge clk1)
     fifo_data <= SRD
Now nothing works.
Arlet
Post by Arlet »
I'm guessing it was taking the JTAG connector on/off while everything was powered. Maybe that caused a latch-up condition or ESD . I don't think it's the regulator. These things are typically protected against overload and short circuit. Also, I didn't see more than 120 mA total current.
Are you just using your clk1 to capture the SRAM data, and using the other clock for everything else ? That should do something, at least. Can you lead clk1 off-chip and see if it's running at the expected frequency ? You could also run a sim, and see if the clock is running correctly on there. Are there any warnings about the clock ? You should always watch out for warnings that say that signal-such-and-such isn't used or that nothing is clocked by a certain clock.
ElEctric_EyE
Arlet wrote:
I'm guessing it was taking the JTAG connector on/off while everything was powered. Maybe that caused a latch-up condition or ESD...
I'll stop doing that then. I've done it several times.
Arlet wrote:
...Are you just using your clk1 to capture the SRAM data, and using the other clock for everything else ? That should do something, at least. Can you lead clk1 off-chip and see if it's running at the expected frequency ? You could also run a sim, and see if the clock is running correctly on there. Are there any warnings about the clock ? You should always watch out for warnings that say that signal-such-and-such isn't used or that nothing is clocked by a certain clock.
Yes, clk1 just to transfer SyncRAM data to the fifo.
The simulation looks good.
No warnings about the clock.
Another observation. I got rid of the IBUF, and used the DCM's CLK0 output to generate clk. Now there are no warnings during implementation. Here's what I have for the BUFGs and DCM. Still no output from the DCM. Do you see anything wrong?
/* clock buffers */
//IBUFG IBUFG_clk( .I(clk100), .O(dcm_clk100) );
BUFG BUFG_clk( .I(clk0), .O(clk) );
BUFG BUFG_clk2( .I(clk1), .O(clk2) );
DCM_SP #(
         .CLKDV_DIVIDE(4.0),
         .CLKFX_DIVIDE(8),
         .CLKFX_MULTIPLY(2),
         .PHASE_SHIFT(0),
) DCM_SP_inst (
        .CLK0(clk0),         //0 degree CLKIN output
        .CLK90(clk1),       //90 degree CLKIN output
        .CLKIN(clk100),       // Clock input
        .RST(1'b0)
Arlet
Post by Arlet »
According to UG382, p72:
CLKFB: Clock feedback input to DCM. The feedback input is required unless the DFS outputs, CLKFX or CLKFX180, are used standalone.
The source of the CLKFB input must be the CLK0 or CLK2X output from the DCM and the CLK_FEEDBACK must be set to 1X or 2X accordingly.
So, you need to feed CLK0 output in a BUFG, and the output of the BUFG back into the CLKFB input. The IBUFG is optional. If you don't specify it, the tools will automatically infer a IBUFG. Check the technology schematic, select the clock signals, and you can see exactly how everything will be wired up. Originally I didn't have the IBUFG/BUFG, and I got some strange warning. On the Xilinx forum I found advice to explicitly include the clock buffers so the tools wouldn't get confused, even though it inferred exactly the same thing.
