Ah.
That is the IC that I was suggesting that I might send it to you, but I also told you that it wouldn't work, since it is too small (8k).
What you need is a 28C256 (32k), or bigger, maybe some 29xxxx IC would suit you.
But again, you should be able to program the one you already have (except if you were rewriting it a few times while programing, since you tried to write a bigger file that it actually fits)...
http://www.ebay.com/itm/1PCS-XICOR-X28C ... 3cbe363a1c
Many of you are discouraged by the look of IC that are sold on ebay, but I never had issues with them.
