Building a simple 6502 microcomputer
Re: Building a simple 6502 microcomputer
Great, thanks!
- GARTHWILSON
- Forum Moderator
Where can I find wire wrap board? Can I just use a perf board instead?
How do you 'fix' the sockets to the perfboard? Can they be soldered to the board?
Garth, any idea what hole diameter is appropriate? Digikey offers parts with 37mil or 42mil (0.94mm or 1.07mm)
Edit: ah, the smaller holes are for a board with plated through holes and pads for each hole - also more expensive. (http://www.alliedelec.com/search/produc ... U=70012513)
I found an interesting-looking forum here: http://forum.allaboutcircuits.com/tags.php?tag=wirewrap
- GARTHWILSON
- Forum Moderator
The hole sizes sound right. The plated-thru holes have their place, but won't be needed in a lot of home-made digital boards. You can still have a ground plane without the plated-thru holes. .042" is what I've always seen for the non-plated-thru ones, and then depending on the board material, sometimes the fibers on the inside of the hole kind of hold the pins in before you've added any wires to them. The insides of the holes are sometimes kind of "fuzzy" I suppose because for that kind of board it is neither necessary nor cost-effective to change the drill bits as often as they do for high-quality custom PCBs.
- BigDumbDinosaur
got me there - hot glue? Or maybe they push-fit.
When I used to use wire-wrap sockets on perf board I'd secure them with cyanoacrylate adhesive. If you do that, I shouldn't have to mention that once it's glued to the board it's very permanent.
I wonder, how do WW components like the crystal or and LED? Can they be wire wrapped or do they need some sort of socket?
- GARTHWILSON
- Forum Moderator
Things like LEDs and resistors can be wire-wrapped but then need to be soldered, unlike .025" square posts. If the part can have a crystal connected directly, go ahead and use the crystal (like the 65c51 normally calls for); but otherwise don't bother trying to make an oscillator. Just get one in a can (like Ed recommended at viewtopic.php?f=1&t=2280&start=3) that plugs into an 8-pin or 14-pin SIP socket. They take less work and space and are more reliable than making your own, and possibly even cheaper.
The pirmer addresses both of these, but I just added the part about wire-wrapping things like resistors yesterday.
I don't if these cuttable single-in-line strips are useful:
http://www.harwin.com/D01-995-Specialis ... amily.html
(The image doesn't look like wirewrap, but it is.)
You can click through to worldwide suppliers and see their stock levels.
I've mentioned this site before, but I'll do so again:
http://electronics.stackexchange.com/qu ... wrap-board
- GARTHWILSON
- Forum Moderator
If you use SIP WW sockets, you will need some way to keep them perpendicular to the board so they don't slant over and touch the next row over. You can either glue them in or solder the base of at least a couple of pins to the pads around the holes. I did this on a few things on my workbench computer.
Now it's the waiting game. Wait till I get my wages... The amount of information you all provided have made me confident that I can build it!
And also EhBasic can be very easily modified to fit in any system.
ElEctric_EyE
BTW this was when I was very young and I had no scope, just a primative DMM.
My bit of advice if you want to skip over all my blah blah blah, is to pay attention to power distribution. Observe the voltages on every IC, even if your initial circuit works, and make notes.
Again, good luck!
