Just one thing:
I had one problem with your solution: your routine 'convertString' messes with the string pointer and expects the caller to use the returned changed string address. TBH that was not what I intended. The idea was to put a string at an address given by the caller (so you can add strings together e.g. for generating a disassembly output: MOVE #<string here>, R0). However, rewriting the convertstring routine might be a bit boring. So I thought about the following:
In 6502 assembly a routine for writing a value as hex nibbles would usually look like
PHA
LSR
LSR
LSR
LSR
ORA #'0'
CMP #'9' + 1
BCC ?0
ADC #'a' - '9' - 2
?0: STA ...
PLA
AND #$f
ORA #'0'
1) convertstring
in: register 1: value
register 2: pointer to string
out: register 2: new pointer to string (pointing to the end of the string: '\0')
2) outhex16
register 2: pointer to device object
out: register 3: errorcode
If you like you can implement method 'outstring':
3) outstring
in: register 1: pointer to string
4) outchar
in: register 1: character
How you implement outchar is up to you and not part of the exercise.
Please note: registers 1 and 2 may not be destroyed (except for routine 1). In addition to the errorcode a flag will indicate whether the operation was successful or not. For example, a 68000 will use the Z-flag for this, x86 and 6502 the C-flag.
I'll give you the example in RISC code soon. All I can say so far is that convertstring + outhex16 + outstring take $5a (90) bytes. Should be easy for you to beat this.
Miles
